Question about Alpine MRD-M501 Car Audio Amplifier
I need a bass boost knob for my alpine mrd-m501 amp. Anyone know where I can find one????
Cerfer39
  • 709 Answers
SOURCE: alpine mrd-m500
Hi SPDGOD,
Could not find exact, but close manual.  It is the MRP-M450 mono block amp from alpine.
Go to this url and view in Adobe. Print it if you need to
http://vault.alpine-usa.com/products/documents/OM_MRP-M450.PDF
Posted on Oct 19, 2007
  • 631 Answers
SOURCE: alpine mrd m500 amp is not pushing my 12 in infinity sub
If you have a dual voice coil sub, make sure that you have the positive and negative terminals connected properly. If you have ONE of the coils wired backwards, it will cause the speaker to produce little or no sound.
Have you set the gains properly?
Are you sure the amplifier is receiving a strong signal from the head unit?
Have you tried it with a different speaker?
Posted on Jul 19, 2008
  • 35 Answers
SOURCE: Alpine MRD-M1005 Subwoofer Amp Problem
He may be right! You might try finding a new source of contact for your ground cause it may not be sufficent enough to ground to, also make sure that no wires from the back of your radio have any wires sticking out touching other interfering things that could possibly be causing the noise
Posted on Sep 16, 2008
SOURCE: alpine mrd-m501 amp
the subs cant handle all the power you got it set on turn off all the settings and then turn off your car and remove your face plate and then it should be ok. it does that because the subs cant handle the settings you might just have them a lil high
Posted on Mar 17, 2009
  • 13 Answers
SOURCE: no sound on my alpine mrd m501
 No sound is produced. ? The output disable mode is turned on. ? Refer to the instructions at ?Output Disable Mode? to turn the output disable mode off.
Posted on Jun 10, 2009
WHERE CAN I GET A BASS KNOB FOR ALPINE MRD-M1001
Any AUTHORIZED DEALER of this Product Although this Spacific Part May NOT be Available, Not EVEN From Manufacturer.
May 12, 2010 | Alpine MRD-M1001 Car Audio Amplifier
So I have two alp mrd 501 amps one in each car both amps shut down ( clips ) while driving I have rolled back the setting still happons ?
Well it sounds like the safety switch is turning on. Which means it turns off. If you could clarify that would be awesome and i'm sure i or someone else could answer you better
Mar 01, 2010 | Alpine MRD-M501 Car Audio Amplifier
Broken alpine amp terminals
THAT USEUALLY MEANS UR AMP IS WAY 2 POWERFUL FOR UR SUBS
Feb 10, 2010 | Alpine MRD-M501 Car Audio Amplifier
How to unlock my alpine mono power amplifier mrd m500?
Hi. If you shorted (touched) the speaker wires together, or let them touch the chassis of the car, then it may have locked out. Just turning the amp off and back on will fix this, so it sounds like you have done damage to it. Most amps have a speaker relay which gives a click sound when you turn on. If there is no click, then it may have a power supply failure.
Mark
Oct 24, 2008 | Alpine MRD-M501 Car Audio Amplifier
Sep 14, 2008 | Alpine MRD-M1005 Car Audio Amplifier
Alpine mono power mrd m500 amp
Try switching the lowpass filter down to 80hz or lower, then adjust the bass boost to your liking.
Jun 28, 2008 | Car Audio & Video
Alpine mrd-m501 amp
Disconnect the speaker wires from the amp, then try it again. If the error message doesn't appear, try connecting the speaker wires back to the amp one by one.
The error message is due to some sort of overcurrent in the amp. If the error does not go away when the speaker wires are disconnected, the issue is most likely with the amp itself and will need professional repair.
Mar 18, 2008 | Alpine MRD-M501 Car Audio Amplifier
Alpine mrd-m501 mono power amplifier
OK, It looks like you may have an internal problem. I must say from the begining if you do not have a background in electronics take the unit to a qualified service center. Now it sounds like you could have a power supply problem if you have power coming in onpen the unit and with the use of a schematic find the main voltage rail and test from there each test point and make sure it matches the schematic value. Look for burnt circuit tarces nad if you find the remove them and jumper with re-trace wire.
Sep 15, 2007 | Alpine MRD-M501 Car Audio Amplifier
Error codes
One of the parts went bad, and you need to take it into the dealer. The way Alpine's error codes work are very vague. E-3 could mean the psu fried, a resistor went bad etc.
Aug 12, 2006 | Alpine MRD-M501 Car Audio Amplifier
Alpine MRD-M501 Car Audio Amplifier Logo
80 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
