It doesn't work. I have a intertherm model # WA 1000-2 electric wall heater in both bathrooms. A tech manual or troubleshooting manual would be great.
4 Suggested Answers
ngafm
  • 166 Answers
SOURCE: I have a bathroom electric
Discount Parts Major Appliance & Consumer Electronic Parts. TOLL FREE 1-(888)-338-3790 8:00AM - 12:00 MIDNIGHT 7- DAYS A WEEK
Posted on Sep 05, 2008
  • 1253 Answers
SOURCE: I bought this wall mount
In general, if it has a heater element, examine it carefully. It has to have a voltage and wattage or amperage rating on it somewhere. I would start there. I would also have to lean towards the wiring diagram. It should show 2 lines of power, usually L1 and L2, and a ground and possible an neutral. Hope this is of some help. Let me know if you need more and I will dig a little deeper for you.
Posted on Jan 29, 2011
  • 643 Answers
SOURCE: I need to wire a
Run the wire to the thermostat then to the heater
BASEBOARD WIRING WITH A SINGLE POLE (2 WIRE) WALL THERMOSTAT - 120V OR 240V SUPPLY
BASEBOARD WIRING WITH A DOUBLE POLE (4 WIRE) WALL THERMOSTAT - 120V OR 240V SUPPLYdennis675_0.gif
Posted on Jun 21, 2011
Where can I get a blower motor for old Intertherm UCG-1000-7 baseboard heater?
I also have a UCG-1000-7 heater from 1978 in the bathroom next to the floor. The last two nights have been quite cold for our area and for some reason the unit comes on once about 3:30AM even though it's turned OFF. We then turn it on to full then back off and after cooling down it shuts off ok. We pulled it out and opened it up. All looks OK except for 38 years of dust which was extreme. We dusted good and put it back in the wall to see if that helps. Any ideas why this may be coming on in the middle of the night? Thanks for any help. You can also email me at pismodise@gmail.com. my name is Bill.
Oct 07, 2013 | Heating & Cooling
My Bradford White Defender M-I-30T6FBN doesn't show igniter button on instructions
1) Copy following links to identify gas control valve and read ignition procedure, and access service manual for your product:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
2) Honeywell gas control used on recent Bradford White gas water heaters has red knob that rotates to pilot. Press and hold red knob. Then push red igniter button until status light changes.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Feb 11, 2013 | Bradford White Bradford MI30T6FBN-337 30...
Had a problem with the thermostat connected to GW-50-4 Wall furnace. One fan is not working at all, the other fan runs continuously even when the furnace isn't running. Is there a control swith or...
Jake, it sounds like the motor coil wiring on the blower that doesn't work may be damaged or has been disconnected.
Regarding the one that is still running. The automatic fan control is located on the bottom of the blower assembly. The fan control is a nonadjustable, automatic type. The fan control will require between 3 and 7 minutes of main burner operation before the fan control "closes" and activates the blower. The blower will continue to run between 3 and 7 minutes after the main burner shuts off, before the fan control "opens" and deactivates the blower. In which case, if it continues to run and run and run, the fan control switch (part # R-2503) may have failed and will need to be replaced. You can order the part from Empire Comfort Systems Tech Service 800-851-3153. Have the Model Number, Serial Number of the heater handy, as well a the Part Number. when you call.
To help you further, I have included a link to the Owner's Manual for that model wall heater. You can download and print it for future reference.
http://www.empirezoneheat.com/assets//EHS/manuals/GWT-%2825,35%29_Manual.pdf
I hope this helped you troubleshoot and solve the problem. Please let me know. Thanks.
Jun 11, 2011 | Empire GWT-50 Wall Mounted Panel Heater
Intertherm baseboard heater model 1580. Need thermostat
Home Depot carries I believe 2 different T-stats , wall mount, and unit mount. Try there. Or you will need to get it touch with the manufacturer. Also have info, 120 or 240 volt.
Mar 06, 2011 | QMark Portable Hydronic Electric Baseboard...
I bought this wall mount heater because I was told it was 120 volt. I opened it up to look at the wiring and found a small wiring diagram that indicates 240 vold input. Which is it? Intertherm WA-1000-4...
Jan 29, 2011 | Heating & Cooling
Can't find replacement parts
Hi google intertherm furnace parts they sell parts on line you may find what you need on there
Oct 22, 2008 | Fahrenheat Electric Convector Baseboard...
Heating & Cooling Logo
241 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
