Question about Fisher and Paykel Washing Machines
Gw712 washing machine....no cold water supply through solonoid
    President:
  • 3,773 Answers
Remove the cold water fill line at the back of washer and put it
over into the tub and turn it on if you have plenty of water
then you need the valve that it screws onto.
If this was helpful please rate me.
IMUFO2
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Posted on Sep 06, 2010
GW712 - cold wash selected but water runs warm. If hot water supply turned off, machine stops?
The cold water temp has been adjusted to a warmer temp,
Move the led back to the first led light with advance button.
Jul 01, 2012 | Fisher and Paykel GWL11 Top Load Washer
No cold water when trying to use it nothing
Your cold water solonoid is not working and needs to be replace. Very easy fix. Just follow the cold water supply tube and you will find it connected to a plastic mechanism with a couple of wires to it. Most of the time the hot and cold solonoid are together and you need to replace both at the same time. When installing make sure you test for any leaks. Good Luck
Jan 07, 2011 | Maytag Atlantis MAV6451 Top Load Washer
No water going into the machine
Assuming the supply is ok replace the cold fill solonoid valve
Apr 06, 2010 | Whirlpool GHW9400SU Front Load Stacked...
Zanussi 1050 washing machine will not fill with cold water . Cold water hose replaced because of a leak in old hose but machine will not now fill
Assuming water supply to machine is okay and no kinks in the hose Then its the solonoid valve that is faulty and needs replaced
Apr 01, 2010 | Washing Machines
My hotpoint washing machine does not rinse properly it still has washing powder on it , what could this be
It could be that your cold water solonoid is at fault. Also is water pumping out ok at end of cycle? this often happens and machine will keep same water in all way through. If you put machine onto a rinse only this will then fill with cold water, if so then that will rule out solonoid problem.
Feb 12, 2010 | Washing Machines
GW712 Fisher & Paykel Washer. Cold water will not fill the machine only a trickle. Taps, water temprature and hose working correctly.
THE INLET VALVE FILTER COULD BE BLOCKED TURN WATER OFF UNDO PIPE AND CHECK IF NOT COULD BE A PROBLEM WITH VALVE ! IS YOUR WATER PRESSURE OK
Jan 11, 2010 | Washing Machines
F & P GW712 - bowl spins, but won't fill.
Read your user manual - but I would suggest that you may not have setup the balance properly. Check the level of the machine and adjust to be as square as possible by adjusting the feet at the bottom. If the water isnt coming in on both hot and cold sounds like a common problem - perhaps the water level sensor is playing up or something else has been knocked during transportation of the machine when you moved house. Check your user manual for troubleshooting. Sounds dumb, but check that 'delay start' isnt selected also. check both hoses filters are not blocked.
Sep 21, 2007 | Fisher and Paykel GWL11 Top Load Washer
Washing Machines Logo
175 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
