Question about LG LFX23961SW Bottom Freezer French Door Refrigerator
Open Question I have a Refrigerators: LFX23961SW (french door) the right door doen not always close when I give it a shove - leaveing about 3/4 in. open will turn off the interior light but will not activate the alarm system after one min. Repair sersive says nothing can be done to correct this problem! Could I shorten the door on off light button? Has any one had this problem before, Greg.
  • 828 Answers
SOURCE: LG LRFC25750 Refrigerator French Door
Freezer section evaporator fan motor bearing are going out. This would be indicted by a high pitched squealing noise. Have the fan motor replaced and it should solve your problem.
Posted on Jul 31, 2008
  • 187 Answers
SOURCE: interior light does not turn off
Hi, try this  There s this knob that gets pushed when you close the door (the door puhses on it when it closes) and the light goes off
you can do it yourself, open the door and find the knob somewhere around the light or on top where the door closes and push it, the light should go off..
Pls rate my solution.. thank you
Posted on Apr 11, 2009
  • 28 Answers
SOURCE: Refrigerator Door not staying closed
Try to raise by adjust the 2 front footing slightly higher than the back, this will tilt the unit slightly backwards. That will help the door to close back by itself.
Posted on May 09, 2009
SOURCE: Our French Door model after almost 2 yrs pops open
We solved this problem by replacing the plastic parts on the top & bottom of the door that 'latch' the door closed.
On the top of each door is a white plastic 'cam' that latches into a receiver at the center point of the refrigerator chamber. One of mine was broken.
Additionally, on the bottom edge of each door is a white plastic hook-shaped 'stopper' that provides spring tension. I replaced both of those and now all is happy.
Got the parts from
Item #: 1266811
Description: Door hinge cam (left)
Price: $2.40
Item #: 1266810
Description: Door hinge cam (right)
Price: $2.40
Item #: 1267543
Description: Stopper,door
Price: $2.40
Posted on Oct 31, 2009
SOURCE: refrigerator light won't turn off
Either the doors are not closing properly, or the door-light switch is bad. Though I would not be at all surprised that it is a more complicated issue such as a motherboard since it is an LG (low grade) refrigerator.
Posted on Jul 28, 2010
I have an LG fridge display giving me ER F1 code. i can unplug the fridge and plug it back in and the display resets for about 2 minutes and the the code comes back?
The ER 1F code usually means that there is a problem with the ice compartment fan, the ice maker motor or one of the control boards (the one for the ice maker or the main control unit). You can try resetting the refrigerator by leaving it unplugged for a day. Next check for ice build up on the fan that is blocking it from turning. Usually, if the fan hasn't been turning, you will have to at minimum replace the motor. It will burn out trying to force the fan to turn.
Sears Parts Direct has a diagram of the LFX23961SW case parts here: . The fan motor is part 405G.
I hope this helps.
Apr 15, 2015 | LG LFX23961SW French Door Refrigerator,...
LG 2014 French Door bottom freezer
Possibly the weatherstrip around the doors. Has this always been the case, since the first use?
It's possible, too, that you have a slight obstruction that's keeping the doors from closing fully. They SHOULD seal completely. If they don't, you may have a problem with fast frost buildup, and the defrost timer may not be able to keep up with it.
Jul 29, 2014 | Refrigerators
Ice maker fan running constantly
There are 3 fans on your refrigerator how are you sure that it's your ice fan that is running?
Nov 08, 2013 | LG LFX23961SW Bottom Freezer French Door...
Not making ice error code 1f
Pull the line off at the icemaker and check for a filter at the inlet...often **** builds up there and stops off the water...
Here are some basic tips for ice maker troubleshooting2_bing.gif...
Ice Maker Problems and Ice Maker Troubleshooting
Jul 12, 2010 | LG LFX23961SW Bottom Freezer French Door...
Right side door does not close unless you push it closed with your hand
The lower hinge on each door may have a door closing cam. It raises the door up ¼ inch when opening and this assist in closing the door. If it’s wore out and doesn’t work the door may not seal and the gasket can be damaged. Watch the operation of the door to see if it rises up when opened.
Leave the door shut and let the magnetic gasket hold the door in place. Put something between the bottom of the door and the floor to hold it in case it slips.
Remove the bracket holding the pin and hinge assembly taking note of order of removal of parts. Slide new cams on.
Part 11 on this diagram is your door closer
Nov 06, 2009 | Maytag MFD2560HES Bottom Freezer French...
Feb 24, 2009 | LG LRFC25750 Refrigerator French Door
Refrigerator door not closing all the way
the pressure inside the box is pussing the other door open and what you need to do is tilt your refrig back until the door will close by itself and that will be as far as you need to go back with it ,,,, it's normal for it to happen and a frig should always have a little tilt / larryyb
Nov 28, 2008 | Refrigerators
Right side french door does not stay closed
I had the same problem - had my local appliance repair shop come by - simple releveling of the unit such that it is tilted slightly back re-establishes things so that the doors will cloe and pull themselves closed. The gaskets are actually magnetized. If the leveling is correct - even upon closing the left door - forcing enough pressure to push open slightly the right side - it will draw itself back in.
Nov 21, 2008 | Jenn-Air JFC2089HE French Door...
Sb5101 cabel modem driver For Xp give me
SB5101 USB drivers
Insight Columbus RR driver page Road Runner/ Insightbb Driver page Road Runner name and ... Links to Cable Modem Manufacturers : ... Sharkfin" Home Connect USB drivers (not compatible with XP
You got the drivers, good luck read & follow instructions .
Good Luck, Please dont for get to Vote.Thank You.
Dec 22, 2007 | Computers & Internet
French Door to right swing on Fridge
Go to this link and you can see all the identical sized models with a right swing door. The hinges are the same so you could easily swap them; here's a link to the user manual if you need it; check page 7 and 8 for how to swap a door. Page 20 gives you contact details for spare parts. Hope this helps :)
Jun 27, 2007 | KitchenAid KBFA20ER Bottom Freezer French...
LG LFX23961SW Bottom Freezer French Door Refrigerator Logo
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
