Question about Sony CDP-CX200 CD Player
SONY CD PLAYER MODEL CDP-CX200. WHEN I TURN THE POWER ON, THE CD HOLDER MOVES SLIGHTLY BACK AND FORTH AS IF IT WAS BOUND UP AND AFTER AWHILE A "Err" APPEARS ON THE DISPLAY SCREEN TO THE LEFT OF THE DOOR.
  • 4234 Answers
SOURCE: Sony CDP-XA30ES CD Player
Try opening up the top and cleaning the lens using a cotton swab and alcohol. If that does not resolve the problem, look at the back side of the optics and there should be a marking like KSS-xxx. This is the generic part designation. Any electronics supplier that supports Sony should have these.
Dan
Posted on Apr 08, 2008
VOTIT
  • 2071 Answers
SOURCE: Sony CDP-C505 door stuck open
The slider mechanism, depending on the age of the unit and the manufacturer, consists of the small chrome rail, a drive motor, a small gear assembly, and (in some units) a small belt that drives the slider unit via the motor. This small belt causes all sorts of problems. If the belt is broken or slipping, it can cause skipping, dropouts, or simply no start up at all. Also, if the belt breaks in the middle of the disc, the drive mechanism gets hair or dirt wrapped up into the gears, or the pick-up assembly doesn’t return to the start position (called home), the unit will (99% of the time) refuse to release the disc, causing it to become stuck inside the unit. There’s a little micro or leaf type switch located at home position that sometimes gets dirty or breaks and, causing this problem also.
If the disc starts to spin slowly and doesn’t come up to speed, the spindle motor that’s attached to the turntable platter is a common problem. There could also be a problem with the spindle motor driver controller IC or the power supply regulator that supplies voltage to the driver IC. If the disc starts to spin and then spins really fast, or stops and starts to spin backwards, your problem is the laser pick-up assembly or the servo control circuit. If you continue to have problems after cleaning and checking the other things listed above, you may have a problem with the player's alignment. Of course, one of the problems you'll face checking alignments on a DVD/CD player is that you’re going to need to use an oscilloscope on most of them. If you have the proper tools and equipment, the first thing to look at is the RF pattern of the unit while its playing. It should be a sharp and clear pattern. If it's dull and smeared, then the laser could be weak.
Also, in these units are very critical alignments called the focus/tracking gains and offsets. When these alignments are off, it can often cause intermittent troubles. As the unit ages and parts change value, so do these alignments, and will need to be checked. In my time as service technician repairing DVD/CD players, 65% of the laser pick-up assembles I have tested were good and only needed a small adjustment. Today's technology makes it unfeasible for a shop to hook up a DVD/CD player, and even some recorders, to their equipment and make these adjustments because of the cost involved.
Hope this may help;
Regards,
VOTIT
DON'T TO FORGET TO RATE
Posted on Aug 17, 2008
cdj repairs
  • 68 Answers
SOURCE: Sony CDP-CX53 rotates the carousel and inserts the CD into the playing position, but it won't play the CD
It sounds like there is a cd tray alignment problem, there is no quick fix, all i could suggest is to send it to us or take it to your nearest dealer.
Regards.
http://www.audiovisualservices.info/
Posted on Jan 02, 2009
  • 35 Answers
SOURCE: sony cdp-c545 won't open
Without turning the unit upside down, look at the bottom of the player. You should see a small round hole toward the front of the unit, with a white plastic part inside with a slot. Take a screwdriver and turn this gear manually with the power off. You should be able to unload the discs by rotating this gear. Be careful not to tilt the unit, as the discs will fall out of the tray, and you'll have to open it to retrieve them.
Once you have the discs out, put in only one disc and see if the unit plays. If you get a disc error, you probably need to clean the lens on the laser. Open the unit, use a cotton swab that has been pre-wetted with glass cleaner to wipe the lens on the laser. Do this gently, don't press down hard on the lens. Use the other end of the swab to dry the lens. Try loading a disc with the top cover off and see if it spins. If it doesn't spin, try turning it by hand. If you can't turn it by hand, the gears have gotten out of alignment.
In this case, use your screwdriver again, noting which way the gear on the bottom of the unit spins when the drawer is going into the unit. Then turn the gear until it "pops" past one or two teeth, and then you should see the laser assembly rise up and meet the clamp assembly on the top of the tray. These are the most common problems with the 5 disc players that Sony made. Many times I could fix them in 30 seconds or less using this procedure.
Posted on Mar 02, 2009
tvservice306
  • 458 Answers
SOURCE: sony cdp-cx235 cd skip
need replaced laser pick up part no:
Manufacturer Sony Part Number 8-848-415-13 Description DEVICE, OPTICAL
Posted on Apr 04, 2010
Sony CDP-CX455 carosel is getting stuck when trying to go to a numbered disc. I hear belt screeching and the carosel goes back and forth a few disc, but not where it suppose to go.
The belt is stretched/worn and needs to be replaced. In some cases an O--ring can be substituted. Got mine at a hardware store that still carries plumbing supplies.
May 18, 2016 | Sony MegaStorage CDP-CX455 400-Disc CD...
Sony CDP CX300...new belts, mechanism gets disk, places it in front of the spindle but the spindle doesn't move toward it and the disk is put back in carousel.
These models often get broken loading parts in front of the pickup assembly. If you could take a good picture of the front of the mech, I may be able to identify what is broken.
Sep 01, 2015 | Sony MegaStorage CDP-CX355 300-Disc CD...
A word Err appears on sony CDP-CX53
The message is its way of telling you it is shot.
Feb 13, 2014 | Sony CDP-CX53 51-Disc CD Changer
Sony CDP -CX200 Arm comes forward to pick up cd but goes back empty. It will not load the disc to play.
Is the second part of the arm clamping the cd? If not then the arm is probably broken and needs to be replaced.
Dec 28, 2012 | Sony CDP-CX70ES CD Player
I need a manual for this model
You may download a copy of the manual here.
Apr 04, 2012 | Sony CDP-CX200 CD Player
Can't erase songs. Followed the directions and still not working.
Sony cdp cx200 sounds like a PLAYER. It won't erase anything. Is the model something else?
Dec 24, 2010 | Sony CDP-CX200 CD Player
Looking for user manual for a Sony model CDP-CX151 100 disc cd player
http://esupport.sony.com/US/perl/model-find.pl?mdl=CDP-CX151&PRODTYPE=33,32,63,71,7,102,26,80,72,44,55,27,74,84,57,61,103,89,10,35,78,48,77,29,50,39,64,58,12,41,81,52,60,73,66,101,45,76,86,62,54,67,70,68,17,2,1,88,100,82,25,28,83,59,69,49,24,104,53,79,42,22,46,13,6,85,36,3,51,9,47,38,4,34,37,43,5
Dec 22, 2009 | Sony CDP-CX151 100-Disc CD Changer
Sony CDP-CX200 CD Player Logo
89 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
