Question about King Kutter II Gear Driven Rotary Tiller 6ft Tiller Width, Model No. Tg - 72 - Y
Just bought KK II 60in tiller. Tried to attach pto shaft withv slip clutch to tiller. there is a bolt that i removed with the hope the shaft would slide on. but it would not go all the way on. I have not tried to attach to the tractor yet. any help would be appreciated.
2 Suggested Answers
SOURCE: I just got a 5' KK rotary tiller and the pto shaft
http://www.youtube.cohttp://www.everythingattachments.com/Tractor
http://www.everythingattachments.com/Tractor-3-Point-Hitch-Tillers-Rotary-Tillers-s/76.htm
go to the second site first, it will explain your "problem.". Your problem is you need to adjust the length of the pto shaft to your particular application. not all pto shafts fit all attachments "out of the chute"
once the shaft is adjusted OR prio to modifying it, view the first video. both or very well presented. i've been there!
Happy tilling!!
steve wood
Rancho de Suenos
Albuquerque, NM
Posted on Mar 18, 2010
How do you change blades on 5ft bush hog?
lift The brush hog up and place on blocks or other foundation that wont fall over. disconnect the power take off shaft from the tractor. Now look for two round openings in the middle of the deck one on ether side of the gear box (the thing on the brush hog that the pto shaft from the tractor hooks up to to make it spin there might be a slip clutch on the shaft but go to the box in the middle) Now turn the shaft till you see the blade nuts in the hole These could be castle nuts with a small carter pin locking them so they don't unscrew. Remove the pin and with a large socket set unscrew it from the bolt then knock the press fit bolt down and the blade will come off, do the same to the other blade if you need them both off. To put them back on use something under the blade and bolt to hold it up so you can start the nut then reverse the order and put everything back on. The blade bolt might be stubborn to get out just take something that fits through the access hole like a wood doll or long punch and drive the bolt down till it comes out as it is press fit and is jammed up to keep the bolt from turning, when putting it back on you will need to make it tight so the bolt can repress back in. Be Careful when reaching under to set the blade and bolt back in. There is not much you can mess up it is just a big nut and bolt Just make sure you put the blade on the way it came off if you do one blade or one at a time you can look at the other to see which way it goes.
Oct 02, 2014 | King Kutter Rotary Tiller Pto Bush Hog...
On a rzt 42. The pto clutch bolt loosens and clutch falls off with use of 10 minutes or less. How do I fix?
The PTO clutch has a bolt that goes through it and into the vertical shaft of the engine. MANY of the PTO clutches have a large spacing washer that goes on before the PTO clutch is slipped onto the shaft. If the washer was lost when the clutch was changed, the bolt might be bottoming out in the shaft rather than tightening on the threads like it should. I'd get a diagram for your model and make sure all parts are in place.
Jun 05, 2014 | Cub Cadet RZT S Series
Remove clutch
I'm assuming you're referring to the PTO clutch on the bottom of the engine shaft. There's a 5/8" bolt that goes up through the clutch into the shaft. Remove it, but then turn it back in about 10 turns and use a wheel puller to start getting it off. You might have to c-clamp the PTO/clutch top and bottom together to get both pieces off. Once the assembly starts coming down the shaft, you can probably remove the wheel puller, remove the bolt completely, and pull the PTO/Clutch off by hand. Be sure to unplug the PTO/clutch before removing it. Also, many of these have a spacing washer on top of the PTO/Clutch that comes off in the process. BE SURE to put it back on before replacing the PTO/Clutch. DO NOT hit anything with a hammer to try to break it loose - you'll most likely NOT get the part off and most probably WILL damage necessary parts.
Jul 29, 2013 | Cub Cadet Riding Lawn Garden Tractor 25hp...
John deere 2210 engine dies when engaging pto, seat switch good
are you sitting in the seat or have you jumped the safety switch under the seat before you engage the PTO I believe our tractors use an electric solenoid to apply hydraulic pressure to a wet clutch inside the trans axle I would think it would be OK with your chipper I have a 450 tiller that was built for the older 400 models 425 445 455 that I now use with my 2210 If I hit a large root or stone when using it with my old 445 it would stall the tractor at full power. Now with the 2210 it will actually slip the clutch on the tiller s PTO shaft I think the correct approach would be to increase your RPM s gradually or start increasing the power just as you trip the PTO switch. You want enough RPM s to create enough hydraulic pressure to run the PTO circuit so that you don t slip the wet clutch anymore than necessary and you want the RPM s low enough so that you don t shock the mechanical systems too severely at start up
Let me know how it works
Feb 02, 2012 | Garden
The tiller will not rotate. The PTO shaft on the tractor is spinning but the tiller will not move. The shaft coming out of the top of the tiller will not spin. There was also a burning smell with a...
Sounds as if you might have destroyed the gearbox or cooked the internal clutches or both....nothing to do but disassemble the gearbox to find out...you may have a broken gear tooth or teeth jamming the pinion...the FIX may be more expensive than the cost of a new tiller...call Tractor Supply to see if replacement parts are even available...sorry to be the bearer of such bad news... ;-(
Aug 11, 2010 | King Kutter Ii Gear Driven Rotary Tiller...
I just got a 5' KK rotary tiller and the pto shaft fits onto the tractor just fine with the button lock. The other end doesn't want to slide all the way onto the tiller gearbox drive shaft. It only goes...
Happy tilling!!
steve wood
Rancho de Suenos
Albuquerque, NM
Mar 10, 2010 | King Kutter II Gear Driven Rotary Tiller...
Slip clutch shaft broke and I'm wondering what the maintenance is on the slip clutch i guess the clutch froze up and it broke the shaft from the universal joint to the 2nd part of the shaft
At least once a year back the clutch bolts out at least 3 turns and engage PTO at operating speed a couple times.Once thats done turn bolts back in the same amount of turns.By doing this you burnish the disc's and prevent them from rusting/seizing together with the plates.
Sep 18, 2009 | King Kutter Xb Rotary Tiller 4ft., Model...
PTO clutch stop needs replacing 2130 Cub
take cover off flywheel so you can hold it from turning.or use a air compressor on clutch bolt
Jul 20, 2009 | Garden
Troy Bilt Tiller tines do not engage
You likely have a clutch problem, never saw one that a simple adjustment would fix. I'd take off the tiller (there are two bolts that hold the tiller portion to the transmission, and check to make sure the clutch is sliding in and out. My hunch is either the lever is loose on the shaft or the allen-head little bolt that they use to shift the clutch has come out. Be sure to grease the clutch while you're in there.
This should be covered in your owners manual. Shame on them if they didn't mention this.
May 24, 2009 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
Changing Drive belt On Troy Built Tiller
You have to remove the engine (4 bolts, no big problem), then remove the bolt in the center of the pulleys, then remove the pulleys. Slip the belt(s) (2 if you have the Super Bronco model) onto the pulleys, re-attach the pulleys with the bolt, re-mount the engine, and you're home free.
May 20, 2009 | Mtd Troy-Bilt Bronco OHV Tiller
King Kutter II Gear Driven Rotary Tiller 6ft Tiller Width, Model No. Tg - 72 - Y Logo
53 people viewed this question
Top King Kutter Garden Experts
Jay Finke
Jay Finke
john h
Mai Lor
Are you a King Kutter Garden Expert? Answer questions, earn points and help others
