Question about Poulan Garden
I have a Poulan BMV200 VS blower/vac - had it for about 2 or 3 years. Recently it will start and idle properly at half-choke position, but dies when I move it to "run". I cleaned the filter, housing, replaced the fuel filter, tried it wit the fuel cap on and off, and nothing worked. Any ideas?
SOURCE: Poulan wt200 "wildthing" gas leaf blower
no compression wont start
Posted on Oct 16, 2008
  • 49 Answers
SOURCE: snow blower is running sluggish with the choke in the on position
It sounds like you my need to rebuild and clean the carburator. Or you have an air leak between the carb and the cylinder.
Posted on Jan 29, 2009
SOURCE: craftsman 32cc blower stalls
Your carb is leaning out, causing the thing to die. Try adjusting the mixture screw (out) to richen the mixture. If there is a cap, you can pull it off to go richer. If that doesn't work, either the filter/pickup is plugged, the fuel line is kinked/smashed, or the carb needs to come apart to be cleaned.
Posted on Jun 12, 2009
mindreader
  • 578 Answers
SOURCE: I have a homelite model uto8550 26cc mighty
1. check fuel filter in gas tank (for clogged condition).
2. Check carb jet for dirt (squirt carb cleaner in jet and fuel inlet
Summary: your carb is not getting enough fuel to mix properly with constant air flow. Therefore, fuel supply needs to be cleaned... then you will run happy!!
-Jim
Posted on Oct 23, 2009
SOURCE: Engine will not reach full operating speed, needs
Need to replace exhaust? Are you for real? Guru of what? Asinine answers?
Posted on Nov 23, 2009
Blower only runs with full choke. When I switch to half choke, it dies and won't start.
it may simply need the high speed jet opening up a bit (2 screws near eachother on the carb and the high speed is furthest from the engine)
failing that it needs a carb kit.... this is a serviceable item changed regularly.
Mar 14, 2011 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
It will run good on half choke but dies when it is put on run
You will need to a Poulan Tool and Adjust the Carb. There will be 2 round nobs on the top of the Carb. You can get those tools at any Lawnmower Repair shop for a few buck. Be sure to Take your machine in and show the guy because there are different nobs on different Carbs. If you own a Poulan you will need it all the time anyway. LOL Good Luck!!
Oct 23, 2010 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
POULAN FEATHERLITE LEAF BLOWER WILL ONLY RUN AT 1/2 CHOKE
Sounds like you will need to clean your carburetor, or rebuild it. Could be some debris in the jets of the carburetor. If the blower is over a couple years old, then I also recommend that you buy and install a new carburetor repair kit, because the diaphragm will get hard and that will cause it to be hard to crank and not run at full speed. Hint: When you clean your carburetor and remove the jet screws, count the number of turns it takes to seat the jets from their original position. That way when you go to put the jets back in, you know how many turns they were in/out. Please rate me, Thanks Good Luck, I hope this helped
Jan 05, 2010 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
Craftsman blower stalls when choke is disengaged
You need to play with the timing adjustment, either on the spark plug, or the gap between the contact and the magneto.
That'll do it ;)
Don't forget to rate, thanks
Jul 31, 2009 | Craftsman 4 Cycle Blower/Vac
I have apoulan 446t pro I can get it started with it full choke but it will die as soonn as I try to turn the choke off what should I do
how long will it run on choke? the newer equipment are jetted really lean to comply with EPA requirements. it should run once it warms up.....if not the air fuel mix needs to be richer.
Jul 05, 2009 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Poulan weedeater will only run with choke half way on
this could one or a combination of a few things
1 check inside the tank for dirt 2check that the filter screen inside the tank is not plugged3 make sure the gas feed tube is not restricted pinched in the case or kinked also you can try a simple carb adjustment.also check to make sure the plug is gapped to the right specs good luck and i hope one of these suggestions do the trick
May 02, 2009 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Garden Logo
164 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
