Question about GE GSH22SGRSS Side by Side Refrigerator
One last question
Then how do I know if it's damaged or not?
Thanks a lot.
  • 975 Answers
You gonna need a multimeter set to OHMS , there should be a reading 2 digits up to 3 digits, if reading is 0 ,then element is damaged , hope this helps AJ
Posted on May 12, 2008
Why my sony TV ES29M80 switching to standby mode immediately?
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Sep 04, 2014 | Televison & Video
My phone seems to switch off at random times and the screen goes white, it only turns on when i pull the battery out and then plug in the charger, what is the problem?
There may be a lots of faults like:
1. Both battery and display is damaged and battery goes dead.
2.display IC has damaged and definitely your battery is dead.
3.Screen may have damaged
Solution:
1.firstly check your battery.
2.check your ic display weather damaged or not.
to solve your problem visit the nearest mobile care center
and get your problem be solved and
lastly your mobile need FLASHING.
Update your handset.
thanks
Aug 19, 2011 | Cell Phones
I have a mitsubishi carisma 1800 gli it has done only 38000 miles but i do not know if the cambelt has been changed it is 10 years old what do i do
Change it or have it changed so you know when it was done last and it won't go breaking down on you in the middle of nowhere.A broken timing belt will do a lot more damage and it will be an expensive repair.
Timing belts are supposed to be replaced at 100,000 km's but they do last till 160,000 if driven with care.
Jul 23, 2011 | Mitsubishi Galant Cars & Trucks
2006 nissan sentra timing chain does it need changing at a certain time or mileage. thanks
Thanks for choosing FixYa and welcome to the sight.A timing chain can last 100,000 miles or more. Some can last the life of the vehicle. Here is the thing though. If it breaks, you are not going nowhere and it can cause engine damage. If you have the money and time, plus it is over 100,000, go ahead and have it done. If not, it should be fine through 125,000 miles. Some last forever and some can break before 100,000. You really just never know. The call is yours. Thanks for choosing FixYa. If you need anything else, just let me know.
Jul 10, 2011 | 2006 Nissan Sentra
Shock absorrber bolt had to be tightend last rear
There is a rubber grommet that has broken. Take to a shop as those can do a lot of damage.
Mar 24, 2010 | 1997 Buick Skylark
My aspire5600 screen is flickering, is my video card damage?
check first the vga connection maybe this loss only. ..and the driver if installed properly check thevga cable..
the last is vga chep.. vga card... use another vga card if pc..
thanks
May 31, 2009 | Acer Aspire 5600 Series 5630-6951 Laptop
Time Belt Maintenance or Replacement
Hi ,Timing belts are designed to last from about 40 ,000 to 60,000,they can last a lot more than that but is not safe to run them for so long ,they can fail at any time causing major engine damage,other than that just regular maintenace,oil changes transmission,brakes,tune ups gas filter, wipper blades, battery ,weel alignment,tire balance , keep an eye on ,tires,shocks,
Dec 02, 2008 | 2005 Dodge Caravan
GE GSH22SGRSS Side by Side Refrigerator Logo
51 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
