Question about Canon MX300 Office All-In-One Printer
Error 5100 from canon mx308 pls help - Canon MX300 Office All-In-One Printer
SOURCE: canon error code 6000 in mx308
please help me. i have canon print mx308. the have paper jams. paper has the full out from print. how i can finish the problems?
Posted on Dec 22, 2009
pineworks
  • 4041 Answers
SOURCE: MX850 - error code 5100 = can you help please.
Hi You can Try
Error Code 5100
Solution 1:
Clean the timing strip.
Solution 2:
The purge cap (the white sliding mechanism that the print head parks to when it's not in use) may be not lubricated well enough .
Lubricate the sliders with some white grease (don't get it on the small wipers or the black caps); this repair probably require to remove the right panel off of the printer to gain access to the purge mechanism.
All The Best: Pineworks
Posted on Jan 28, 2010
jomabug76
  • 1148 Answers
SOURCE: my printer canon mx308 alarm error 5b00 we can't
check canon website they can tell u what error code means
Posted on Nov 04, 2010
  • 412 Answers
SOURCE: Canon PIXMA MP140 Service error 5100
ok... you have to reset the printer --
How to reset the Canon MP150 after a refill (Step 10 concerns refill; instructions below the steps):
Method1 (Safe Factory Method):
1) Disconnect the printer’s power outlet
2) Press and hold the power button while connecting the power outlet back.
3) While still holding down the power button, press the reset button twice.(red circle with a triangle)
4) Release the power button
The printer takes about 10 seconds to show the number 0.
5) Press + to change the value from 0 to 1.
6) When this value is 1, press colour button; this will light up two leds.
One is for plain paper and the other for photo paper. At this point is feed the printer with paper.
7) Press the power button twice and the printer will print a some stuff (if it doesn't print by itself, then press the "color" button once and the test sheet will print). Don’t worry much about the printed material. I got some stripped lines and some numbers. I believe that my colour cartridge is clogged which is why I got the green strips.
When you print this sheet the value in the display returns to zero.
8 ) Open the printer cover cover (not the scanner cover) and remove the cartridges. With the printer still open, disconnect the power outlet.
9) Close the lid and turn on the printer.
10) Refill cartridges and place them back in their nice little abode in the printer.
Hpoe this helps
Posted on Mar 09, 2009
  • 1218 Answers
SOURCE: error 5B00 Canon MX308
The reset procedure (for canon MP130) is:-
Turn on the machine
(1) Press MENU
(2) Press SCAN COPY SCAN to enter service mode
(3) USE > to got to NVRAM ACCESS
(4) set ABS-M LEVEL to 0
(5) set ABS-P LEVEL to 0
(6) Press STOP to EXIT
Hope this help for you also.
Posted on Oct 26, 2010
Can we use cannon mx308 model scanner without cartridge
No, it is not possible & see help topic on error cartridge in canon printer error e5.
Sep 25, 2010 | Canon MX300 Office All-In-One Printer
My printer is pixma canon mx308.when printing,the paper always jammed.how to solve this problem?error code 5100
This particular error has a lot to do with some obstruction in the print path, the gears, or ink on the clear plastic encoder strip.You can find the the purge cap (the white sliding mechanism that the print head parks to when it's not in use) was not lubricated well enough from factory. If you lubricate the sliders with some white grease (don't get it on the small wipers or the black caps) the mechanism can now slide more freely, and the unit can park the head properly without giving you the dreaded head homing error 5100 (or E-2-2 on the LCD display). Keep in mind that this repair will probably require you to remove the right panel off of the printer to gain access to the purge mechanism. There are two screws behind the printer, and two in front for each corresponding side panel (the front screws are behind the grey front panel of the printer - open the top cover to see the clips which hold the front cover on).
Thank you !!
Jul 22, 2010 | Canon PIXMA MX300 All-in-One Printer
Service error 5100
you have a carriage error, not worth fixing throw it away
Canon Tech
Apr 08, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Canon MX 308
How to reset canon MX 308 ??
Error Code 5800
Any Software to reseter this printer?
Feb 24, 2009 | Canon PIXMA MX310 All-In-One Printer
Need printer driver
hi
sir,
i realy need pixma mx 308 inkjet printer driver .
becouse i lose my driver pls send fast sir
Oct 06, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Need a help for Canon PIXMA® MP470 Printer
My printer wont print. It flashes Error 5100 and the orange light flashes twice. There are no answers in the book.
Feb 19, 2008 | Canon PIXMA iP5000 InkJet Photo Printer
Pixma mp150
when i get copy or print the appear on disply error #2 pls helpe me 2 find solution. error service 5100. For my mp 160 printer
Dec 12, 2007 | Canon PIXMA MP150 All-In-One InkJet...
Canon MX300 Office All-In-One Printer Logo
1,595 people viewed this question
old marine
old marine
