You should phone Miele, that is disgraceful. Tell them you want a factory technician to visit. Whomever you got isn't a 'proper' technician, plus you have expended money for items you didn't need replacing. With my Miele washing machine, the engineer attached his laptop to it to diagnose faults.
The only thing I have found is making sure the salt cover is tight. These machines go through a self test procedure and if sometimes fails, it aborts the program.
F84 Error code Miele\015
As soon as I install the dishwaser I got Error F84\015
Answers :
This problem arises because the water inside the washer cannot get out.\015\012
\015\012Firstly......Make sure the salt cover if screwed on tightly (if you have one).\015\012
\015\012Then remove the filter(s) from bottom of the washer and clean.\015\012
\015\012Remove the drain pump cover and remove the one way valve (a ball bearing in a housing) and clean. Take note of rubber cover direction before pulling it out to clean.\015\012
\015\012Make sure the impeller (visible after you remove drain pump cover) is clean and spins ok. It will have a little resistance as you spin with your finger.\015\012
\015\012Make sure all is cleaned properly and it will all work fine again after replacing it all back in
either a burnt out drain pump or a blown main module,test pump first if it has a burnt smell try another pump sometimes the pump can blow the board so both can end up being replaced
Hi just read your posting.Could you please supply the model number of your machine for me.The model number is located on a sticker at the back of the machine top left.Does your machine stop and beep and show an error code?Please reply with additional information and I am sure I can help you rectify this fault.Looking forward to your reply.
Hi, Problems with a washing machine not spinning or not draining are often inter related.. If you are having a problem with your top load washer then check out this tip...
If there is power and all your lights are lighting up but you get no responce from the machiene eg no spin, water filling, wash cycle or drain then it will be the sensor for the lid it will have coroded but this is an easy fix , I hope this helps
remove the pump from underneath front right move whith clip forward the twist pump out.but you will need to remove all the water first you may a ball of lint stuck in the pump.hope this helps.
