Copiers
Problem for Copiers
Generic problem for all Copiers
Canon Imagerunner C2050 changing toner
By antifog on May 12, 2008
Hi I couldn't install new toners into the machine because it can't get pushed all the way in and be locked. Is there some sort of lever or button I have to push?
Thank you in advance.
Comments:
May 13, 2008
- Hi Cogz. Yup every package removed, colors correct, etc. I concur it should be easy to install, but for some reason, it does not push all the way in. It does seem like the bottom part of the toner is stuck midway. The same goes for all 4 color of toner.
Solution #1
posted on Aug 03, 2009
Not Rated)
josemigo007
Rank: Apprentice
Rating: 0%, 0 votes
I have the same copier and i just took out all the cartridges and cant put them back in, same problem with the same old cartridges
Was this helpful?
Yes
No
Solution #2
posted on May 13, 2008
Not Rated)
Cogz
Rank: Guru
Rating: 86%, 460 votes
Did remove all of the packing off the cartridge before installing the cartridge. Also, is it the right type of cartridge for that you need and or the right color... It should be easy to install if you are installing the right cartridge... Good Luck
Comments:
May 14, 2008
- Come to think about it.... take out all 4 cartridge and see if the trans port unit is installed correctly( look for 2 little blue levers) make sure it is locked in correctly. Then try to close the trans port unint then the front door? dose it close with easy or dose in get hung up. I believe there is aengaging arm that open the covers on all of the toner unit. It may have gotten knocked out of place. Also try to reinstall the old cartridge and if it works??? Then it is the wrong cartridge. The printer is a HP printer on it's own. It may be conpatable??
Was this helpful?
Yes
No
Popular Solutions for Copiers
Questions and Unsolved Problems for Copiers
Answer
What do customers think of the the Toshiba e-studio 5520c, as we are considering buying one?
Answer
conica minolta bizhub 35o vs kyocera in same price range
Answer
ctengo un problema con mi canon image runner 400s: cloe the lower right cover, el problema es que no... (More)
Answer
screen says close finisher door, where is finisher door?
Answer
do you know where i can get a ethernet card for a dsm645 cheap or used?
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Copiers Experts
Top Copier & Fax Repair
(800) 816-6855
Over 50 years in the office equipment repair &...
EBS Scantracker
(877) 434-9747
Full service mobile shredder repair service to...
Pacific Coast Shredder Repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
