Question about Toshiba Satellite A135-S4527 Notebook
Laptop heats up then shuts down cools down starts again does same thing again
    President:
  • 834 Answers
That sounds like the cooling fan is either plugged up, or it is faulty, or the cooling fins for the CPU heat sink are plugged up with lint and dust. The cooling fan on that toshiba should be accessible through a cover panel under the pc notebook. Remove the cooling fan and use compressed air in a can to clean the cooling fan and the cooling fins to the CPU heat sink and be sure that the air intake vents for the cooling fan are also clean and free of any dust, dirt, or lint. Here are some images that are similar to help assist you, and let me know if you require any further assistance.
Posted on Sep 06, 2010
  • Toshiba Master
  • 32,281 Answers
When the CPU overheats then it will shut down (ie thermal overload) and won't boot up again until it has cooled down. If this is the problem is not fixed then the CPU will eventually fail
The problem is caused by a faulty fan or the fan and heatsink assembly are clogged with dust.
Check the CPU fan to see if it spins freely, if not replace the fan. If the fan and heatsink is clogged with dust the remove the dust and make sure the vents are clear and dust free.
Tip
Laptop Tips: Overheating Problems
Overheating Frequent overheating will damage the motherboard!..becomes unstable, no display, hang-up and worst black-out or no power at all.
Symptoms: The laptop starts beeping, freezes, restarts by itself or shuts down after it has been on for some time, typically 10-15 minutes or more. If you start it again, it does the same thing after just a few minutes.
Troubleshooting: Most laptops overheat because the fan intake is blocked either from placing the laptop on a soft surface or by dust. In either case you will need to let it cool down before turning it back on (may take up to 30 min). If you suspect that dust is blocking the fan/heat-sink, get a compressed air can and try to clean it now (that will cool down the laptop too).
Sometimes overheating is caused by a fan malfunction. If the fan is completely stuck, the laptop will show an error message immediately after starting. However in rare cases the fan’s fins are just loose or broken and won’t move enough air to cool the laptop.
In either case you should try cleaning the fan(s) and heat-sink(s) with compressed air. That is best done outside, as usually there is a surprising amount of dust accumulated in there. If the laptop continues to overheat, you will need to bring it to a repair shop.
Also if you have dropped the laptop, the screws holding the heat-sink may have broken off. In this case the laptop will overheat in just a couple of minutes as the CPU has lost contact with the heat-sink and is not cooled at all.
Another one is moist inside the motherboard or corrosion.
If this troubles may arise and can't solve it yourself, bring it to certified laptop repair shop.
KUYA BOY LAPTOP
machinetosh of tipidpc.com
0912-6888500
on Apr 05, 2010 | Computers & Internet
I have a IBM Think pad laptop running Windows xp that keep shutting down, it go through the POST OK. then 2-3 minutes it shut down. The fan is OK, and the cooling system is ok, so what do I do next.
Hi
its either a software problem or a hardware problem
normally over heating shuts down older style laptops
try using a lap top cooling pad
sometimes its a faulty hard drive
Try reinstalling XP windows again
cheers
May 21, 2015 | IBM Computers & Internet
Air conditioner cools for 30 minutes then stops cooling after 20 minutes starts cooling again what is likely problem
The compressor motor is over heating and thermal protection shuts it down , when it cools down it restarts. Restricted air flow over the cooling coils could be the cause. Check filter,Sometimes furniture or other things block the return air vent.
Aug 27, 2014 | Heating & Cooling
HP 620 laptop shut down and won't start
When the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a small brush and can of compressed airto do this.
Mar 24, 2012 | HP Computers & Internet
When i am ueing the lop top it get hot and shut down i have to wait antill it cool down before it start up again
it sounds like your cooling fan has stopped working therefore the cpu is getting too hot to work and will shut the system down have the cooling fan looked at
Oct 29, 2010 | Compaq Presario CQ60-220US PC Laptop
My laptop getting heated after 10-20 min when i start and it automatically turnoff after that.
Your laptop could be overheating and the CPU shuts down and won't boot up again until it has cooled down.
This is most likely caused a a faulty fan or dust clogging the fan and heat sink. please click on this link and follow my instruction to fix this problem :-
Normal 0 http://www.fixya.com/support/r5959377-overheating_computer
Oct 25, 2010 | Toshiba Computers & Internet
Kenmore Gas Dryer Gets Hot, Shuts Off Early in Cycle
Sounds like a faulty high limit or cycling thermostat. The thermostat tells the dryer to heat until the interior of the dryer reaches a certain temp. It should be mounted on the exhause duct inside the back of the dryer. It should look something like the one in the picture:
Hope this helped and best wishes.
Jul 27, 2009 | Dryers
Blinking AC light with/without battery, computer shuts down
I want to try a very simple thing, cause it happened to me, while I am working on my computer , it shut down unexpectedly... cause the processor is working with its full performance and no enough cooling around the laptop. so while I move to other place and also I raise the laptop a little bit from the back to let the fans (bottom of the laptop) works perfectly .
try to open it again and do so.... may be it is a so simple thing that was far from your mind like I was before... good luck
Nov 29, 2008 | Toshiba Satellite A135-S4527 Notebook
Crash!!
Could be Heat, sounds like the system is shutting down to protect the processor. Let it sit shut down over night and see if it runs longer when it's cooled down. Is the fan running?
Aug 29, 2008 | Acer Aspire 5315 Notebook
Toshiba Satellite A135-S4527 Notebook Logo
430 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
