Question about Canon NP 6035 Copier
My Canon copy NP 6035 if in turn it does not want to live. sound briefly returned to off himself. how the solution. thanks.
  • Canon Expert
  • 1,326 Answers
The copier comes ON then it turns it's self Off , Correct? Turn the copier back ON and hold the Main power switch ON and the display will show a error code. Read it and let the copier turn Off. You most likely have a dead AC short. The error code maybe a E0202 or E000 . One of the lamps are blown or broken and shorting out. You probly have a blown scanning Lamp or fuse. You may also, have a shorted out Scanner Power Cable. It's black and powers the scanner lamp > sometimes the cable crack's and exposes the AC wire. That is a fun job. It may just be a blown fuser lamp.. Good Luck
Posted on Sep 06, 2010
I NEED TO DOWNLOAD CANON NP 6035 MANUAL
Send your email adress!
But I think that the best way is to buy new one digital age.Its not worthed to waste your time on this machine.
In service manual wont find nothing abaout your problem description.
Check dc controller, power supply, check fixing assy...
Jun 22, 2010 | Canon NP 6035 Copier
How do you replace toner for canon np 6035 copier
open the front cover, then you will need to slide out the piece the toner goes into, upper right side. Set the toner cartridge on top. You will see a tab to pull toward you, so the toner will drop down into the copier. Push the tab back in. Then push the cartridge toward the back of the copier a little and pull up.
May 15, 2010 | Canon NP 6035 Copier
Canon np 6035 saya tak menyala tombol start di posisikan on mati sekitar 5 detik mati sendiri
Mesin canon NP 6035 kalau dinyalakan keluar kode E 224,kenapa yaa????mohon bantuanx....thanks.....
Oct 01, 2009 | Canon NP 6035 Copier
Copier Drum problem
If you send me a copy i 'd tell you
Mar 20, 2009 | Canon NP 6035 Copier
Cannon NP 6035
probably the buttons are not working. you will need to check the control panel (whee the button are at) and check if the micro switches are working properly.
Jul 17, 2008 | Canon NP 6035 Copier
Printing on Canon NP 6035
I check www.usa.canon.com and couldn't find anything that came close to that model number. You should contact them directly. It may require a copier dealer in your area to get one for you.
Jun 26, 2008 | Canon NP 6035 Copier
Canon np 6035 copies to dark
He is probably adjusting the exposure voltage. If you take a flashlight and look inside the small hole, you should see either a "+" or a "-" on a plastic part. Turning it clockwise will increase the voltage, and counter clockwise will decrease the voltage.
If you are going to do this, I would suggest using a plastic screwdriver to turn the "Pot" (Potentiometer)
Doing with by yourself will be a hit or miss effort. Also it is not recommended doing this without knowing what you are doing.
FYI, If you are going to turn the "Pot" on your own, I would suggest turning it very little and testing a copy, and then doing this again and again to make sure you are helping the situation or hurting it.
Good luck.
Hope this helps.
If I have helped, please post a feedback and a rating towards me.
Mac
Feb 28, 2008 | Canon NP 6035 Copier
E065 error
E codes are usally associated with copy jams check all paper drawers for paper jams and display panel indicator to see what area is lit and then check that area for trapped paper.
Jan 15, 2008 | Canon NP 6035 Copier
Canon NP 6035 Copier Logo
79 people viewed this question
old marine
old marine
