Question about Tomtom One XL GPS Receiver
I down loaded the USA-Canada-and Mexico- map last evening . Today my Tom Tom says There is a problem with map. "You cannot use this map on this device:USA-Canada-and Mexico-P-165." I can't delete it. My XL is frozen and won't respond. How do I fix this back to working order.
ameriscot
  • 7 Answers
SOURCE: tom tom one usa nd canada
here is a possible solution from TomTom tech support:
To solve this, use TomTom HOME to install the application. Follow the steps below:
  1. Install TomTom HOME on your computer, if it isn't already installed. You can download the latest version of TomTom HOME here: www.tomtom.com/home
  2. Connect your device to your computer and switch it on.
  3. TomTom HOME opens automatically and checks for updates. If it does not automatically check, do one of the following:
    • In HOME 1.x select Device > Update now from the menu bar.
    • In HOME 2.x, click Update in the HOME menu.
  4. When you are shown a list of available updates that you can download, make sure that you select the check box for the TomTom application.
TomTom HOME downloads and installs the latest version of the TomTom application for your device.
Posted on Dec 17, 2007
SOURCE: tom tom one xl wont accept SD card with map on
Make sure the SD Card is formatted as FAT32 and not FAT. My TomTom One XL would not recognize it until I did that.
Posted on Aug 01, 2008
Trail0fDead
  • 36 Answers
SOURCE: tomtom one 125 map
The reason the 125 is cheaper is because it only has the US map on it. Each map contains an activation file that prevents it from being used on different devices, so its doubtful that the other map will work for you. You can purchase the latest Canada/Alaska map from TomTom's site for $59.95.
Go to
http://www.tomtom.com/products/maps/
Select your device as the ONE 130 (since they don't have 125 on the site) and choose the Canada/Alaska map.
Posted on Jan 10, 2009
If you have TomTom that have the slot for SD card, then it should accepted the SD card. The instruction for how to use the SD card is simple, but it is hidden in the TomTom Home, that's why it's difficult to find it. Below are the instruction how to use the SD card.
1. Format the SD card (FAT32) and do not stick the SD in the slot yet
2. Run Backup (connect TomTom device to computer)
3. Disconnect TomTom from computer and turn off
4. Slide the SD into the slot and connect TomTom back to computer (choose "yes")
5. In the TomTom Home menu, Choosen Backup & Restore >>> and choosen Restore
TomTom Home will add all applications to the SD card. So the internal memory still have the applications and the SD card also had the same applications. Everytime you slide the card in, TomTom will automatic detect and use it as its primary storage, if it not detect, you can go to the device menu and pick the device to connect to.
Whenver you take the SD card out, then TomTom will use its internal memory.
Hope this helpful
Posted on Mar 06, 2009
  • 171 Answers
SOURCE: Problem with map. You can't use this map on this device TOMTOM
It sounds like you are trying to use cracked maps and have not patched the .dll file for your TomTom in TomTom Home. Use yDGpatch to patch the .dlls in TomTom Home
Posted on Jun 23, 2009
Testimonial: "thanks"
Does Puerto Rico come with the map of USA on tomtom.com that you can buy?
According to the TigerDirect specifications for the device, it does include the Map of Canada, Mexico, the Continental USA + Hawai and Puerto Rico.
But you don't have to believe that. You should visit the TomTom Website. You will have to visit it anyway if you buy the device: That is where you will get your updates.
Dec 23, 2013 | Tomtom VIA 1505 GPS Receiver
How to map canada only
See if TOM TOM has that available but most major brands like Magellan have both Canada and USA in them--
Jun 17, 2012 | Tomtom GPS
Can you load mexico maps on a jvc kwnt1
I've only seen USA/Canada maps and updates are ~$139 each.Might want to upgrade to a different brand/model that has worldwide support like TomTom.
Nov 16, 2011 | Car Audio & Video
What do i need to do when i hook up my tom tom for the first time and try to download the map. i dont want mine to crash like some other ones did when they tried to download. im getting a tomtom 340s in...
It is a good thing that TomTom more or less functions like a computer. Start with downloading the TomTom home from TomTom website.
Then follow the link below.
http://us.support.tomtom.com/cgi-bin/tomtom_us.cfg/php/enduser/std_adp.php?p_faqid=7954&p_created=1194036534&p_sid=lhLt3NZj&prod_lvl1=&prod_lvl2=&cat_lvl1=&p_accessibility=0&p_redirect=&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9MTI2LDEyNiZwX3Byb2RzPSZwX2NhdHM9JnBfcHY9JnBfY3Y9JnBfcGFnZT0xJnBfc2VhcmNoX3RleHQ9bmV3IG1hcA**&p_li=&p_topview=1
Then comes the tricky part. If you are in US or Canada, you will see that the new map will not install properly. Reason? not enough space in your Tom Tom for 2 maps simultaneously.
Solution : Connect the GPS to computer via USB cable . copy every thing to a folder in your computer. Make a second copy as a precautionary method. Now go back to the GPS (drive) in the file manger. (delete the maps-USA-Canad-Mexico folder. This is an example, if you are from a different country find the map folder and delete it. ) You will see that you have freed approximately 1.6 GB space. Go back to TOMTOM home and use the latest map guarantee feature. This time around you will see that the map updates completes without failure.
Check it out by driving around through some roads you know.
Good luck
Apr 17, 2010 | Tomtom XL 340S Car GPS Receiver
How do i get to the map for puerto rico on new tom tom
Puerto Rico is included with the latest 'USA' or 'USA & CANADA' or 'USA & Mexico' TomTom maps.
Depending on what map came originally with your unit, you can download the required USA map either for free or for a fee via 'TomTom Home' while connected to the internet. Alternatively, you can get it from a retail shop or from Tomtom directly on a DVD. It is a new Map, it will need to be registred to your device: you cannot just simply copy the maps from somebody else ...
WARNING: unless your unit came with a SD memory slot or came with 1GB of internal memory, YOU WILL NOT BE ABLE TO USE those rather large maps! For instance, Tomtom One V3 in Australia only come with 512K and NO SD memory slot!
Hope this information is useful: let me know how you go!
Jan 03, 2010 | Tomtom ONE 130 GPS Receiver
I am looking to buy a GPS that have both Canada and USA maps on it. Also do not want to spend lots of money. Need to have 5 inch screen.
Most of the devices on the market now have both maps on it and some also have Mexico. The cost probably won't exceed $150-200. Garmin, Tom-Tom, Magellan and others should fill your needs.
Aug 15, 2009 | GPS
I cannot download the USA and Canada on my Tomtom any more
Connect the device to a pc via a usb cable. It will appear as an additional external drive. Navigate the drive and you will fin a folder called Guam.
Copy it to the PC.
There will be another one called USA_and_Canada. check if it has any contents.
The Tom Tom website can tell you how to install the map again if it is not there
May 28, 2009 | Tomtom ONE GPS Receiver
Will not properly display rural areas near Greenwood,Nova Scotia ,Canada postal code b0p1n0
If you have the most updated maps installed the only other option I can tell you to try is making sure that all your avoidances are selected properly. Usually by default your avoidances are set so they don't recognize things like rural roads, toll roads, dirt/farm roads for fastest directions and speed. Look into this and see if your adviodances are turned on. If so then turn them off and see if your roads are there. If it doesn't work then you will need to connect your garmin to the PC and run an update to see if you have the latest map update.
Hope this helps
TankMurdock
Apr 14, 2009 | Garmin Nuvi 350 Car GPS Receiver
SETTING COUNTRY
Try clicking on the main part of the screen during navigation. Then click on the "wrench" icon (Change preferences). Then click the blue arrow (2x) until you get to the 3rd page (Preferences 3 of 5). Click on Manage maps. Then click on Switch map. Then select USA & Canada.
Dec 28, 2007 | Tomtom ONE GPS Receiver
Fix a tomtom
Turn the tomtom on, and then press the reset button on the bottom of the unit with a paperclip. After the reset turn off the unit and then turn it back on. Make sure you have not dislodged the sd card from the unit.
Mar 19, 2007 | Tomtom ONE GPS Receiver
Tomtom One XL GPS Receiver Logo
180 people viewed this question
Top Tomtom GPS Experts
LP
k24674
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
