About 6 months ago I was cooking pasta on a front burner when the water boiled over. It must have seeped into the electronics below, because the range started to beep. The oven door lock made a grinding sound, and tried to lock the door. The display flashed F8. I finally got it to stop by turning off the power.
I successfully used the self clean cycle once after that.
The other day I tried to used the self clean cycle again, but the door latch makes the same grinding sound and the door will not lock.
When i turn the oven in broil mode the igniter comes on but there dosn't seem to be any gas...
(More)
When i turn the oven in broil mode the igniter comes on but there dosn't seem to be any gas present.had repair man out and he taped on something in the area of the igniter told me the gas valve must have been stuck broiler lit. since then i have tried the same thing only having success once
About a 4 inch square in the center of the broiler does not burn after lighting. We have self...
(More)
About a 4 inch square in the center of the broiler does not burn after lighting. We have self cleaned the over for 4 hours but that did not help. It has been taking a long time to light but we think the igniter is going out since it takes a long time to light. We are replacing that but also noticed the broiler was not cooking even and then noticed that a large square in the center of the ceramic plate was not burning after the broiler lit.
Bought the stove in 2005 when we build our home. Had to have a switch replaced in 2007 to broil. ...
(More)
Bought the stove in 2005 when we build our home. Had to have a switch replaced in 2007 to broil. The stove is not broiling again
when i select bake to preheat oven the bake element does not glo on only the broil burner. then when...
(More)
when i select bake to preheat oven the bake element does not glo on only the broil burner. then when it reaches temperature it does not hold heat.please help. i have replaced the bake element and that did not solve the problem
