Question about Compaq Presario CQ60-220US PC Laptop
Screen light goes on then dims so low you cannot read
  • 2,567 Answers
Try attaching an external monitor to the laptop & see if you could get any display on it. If this is successful, then you might have either a faulty LCD cable or screen inverter board.
The LCD cable transfers data signal from the motherboard & video card to the LCD screen. It also supplies high voltage DC power to the screen inverter board. The screen inverter board works as a power supply for the backlight lamp mounted inside the LCD screen. It converts low voltage DC power to high voltage AC power needed for the backlight lamp.
Posted on Sep 06, 2010
Driver side headlight goes dim on high beam while passenger side is bright
bad connection or bad earth check all connection or bulb
Jan 24, 2016 | Cars & Trucks
What would cause instrument and radio light to dim
With the lights on auto, the dash will dim when the lights go on, based on the dimmer setting. If it's set low [wheel] they will be really dim. If it's light outside it will be hard to read. there are not many other causes other than a low battery or bad alternator.
Jul 29, 2014 | 2004 Buick LeSabre Custom
Screen goes dim
It sounds that its back-light have a problem. Check its back-light CCFL lamps, and back-light inverter board.
Apr 27, 2013 | Sanyo Televison & Video
I have a 2008 f250. one headlight (driverside) low beam is not working. I have checked both fuses 10amp and they are good. The flash to pass works and both lights on bright, right and left come on. the...
I am sure that a 12 Volt bulb means it needs 12 Volts. Since you changed the bulb to the other side, why not check the voltage in the working side and see what it reads?
Sometimes the turnstalk can interfere with the lighting. Try pushing the Hazard switch several times and see if the headlights straighten out. I read that too much goes through the turnstalk and that using the Hazards can derail a contact inside the stalk.
If this does not help, you may need a headlight relay in the powerbox. One contact may be dirty or burned down for the wire it feeds. Unless you have a single wire feeding both low beams to the headlights, I would bet the left and right side come out directly through the relay.
Oct 20, 2010 | Ford F-250 Cars & Trucks
Dell screen goes black , after 2 seconds but when low down the brightness it work good it not goes off , but it is very low brightness and difficult to read text some time ,
but when low down the brightness it work good it not goes off , but it is very low brightness and difficult to read text some time......WHAT?
Can you explain in a bit more detail please...I don't know what you mean by.........
'when low down the brightness it work good'?
But try holding down the FN key on your keyboard & tapping the 5fc1ca0.png Button that alters the brightness.
Sep 04, 2009 | Dell InspironTM 1501 Notebook
Left low beam is dim
The mechanic didn't hook up the ground wire. The system is using the other light as it's ground and when this happens it causes the other light to go out.
Check the ground wires
Aug 24, 2008 | 2005 Chevrolet Malibu
SIR-PNP3
When mine goes time I squeeze the radio downward into the cradle and it lights back up.
Might be a weak connection. I'll have to hit it with contact cleaner sometime to see if it helps.
Aug 06, 2008 | Audiovox SIR-PNP3 SIRIUS Radio Receiver
LCD goes dim within 1-2 minutes
You could have a bad "inverter" or flourescent backlight tube, or a problem in your power supply.The only way to isolate the problem is to check each component in sequence.If your hard disk and DVD / CD drive are still working when your screen goes dark, then I'd say it's the "inverter". You'll have to take it to a repair shop.
flipbooks
Jan 20, 2008 | HP Pavilion dv6000z Notebook
Compaq Presario CQ60-220US PC Laptop Logo
98 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
