Question about Fantom Vacums FM741 Twister Bagless Upright Vacuum
Sweeper wont pick anything up. When the motor runs it sounds like the belt is broke, but it is not. It revs real high. There are no clogs and the filters are clean. I have no idea what it is, and I can't find anybody local to fix this thing either. I really don't want to throw it away. I love that sweeper. It worked good for about 5 years and now it just won't pick anything up. I went over it with a fine tooth comb. Any suggestions? Fantom Twister fm741h Thank You
    Genius:
  • 1,075 Answers
To me it sounds like a blockage?having worked on these machines for so long,when the motor runs high as you say then its under pressure im not convinced you have cleared the blockage take another look ,i use a old wire coathanger straightened out to push the rubbish out,if that fails,go out and buy yourself a new machine you derseve it and you will be surprised at what the new machine can do..adrian,,,,
Posted on Sep 06, 2010
2013 Oreck Vacuum . How can I check to see if it is stopped up?
If it scatters the dirt then it's definitely clogged up at the nozzle just behind the roller brush. Turn the sweeper upside down and stand it on the handle. Then look under the roller brush. I have two Oreck's in my house. You can take a screwdriver to loosen the clog and dump out the dirt. Don't try to pick up pine needles as these are sticky and will quickly clog up any vacuum sweeper.
Dec 29, 2013 | Oreck Vacuums
Is there a wrong way to attach the belt and the sweeper?? My Hoover Runabout is making a rubbing noise, like the sweeper is hitting something, and it's real hard to push.
take off the belt . clean any hair from brush roller make sure movement smooth . re position belt and move by hand to make sure roller is not skew , , rubber is riding sideways and causing friction .
Mar 22, 2012 | Hoover Vacuums
MY VACCUUM HEAD WAS CLOGGED I REMOVED ALL GUNK FROM AROUNG ROLLERS AND CHECKED BELT IT STILL WONT PICK UP HELP
check to make sure the filter is clean and also check for a blockage in the hose where it bends down to the floor sweeper, ( use a bent coat hanger to clean out any blockage in the hose ).
c...
Jan 28, 2011 | Vacuums
My sweeper won't pick up anything could the belt be broke
It may be broken or it may be stretched. Belts can become stretched and will lose elasticity.
Jan 26, 2011 | Hoover U59 WindTunnel TurboPOWER Bagged...
I have fantom FM741H It sadenly stop working. I checked plugs,circuitbraker. They are Ok. What is possible problem? Thanks
I have the same sweeper as you. I have had this sweeper over 10 years. I purchased it from HSN. Model fm741h. Ok here we go. I paid 299. for it 10 years ago. It worked perfectly. Picked up all sorts of things. It stopped working about 5 years ago. I kept it hoping I could get someone to go over it with a fine tooth comb in my area. No one worked on them. So I still kept it. Just today 09/4/2010 I was looking at it. I decided to start taking the whole unit apart. I come to find out all the filters are clogged. I have never replaced them or the belt. The belt was fine, the motor runs, but its just not picking up anything. So inside the canister was caked with dirt. I mean literally DIRT. Inside the part that spins is another filter. I checked the prices on those. Anywhere between 23.00 up to 50.00. So I took a toothbrush and ran it under hot water. Scaped off all the dirt, let it dry and presto....I have my TWISTER back. YIPPY!!! I can't see spending that much on a filter when all you have to do is scrape the dirt off of it. Works perfectly. Now that I know what to do....I'm a happy camper.
May 10, 2010 | Fantom Vacums FM741 Twister Bagless...
Sweeper Brush doesn't turn.
Could be that too much hair, string, or long fibers have been collecting around the roller. Remove it and clean it off. Also check the duct behind roller that goes up into the connection hose. Ther most likely is some sort of blockage.
Nov 20, 2009 | Dyson DC14 All floors Bagless Upright...
It wont pick up dirt and motor is very loud it was clogged but cleared it still loud belt is fine
check impeller that is the part that creates the suction in a vacum if impeller is broke that will make the vacum loud and vibrate
Oct 17, 2009 | Bissell 3910 Bagless Upright Cyclonic...
No suction
You have a clog somewhere in the vacuum. Check the hose and the little trap door on the underneath side of sweeper.
Does the brush turn? If not, then the belt that drives the brush is broken. Replace the belt
Jim
Jun 08, 2009 | Hoover Tempo Widepath Upright Vacuum -...
Roller brush doesn't turn
Sounds like the belt is maybe slipping did it brake the new belt as well?
Mar 10, 2009 | Vacuums
Dirt Devil Swivel Glide
look on the underside where the brush roller is and unplug it first then try to turn the brush roller by hand,if it turns real freely the belt is broke.you might have a clog at your intake hose at the bottom its the clear looking hose that goes from the bottom and comes up the back.if the belt is broke before you put a new one on clean the motor shaft there might be some old belt rubber on it ,otherwise the new belt won't last
Jan 03, 2009 | Dirt Devil Featherlight Bagless Upright...
Fantom Vacums FM741 Twister Bagless Upright Vacuum Logo
141 people viewed this question
Top Fantom Vacums Vacuums Experts
Billy Detlefsen
woodzowl307
Are you a Fantom Vacums Vacuum Expert? Answer questions, earn points and help others
