Question about Sharp Office Equipment & Supplies
Staff member who knew the admin password has left. How do I reset this so I can access machine and instal new password?\r\nthanks
Contact the company who leased your copier. They'll assist you with the password.
Posted on Sep 10, 2010
Forgot ip address and password
To re-enable the Console access requires the SW2900 series to be reset to its default settings via the WEB INTERFACE
- Web Interface
- Device >Configuration >Initialize To change the Default User "ADMIN" password it is necessary to use the Console connection
-Console Interface
-Once the unit has successfully booted and the prompt presented
-Enter "password" (without "")
-Enter "admin" when the system prompts for User
-Press the "Enter" key when the system prompts for "Old Password" (the ADMIN password was reset by the Web Interface commands)
-Enter "" when the system prompts for the New Password (where "" is the new product ADMIN password)
-Enter "" when the system prompts to confirm the New Password In order to complete the configuration it is necessary to save the configuration via the WEB INTERFACE
-Web Interface
-Device > Configuration > Save
Symptom:
SW2900 Baseline Switch - Default console access disabled following password change
From the web interface, the default user "admin" password is changed and console access is disabled
Cause:
When applying the new password, by default the service-type is set to "telnet". When applied, the default "terminal" setting is removed thus disabling console access.
Apr 20, 2013 | 3Com Baseline Switch 2924-SFP Plus
Tip
Reset sql sa password directly and efficiently
A few days ago, I had a painful experience that I lost SA password on my MS SQL Server database, and I almost took the whole weekend to look for an efficient way to reset SA password. I asked friends, searched on Internet and even bought some book.... Fortunately, I finally got a SQL server password recovery software and it instantly reset SA password without data loss. And I also got a couple of good solutions for sql sa password reset to save your weekend in case you have lost or forgot MS SQL Server passwords (SA password!).
Option 1 : Use MS SQL Server Password Unlocker to Recover/Reset SA Password
The most direct, efficient way to reset SA password is to take use of the third part utility - SQL server password recovery software. Just two steps:
Step 1: Access to master.mdf file, which is default at C:\Program Files\Microsoft SQL Server\MSSQL\Data\master.mdf
Step 2: Select SA password and reset SA password
So, Reset SA password successfully!
Option 2 : Recover or Reset SA Password with Other SQL Server Login
If there is any other SQL Server Login that is a member of sysadmin role, you can log in using that account and reset SA password of SQL Server. Reset sql sa password as described here :
SQL SERVER - Reset Password of SA Login Using Management Studio.
Login into SQL Server using Windows Authentication.
In Object Explorer, open Security folder, open Logins folder. Right Click on
SA account and go to Properties.
Reset SA password, and confirm it. Click OK.
Make sure to restart the SQL Server and all its services and test new password by log into system using SA login and new password.
Option 3 : Recover or Reset SA Password with Windows Login that is a member of Windows Admin Group
If there is any other Windows Login that is a member of Windows Admin Group, log in using that account. Start SQL Server in Single User Mode as described followings :
SQL SERVER - Start SQL Server Instance in Single User Mode.
There are certain situation when user wants to start SQL Server Engine in "single user" mode from the start up.
To start SQL Server in single user mode is very simple procedure as displayed below.
Go to SQL Server Configuration Manager and click on SQL Server 2005 Services. Click on desired SQL Server instance and right click go to properties. On the Advance table enter param '-m;' before existing params in Startup Parameters box.
Make sure that you entered semi-comma after -m. Once that is completed, restart SQL Server services to take this in effect. Once this is done, now you will be only able to connect SQL Server using sqlcmd.
on Oct 05, 2010 | Computers & Internet
I am locked out of facebook account. It keeps telling me that I entered wrong password. I tried requesting new password and it tells me that it is incorrect and that I have made too many attempts.
Login and password I forgot the password to my login email address. Contact your email provider to regain access to your login email address. For email domains other than those listed below, please locate your email provider's help center.
Gmail
Hotmail
Yahoo
Once you have regained access to your email, try resetting your Facebook password here. Was this answer helpful?
Feb 09, 2011 | Computers & Internet
I just installed my new netgear router and i have the hardtime to get a username and password..what is the best way to fix this problem
Default settings will be as mentioned below....
IP address:
//192.168.1.1
Username: admin
Passsword: password
Thanks,
Satheesh
Jan 27, 2011 | Computers & Internet
I have Dlink 615 model router. i reset one time and now i want to change again my name and password but i cant log into. I try admin in with the IP address and also my user name and password but i cant get...
When you reset your router the IP address will revert back to its factory default IP address and access information, if you changed the IP address prior to the reset you will have to use the default IP.
default IP: 192.168.0.1 (make sure that your network cards IP address is somthing similar like 192.168.0.2 and not 192.168.1.2)
Default username: admin
Default pass: leave blank
If you are still having issues let me know.
Jun 20, 2010 | D-Link DIR-625 (790069292637) Wireless...
Need to find out the password to get onto the speedstream we did not get a password when it was set up for us
You don't mention what model Speedstream you have. Assuming the installer left the default admin password on it, you can refer to http://www.routerpasswords.com to find out what that default password is. For most (but not all) models of Speedstream, the user ID is admin, and the password is admin. If the installer did not leave the default password on it, there's no way to find out what it is short of actually asking him.
Nov 17, 2009 | Computers & Internet
I have an old school pc it is an emac and need an password for it can you break it
In OS X, if you're the administrative (or only) user, you can reset the admin/user password using the OS X installation disk #1. Put the disk in the CD drive & restart the eMac while holding the "C" key down (Restart is also on the Apple menu, top-left corner of your screen). When the Installer opens, click "Utilities" then Restart. When the Installer asks you what language, pick one (maybe English?) 8¬), click continue (arrow) then Utilities again & choose "Reset Password"; the system will guide you through the steps. Once you've reset the user password, restart the eMac, then you can log in using the new password. You'll probably want to reset your "Keychain" password to match your new login password – otherwise it'll ask for your password every time it needs one for a program. "Keychain Access" is in the 'Utilities' folder, which is inside the 'Applications' folder.
—> Important: if the old Users Home Folder was encrypted ("FileVault" protected), you'll need the old user's password, or the eMac's Master password to access the files in the Home Folder – otherwise, the Home folder's files will be lost. As a new user, you'll have your own Home Folder & access to all application programs.
Oct 16, 2009 | Apple Computers & Internet
I need to put a password on my wireless router so neighbors cannot access my internet connection.
Access the configuration page of the router by typing in 192.168.0.1 on the address bar.
>Type in Admin/admin on your the log-in page and leave the password blank click ok.
>If you created a username and passsword used that one, if you forget your username and password reset the router for 15 seconds. Reset button is located at the back of your router and use admin on the login page.
>Once inside, click on HOME and on the left side choose WIRELESS
>Enables should be choosen.
>Under SSID, change your network name to a new one.
>Under Network Authentication choose WPA-PSK
>Key type would be passphrase
>Type in your password for your network. mimimum 8 character.
>Click on Apply >Continue.
>On your laptop, connect first to your wireless network before accessing the Internet.
Jan 21, 2009 | D-Link DI 514 Wireless Router (DI-514)
Domain\administrator has no local admin rights
You may need to edit group policy if this was once in a domain. You may want to try rebooting the machine and logging into the 'LOCAL' machine and see if you have rights that way. Each machine by default has one administrator account but if the server was part of a domain, that right may have been removed. You may need to reset OWNER privileges for all files in the machine.
Jul 24, 2008 | Microsoft Windows Server Standard 2003 for...
195 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
