Question about Dishwashers
I have the same problem described in this web link
Http://www.fixya.com/support/t407247-kitchenaid_dishwasher_kuds02srss2_start
but i dont know what you mean by the strike plate, nor where i would hear the click sound. I tried bending the peice that you can take out.. and used a screw driver to puch down the latch on the door. All to no avail.
Thanks
    President:
  • 2,651 Answers
The strike plate is the metal actuator depressing the door latch when closing hte door, its mounted to the top of the tub assy.and as far as pushing down on the latch you would need to push down on either side of the latch( the middle section is a fixed plastic to grab the strike plate
Posted on May 13, 2008
Control panel not lighting
Hello, welcome to FixYa.
I understand by reading your post which indicates it is a KitchenAid KUDS02FRSS
you appear to have a concern with no power to the control, manifesting in the control panel not lighting, correct ?
The one thing I'd suggest is the thermal fuse, typically the symptom you've described is associated with a bad thermal fuse. (part #
661663).
Here's a helpful link below to a video from "repairclinic.com" to assist in changing (or simply checking it as shown in the second link) the fuse kit...it generalizes on most Whirlpool built dishwasher's such as yours, but if slightly different it is essentially the same.
http://www.youtube.com/user/RepairClinic#p/search/0/jdlVbTXm8SY
http://www.repairclinic.com/PartDetail/Thermal-Fuse/675813/679723
I'll watch for your reply and try and help going forward. Hopefully this will provide you with the solution you seek, but please keep me posted if not.
...If so, please take a moment to rate the assistance provided for you here today. Good luck and thank you for choosing FixYa.
Regards,
Macmarkus :)
Oct 17, 2011 | KitchenAid 24 in. KUDS02FRSS Stainless...
No power kitchen aid dishwasher mod kuds01flss6 what do I check first after checking the door switch?
kitchen aid dishwasher mod kuds01flss6 you appear to have a concern with no power to the control, correct ?
8193762)
Regards,
Macmarkus :)
Oct 12, 2011 | KitchenAid Dishwashers
Dishwasher won't start. digital panel, control lock light comes on. Nothing in the manual describes this problem
Hold down the heated dry button for 5 seconds, if that does not unlock the control replace the touch pad. i can walk you though this repair let me know,
http://www.appliancerepairlesson.com/
Mar 07, 2011 | KitchenAid Dishwashers
Dish dispenser will know open
Checkout this tip that I wrote about that problem...
Dishwasher Repair Problem Detergent Cup does not Open
http://www.fixya.com/support/r4225828-dishwasher_repair_problem_detergent_cup
Dishwasher Maintenance
http://www.fixya.com/support/r4319937-dishwasher_maintenance
heatman101
Jul 18, 2010 | KitchenAid Dishwashers
Below is a link on how to reset the control and some information on the causes, let me know if it helps.
http://www.fixya.com/support/r4628906-flashing_or_blinking_green_clean_light_7
May 10, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
Hi, how can remove the inlet protector (chopper) from a Kitchenaid KUDS01IJ?
Here is a link to some instructions I put together to clean out that area. Take a look and let me know if it is helpful.
http://www.fixya.com/support/r4628450-poor_cleaning_or_noisy_pump_whirlpool_or
May 11, 2010 | KitchenAid Dishwashers
Weak water pressure particularly in the upper spinning water arm. Never a good cleaning machine again in the upper half of the dishwasher. My other kitchenaid never had this problem...
This sounds like debris got into the sump area of the pump. I have created a set of instructions on how to clean out. If you are up for it, follow the link below and let me know if it helped.
May 09, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
Control lite just blinks no mater what button i push wont start
HI,
If it is the green clean light flashing then you may have a problem with the water heating up. I have put together some instructions on what might cause that and how to reset the control so you can use the dishwasher again. Follow this link and let me know if it was helpful.
May 04, 2010 | KitchenAid 24 in. KUDI02IRBS Stainless...
I've ordered the parts to repair the latch on my Amana dishwasher, but I don't know where to find instructions. Any suggestions?
here is a web address to link you to it just happens to have a manual online here at www.fixya.com The link is posted below hope this works for you
http://www.fixya.com/support/p51530-amana_24_in_adb1200aw_built_in/manual-1748
Dec 01, 2009 | Amana 24 in. ADB1200AW Built-In Dishwasher
Dishwashers Logo
95 people viewed this question
Top Dishwashers Experts
