If you are getting a "shadow" behind the text or image it is probably your fuser that is causing the problem. Anytime you see a double image or the print is smearing the fuser (aka fixing assembly) is to blame. You can troubleshoot the problem to see for sure before calling out a technician. Send a one page test print job to the printer. Open the rear "output" tray so that the print job exits the rear of the printer. Watch the paper as it is pulled into the machine. When you see the leading edge of the print exiting the printer open up the front door of the printer. This will of course cause the machine to jam up but its worth it. Carefully remove the toner cartridge. Look at the print on the page still inside the machine. Do you see the same grey image? If not then the problem is the fuser. If you do see the grey image then the problem is the toner cartridge. Stopping the print job in the middle of the printer like that allows you to see what the image looks like before it goes into the fuser. If the fuser is the problem call a tech. It is about a $100 - 150 repair for the fuser depending on the labor rates where you live.
use a 9volt battery and grab only speaker wires only and touch them to the 9vt battery this will tell witch speaker is witch. for mor help please call 419 689 1114 for futher assistance i will be more then happy to help you
This usually happens when the cam is still being used by another application. Go to Task Manager and see if windows live messenger is still running. If so close it in Task Manager then try to run the cam again in yahoo messenger.
Hi.. I think you have solved the problem yourself... replace the adapter with a memory stick... You have eliminated the micro sd card as bad... now try a new known good memory stick..
Its an error code and shows problem of Lens mechanism. Lens focus / zoom motor is stuck that's why camera gives out of focus image. You need to replace Lens Assembly and it would cost you more then camera worth.
This is new.
I see that according to the illustration, there is no Optical Viewfinder- thus you need the the screen to compose the images -
Is this correct?
As this camera is new to you carefully read up the instruction manual - especially the set up routine.
If after a day or so you are still in trouble - take it back to the store for replacement.
Do not interfere with the camera.
