Question about Metra Chevy Truck 88 94
Have a 94 chevy trk with 4l80 trans has 60,000 miles on it went to drive today would not go into reverse or shift into drive pulled pan and trans is spotless inside any ideas? thanks
I have a 1999 Chevy 2500 he diesel and over drive pops in and out...now it will not shift from first
Automatic trans having overdrive issues - Diesel Bombers
www.dieselbombers.com > ... > 12 Valve 2nd Gen Dodge Cummins 94-98
Apr 22, 2011 - '96 dodge 2500 transmission is having trouble staying in overdrive. ... Hetold me it could be the Throttle Position Sensor, the computer needs ... Oh and another thing, The brake safety for shifting out of park is .... 95 chevy 3500 6.5l trans issues, drgracen, Chevy/GMC 6.2L and 6.5L, 1, 10-05-2015 10:13 PM.
Keeps Jumping in and out of overdrive
Mar 25, 2012
4l80 no overdrive or reverse
Mar 10, 2012
4l80E overdrive problems
Dec 10, 2011
More results from www.dieselbombers.com
The most ridiculous Overdrive questions - Diesel Place : Chevrole
Dec 02, 2015 | Cars & Trucks
I have a '94 Caravan w/ a 4-speed trans-axle . When cold it will stay in first gear and also delay engaging in reverse until 2 -4 minutes.I have had a shop change the filter and fluid to no avail. They...
Remove the transmission pan, change the tranny oil filter & adjust the low-reverse band. Any chilton or haynes manual gives the tolerances & step by step procedure to effect repairs. You will need approx. 7 qts. of tranny fluid. Hope this helps. Good luck!
Feb 28, 2011 | 1994 Dodge Caravan
My 94 pontiac grand prix will only drive in first gear an will not shift up also will not shift to reverse
your reverse band went out in the trans you will have to get it replace or rebuilt. either way youll need a trans.
Jun 26, 2010 | Cars & Trucks
Shifts hard only some times when cold or hot from 3rd to over drive the truck has 130,000 miles and is a 2000 chevy silverado 2500 6.0L
1-2 shift is delayed and harsh, may not shift into OD: Check TPS for smooth and linear electrical response over the entire range of motion. If not, replace or EPC (Electronic Pressure Control) solenoid failed. Easy fix in pan. Fix as soon as possible or hard parts will eventually break. Start with the simple and check the transmission fluid level and condition.Secondly, put a line pressure gauge (or visit a local trans shop) on the pressure test port and go for a drive to verify proper line pressure. Base pressure at idle in P,N,OD should be around 70psi and around 140psi in R. Max line pressure should be at least 190psi at WOT in 1st or 2nd, 225psi is optimum. If base pressure is low, trans or pump is worn out. If max pressure is low, check EPC solenoid. If reverse is slow to engage, and line pressure does not come up to at least 130psi in reverse, replace the boost valve with a Transgo 0.500" boost valve (easy fix in pan).
No 1st or 4th available; trans shifts 2nd to 3rd by itself in D or OD and locks the converter : ShiftA solenoid failed. Easy fix in the pan. Or a wiring problem from PCM to trans.. or PCM.
Good luck and keep me posted.
Feb 17, 2010 | 2000 Chevrolet Silverado
1997 Chevy P-32 step van (panel van, delivery van) with 4L80-E transmission: Truck drives and shifts properly in gears one through three, but slips as soon as it shifts into fourth. It will not pull at all...
the fourth clutch is burnt probably due to a bad 4th clutch piston seal... if you can get a good trans that cheap then you should just put one in it unless you are familiar with internal trans repairs...
Oct 13, 2009 | 1997 Chevrolet K1500
No reverse
there should be a vacuum tube on the pas side of the trans. its either diconnected or broken. or the bans are bad. also check the filter. mine went bad and all I did was change the filter and used synthetic fluid.
when the pan and filter is down see if there is a heavy spring in one of the corners. if its casing is broke then it wont allow fluid to travel to and fro.
May 20, 2009 | 2002 Chevrolet Silverado 1500HD
My 2001 f250 when shifting out of overdrive its not a solid shift! it seems to flutter into overdrive. the truck has 75000 original miles, 1 owner. under extreme acceleration it shifts fine.
has the trans ever been serviced? it should have the fluid and filter changed every 60,000 miles, this may help if it hasn't been done, also check for clutch mud in the pan of the trans..
Apr 21, 2009 | 2002 Ford F250 Super Duty SuperCab
Linkage shifter adjusted/fix
If you have no reverse, you have a problem. Try changing the trans filter and fluid. While the trans pan is off for filter change, add a bottle of Lucas trans conditioner to the pan before reinstalling the pan. Refill with correct fluid to correct level. That's your cheapest bet. Trans needs service every 60,000 miles
May 17, 2017 | 1994 Lexus Es 300
91 Toyota Camry Transmission Trouble
first check transfluid for level,color,smell&metal shavings if its dark in color and smells burnt. look to change the trans. or if metal shavings also look to change trans if color is clear red flush trans then pull trans pan change filter refill with now toyota type trans fluid.
Jan 05, 2009 | 1991 Toyota Camry
Transmission
i had a problem on a 2004 with 70,000 miles ,it was the trans converter, it fixed it.
Jun 26, 2008 | 2004 Mercury Montery
Metra Chevy Truck 88 94  Logo
199 people viewed this question
Top Metra Car Audio & Video Experts
xxxxxx xxx
Jason
Are you a Metra Car Audio and Video Expert? Answer questions, earn points and help others
