It will see the cd rw in bios but wont boot up from cd any idea guys and gals please help real bad
  • 57 Answers
Try changin the cables or try and make the CD the first boot device in the BIOS or us ur friend CD drive
Posted on Sep 06, 2010
My laptop recognizes the CD-RW/DVD drive but it can't read any disk.
What Operating System are you running? Drive could be bad. If you have you a bootable CD (like your original setup disks) turn your computer on with the bootable disk in and see if it tries to boot from it. You may have to adjust your settings in the BIOS to set it to boot to disk before the HDD for this to work.
Nov 10, 2010 | Toshiba SD R2002 CD-RW/DVD-ROM Burner
My cd-rw/dvd drive doesn't register on my computer anymore. I have a dell latitude 110L and i have a nice cd-rw/dvd drive i believe that it can burn up to 20x or 24x speed i'm not sure anymore the exact...
try and roll back the drivers...also another way is to try and boot your machine off the cd drive..if it boots of the drive then you knoie that the drive is working and it is a driver error..if it wont boot off the drive the drive is probablly bad..make shure when trying to boot off the drive that you change your settings in your bios to for to boot from cd..
Oct 21, 2009 | Dell (0F027) CD-RW/DVD-ROM (Combo) Burner
Wont boot
go to BIOS and enable the secondary drive auto detect.
if you manaully set the drive to primary, secondar. the system should be able to detect it as you have set it. if you select cable select or auto. the sytem will put the drive connected to the end of the IDE cable as primary.
Apr 02, 2009 | Intel Motherboard
ASUS P5S800-VM Motherboard set up
Hi m_k_bishop,
You must connect the CD-RW drive to the Secondary IDE connector on your board.
It can not be connected to the Primary IDE port.
(All SATA drives are seen as master drives in the bios).
With that in mind there shouldn't be any data cable connected to the Primary IDE slot.
When you first load the Bios menu screen you should see your CD-RW listed & you should see your SATA drive listed. Go to the title, " BOOT " in your bios.
(If your system has a floppy disk drive connected your Boot menu should read as follows);
First boot device [Floppy Disk]
Second boot device [Your CD-RW drive]
Third boot device [Your SATA drive as shown from the main menu]
No need for a fourth device.
Save the bios & exit. The system will auto restart.
(At boot up re-enter your bios).
Next change the [RAID Mode] to SATA or Enabled anything but RAID.
Once completed save & exit the bios. If everything is connected correctly & you made the changes above your system should see your SATA drive & windows should install.
(Load the windows CD into your CD-RW drive).
The Asus manual lacks the proper information needed for you to make the correct setting changes in the bios.
Good luck m_k_bishop!
Post back if still have trouble... You shouldn't!
Mike
Mar 21, 2009 | ASUS P5S800-VM Motherboard
ASUS P5S800-VM Motherboard configuration
Serial ATA drives are pretty much plug and play. You just need to install them and set them up as a primary drive in your bios settings. The IDE devices can be connected on the same ribbon cable but need to have jumpers set on the back to determine which device is primary or slave. If the IDE devices are on different ribbon cables then most likely the hard drive jumper setting should be set to master or master (single drive). The CD-ROM drive jumper on master. BIOS should detect all drives You also need to assign the boot order in BIOS. CD-ROM should be the first boot device to load and install the new OS onto the primary hard drive.
Mar 20, 2009 | ASUS P5S800-VM Motherboard
My laptop after starting goes to the window xp intro screen then restarts again and again. it wont even recognize the boot disc that came with it
All right, first you gotta check your BIOS settings goto to bbot tab and check the order of your drives at the top must be the CD-rom drive, then check that "boot to optical devices" and "boot to removable devices" are enabled then restart your computer with  a bootable cd and goto repair mode, and perform check disk to the drive in your windows is installed. The command is "chkdisk C: /F /R" hope that helps, please rate the answer
Jan 21, 2009 | Toshiba Satellite P35-S609: Pentium 4-3.2...
Emachine
F10 should get you into BIOS.
Jul 27, 2008 | HP Pavilion dv9000z Notebook
BIOS and Sony CD-RW CRX300E
Your Sony CD-RW is an ATAPI CD-ROM for the purpose of your BIOS. Without you specifying the motherboard brand and model, it is hard to tell you what your issue could be.
Nearly all PC motherboards made after 1995 will allow you to boot from the CD. Enter the BIOS setup screen by pressing, during POST, <DEL> or <CTR>-S (Gateway), <F1> or <F2> and look for boot sequence. Some MB's have a boot sequence key you can press to select the boot device for that boot instance only.
If you are trying to say that you have an ATAPI CD-ROM and the Sony CD-RW, then check your master/slave/cable select jumper settings on the device. Each IDE channel can have at most one master and one slave.
Jul 13, 2008 | ASUS Computers & Internet
Acer 5100
please to go to your bios setting and check under boot sequence whether your hard drive is the 1st device. try to reset the bios to its default settings and after resetting it try to check again on the boot sequence to make sure that your hard drive is the first option. if you have external devices connected to the computer remove all of it.
Jun 09, 2008 | Acer (91.42R37.001) CD-RW/DVD-ROM (Combo)...
My windows XP home edition wont find my CD drive
I'm not sure if you've already done these things or not, but this is what I would do:
Reboot and enter the BIOS setup. There should be an indication on the screen of how to enter the BIOS setup during the startup. It's typically something like the Delete Key or Function Key.
Check to see if the BIOS recognizes the CD-RW drive. If it does then your problem is most likely in Windows. If the drive is not visible in the BIOS then a number of things are possible. Is the drive set to Master, Slave, or Cable Select? Is it on the right setting? Have you tried both of the IDE connectors?
If you need more help with this just let me know. I also want you to know that I'm not getting paid, I just like helping when I can. If you've found this information helpful I hope you'll give a positive rating. If what I've offered has not been helpful please let me know so I can try to help more. Thanks and good luck.
Jan 01, 2008 | Computers & Internet
Computers & Internet Logo
14 people viewed this question
David Payne
David Payne
