Question about Frigidaire Affinity ATF7000ES Front Load Washer
ATF7000es E10 fault
Getting an E10 error which I am unable to locate in the manual. It seems to be associated with the door lock, if I apply pressure to the door while washing it goes through the whole wash cycle. We have already replaced the door latch and main brain about six months ago. Do I need to hire a lady with a big **** to lean on my machine or is there a better alternative??
  • 1 more comment
  • mirwin726 Oct 05, 2008
    I am getting error code 10 also. Did this solution work for the other people with error code10??
  • Anonymous Oct 06, 2008
    It seems to only run through the normal cycle and shows e10 on ALL other cycles. I HATE THIS WASHER. It is making a nice grinding noise as well when it starts to drain.
  • Anonymous Oct 10, 2008
    Same problem, Frigidaire repair guy came to look at it but , I been waiting for new latch for 3 weeks.
    Sergeant:
  • 225 Answers
Hi - it sounds to me like the door latch needs adjusting or tightening up. It's probably something really simple like a loose screw. I must have plenty of those to be spending my time here :-)
If these suggestions do help you solve the problem, please give my reply a rating to help others judge my knowledge / guessing skills.
If they do not, please hold off on the rating and add a comment with more details so I can try to help you further. Cheers, D
Posted on Jul 12, 2008
I keep getting a error code E10 despite replacing numerous parts on my GE model GFWH2400L0WW front load washer.
this code came up after the door latch was replaced ? did the old part number and the new part number match as they switch over the switching in the switches on different models.also the locking device that locks the washer is the big round valve that has a pipe feeding from the bottom of the drum. its also the the water level sensor tells the washer were the washers water level is. this also has an amount of resistance that tells the door to lock. if its blocked it will either overfill washer or not allow the door to be unlocked. in turn you break the lock off. if you put a new lock on and not fix this part the door will not lock or start.
Feb 15, 2018 | GE Washing Machines
What does error F:16 indicate?
no one will know without a MAKE and MODEL.
Dec 26, 2015 | Washing Machines
Frigidaire washer door
Hi Ryan C - From what you have described since you have already replaced the door lock assembly, you may possibly have a communication error with the control panel not responding.
Sep 20, 2012 | Frigidaire Affinity ATF7000ES Front Load...
Stirling XQG65-908E. We keep getting an E10 error and would like the instruction manual as we have misplaced it
Unfortunately, that particular model of washing machine has been completely discontinued and is no longer supported at all. Cheap imported brands / models like the Aldi Stirling machines are seldom provided with useful documentation even right from the factory in the first place, and so finding electronic copies of that documentation online afterwards is often an impossible task.
Furthermore, you would not likely find the information you are looking for in any standard Owner's Manual anyway.
ERROR CODE definitions and the associated corrective action procedures are normally only found in the Factory Service Documentation provided only to Factory Service Technicians and Authorized Repair Facilities. These special Service Instructions are normally closely protected documents not readily available to non-authorized personnel and ordinary customers.
I'm very sorry if this is not helpful to you, but what you are asking is more of an Appliance Service Call than a simple User's Manual request.
However, I will attempt to contact the previous distributor (Tempo Australia) to see if anyone there can still provide the instructions for clearing the E10 Error Code on that model, as well as a diagnosis of what possibly caused that fault condition in the first place.
Often times with these machines, the fault code is the result of a BLOCKED FILTER inside. You can usually find the filter located behind the lower right hand panel on the front of the machine, below the door.
Just turn off and unplug the power cable to the machine, then access the filter fitted in the location described above, and be sure to clean it out thoroughly. After waiting about an hour with the power disconnected, plug the unit back in and then test it out.
If the error code is still present after this procedure, then the fault is almost certainly something more significant and you will likely need the services of an on-site appliance technician. As always, I would recommend purchasing major appliances only from reputable and established name brand dealers who are able to provide reliable service and product support if ever required. They are certainly more expensive initially, but they are almost always more reliable and worth the money in the long run.
Please COMMENT back to this page if you have any questions or comments and I will respond back to you as soon as I see them.
As I said I will continue to search for the information you need and will post it here if I locate it.
Truly, my sincerest apologies for not being able to assist you more today.
Take care.
Joe.
Oct 01, 2011 | Washing Machines
I am getting a EFO then E10 error message after I start a load of clothes...which means I have to cancel the load.
E10/EFO error code is an indication of a slow fill, took to long to fill, no fill or the fill water could be siphoning out the drain hose as it's filling with water.
Check to make sure that the drain hose is not stuck too far down the stand pipe and causing the water to siphon out. Check the cold and hot water supply to the washer for any restrictions. If you have a slow fill remove the hoses from the washer and check for restricted filter screens in the water inlet valve. Check for any restricted hose screens too.
Feb 07, 2011 | Frigidaire Affinity ATF7000ES Front Load...
Error code E10 what is it
When error code E10 appears just take the cold water off the inlet tube to the washing machine, then clean the screen using light force air then replace the hose .Finally turn the water back on.This should solve the problem. If not the door latch needs adjusting or tightening up. It's probably something really simple like a loose screw.
Thank you !!
May 31, 2010 | Frigidaire Affinity ATF7000ES Front Load...
E10 code on a zanussi jet system washer
Is it a washer-dryer? E10 relates to a fault with the inlet valve.....usually the valve itself going open circuit.
Feb 26, 2009 | Zanussi WJS1265W Front Load Washer/Dryer
I am experiencing an error code during my wash cycle of E10... I have a frigidare affinity series washer.
Clean the cold water filter on the back, then try again. This should work. Mine was doing the same thing and the repairman had no idea what it meant.
Jan 08, 2009 | Frigidaire Affinity ATF7000ES Front Load...
I have a Fridgidaire Front Loader Washer _ Affinity. It has an error message flashing. E10. What does that mean? What do I do to fix it?
I have a Fridgidaire Front Loader Washer _ Affinity that flashed the E10 error code. I also had the problem with the fabric softener dispenser not emptying, and staying full of water. The problem was the cold water filter on the back of the washing machine that was semi-plugged. Cleaned the filter and now works perfectly. My machine is no longer flashing the Error code 10. The dispenser works perfectly.
Oct 05, 2008 | Frigidaire Affinity ATF7000ES Front Load...
F5E1 error
Whirlpool-KitchenAid-Roper Appliances: Oven Fault Codes:
>>Exception Note:<<
Chart below does not apply to Whirlpool Models using the "Y" line in the products model numbers. Applies to models using 4 digit displays only.
F0-E0 Analog to Digital failure
Disconnect panel for 30 seconds
Should the above error re-appear, replacement of the control is required.
F1-E1 Defective ERC Replace ERC
F2-E0 Shorted Keypad Replace Keypad
F3-E0 Sensor or Sensor Fuse Open Replace Sensor or Fuse
F3-E1 Shorted wire or Sensor locate short and correct it or replace Sensor
F3-E2 Oven over heat Replace Sensor
F3-E3 Cleaning Temp over heat Replace Sensor
F5-E0 Door Error Check Door
F5-E1 Door Latch Check Latch
F5-E2 Door Switch Check Switch
May 11, 2008 | Whirlpool RF378 Electric Kitchen Range
Washing Machines Logo
210 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
