Question about Polar M32 Heart Rate Monitor Watch
Chenge the battery
I have own my polar heart rare monitor for 3 years I need to change the battery how ?
  • Wasilij Jan 22, 2009
    I'm sick and tired of sending in my Polaar heart rate monitor + chest-strap transmitter to have the batteries changed - and paying a fortune for the favor. I've changed the battery in the waatch with no problem, but how do I get the belt open?
  • Anonymous Mar 25, 2009
    I want to change the battery in my f6 myself, how do I get the old battery out of the caseing?
  • 56 Answers
Response to Wasilij: The belt is sealed, so it can be used while swimming. It's not meant to be opened. They replace the whole thing, instead of replacing the battery. So sorry, not going to work.
Posted on Jun 11, 2009
Changed the battery and now it won't pick up the heart rate monitor. I know the monitor works because it is picked up by all the equipment in the gym.
If Heart Rate is being displayed on the equipment in the gym, but not your watch, then your chest strap is transmitting fine, but the watch is not recieving the signal.
It is not uncommon that when a battery is changed outside of a polar authorized service center that something can happen to the internal electronics. I would suggest you send the watch into Polar and have them take a look. if you have had the watch less than 2 years they will most likely take it under warranty and correct the issue, at the very least they have equipment to test and diagnose both the watch and strap, although it sounds like your HR strap is fine since you are getting HR on the machines.
Dec 27, 2010 | Polar FT40 Heart Rate Monitor Watch
I just put a new battery in the Polar F4 heart rate monitor watch and it does not work. The battery died about 2 years ago and I never replaced it until now. How can I get the heart rate monitor working...
This is a common issue. The Polars and other Heart Rate monitors are not designed to be fixed by the consumers except for very specific models. These only look like watches, they are in fact mini computers and very susceptible to internal damage if not handled properly.
You need to send the unit it to a Polar Authorized Service Center to have fixed properly. There is not reset within the computer, if you had done everything correctly then it would work.
Dec 12, 2010 | Polar F4 Heart Rate Monitor Watch
REQUIRE MANUAL FOR F4 C716G00457925 MY BATTERY HAS BEEN CHANGED.BY POLAR . AND HAS WIPED ALL SETTINGS. NEED HOW TO USE GUIDE
For all those who lost their Polar Heart Rate Monitor manuals. Follow this link, fill in the details and get manual. Plenty of other Polar product info and support on this site.http://www.polar.fi/en/support/downloads?product=&category=User+manuals
Nov 22, 2010 | Polar F4 Heart Rate Monitor Watch
How to change battery
mcdevito75 here, Battery change is once every year or so, even if you changed thr battery now, you"d forget next year, I know I did. BEST BET, look for a small watch repair shop in your area for the peace of mind. Approx. cost, $10.00-- $15.00
Oct 26, 2010 | Polar FS1 Unisex Heart Rate Monitor Watch
Battery in a Polar F7 heart rate monitor
Hello
You can change the battery in your polar f7 if the battery is worn out.
1. Insert the tip of a pen knife into the lifting point and lifting the back up. The back of the watch is only pressed into place and will come off easily this way.
2. Grab the small clip that is extending across the surface of the battery with a pair of tweezers. Slide the tweezers toward the end that hooks down into the watch. Pull the hook end of the clip out of the watch and remove the clip from the battery
3. Match the old battery with a new one at any electronic store. The store will be able to read the writing imprinted on the battery to make sure that you get the correct battery type for your heart monitor.
4. Press the new battery into the watch making sure that the writing on the battery is facing up.
5. Press the holding clip back into place. Handle the clip with tweezers only, since it is very thin and can be bent or lost easily. Once it is in place, press the back of the watch on.
GOODLUCK
Jul 15, 2010 | Polar FS1 Unisex Heart Rate Monitor Watch
New battery needed and fitted to a Polar heart rate monitor
This is really easy to do yourself. Get a CR1632 battery, unscrew the four screws on the back (dont tip the watch as there is a small spring in the watch), unclip the metal band holding in the old battery noting the way 'round the battery is in (minus side up), pop in new battery and push clip back down, when re-fitting the back make sure the spring mentioned earlier lines up with the white sticker with a hole in it on the inside of the watch back, screw down the back. After you have re done all your settings you may need to re-aquaint the watch with the strap, to do this put on the watch and strap, set the heart monitoring going, bring the watch up close to the 'Polar' logo on the chest strap until the time is displayed, should now be all set up.
Andy
Oct 28, 2009 | Polar F4 Heart Rate Monitor Watch
How do I change the battery?
Someone posted a link on how to change the batter on an F11. If it's not longer under warranty or you just don't want to bother with sending it back and the extra costs, you could follow this: http://timlaqua.com/2008/09/how-to-replace-the-battery-in-a-polar-f11-heart-rate-monitor-hrm/
Jun 10, 2009 | Polar M32 Heart Rate Monitor Watch
Need instructions for use of Polar Heart Rate Monitor A1
Paste this link into your browser and download manual:
http://www.polar.fi/en/support/downloads?product=&category=User+manuals&documenttitle=User+Manual+for+A1+in+English&document=/gip/PKBStoGIP.nsf/web_cat/C225742500419A8A42256A670036F49C
Do not forget to rate, please.
Jan 22, 2009 | Polar Watches
Polar M32 Heart Rate Monitor Watch Logo
584 people viewed this question
Top Polar Watches Experts
Jerry Greenberg
Jerry Greenberg
NOEL
NOEL
David Payne
David Payne
Are you a Polar Watch Expert? Answer questions, earn points and help others
