Question about Honda Pressure Washer PSI 3000
I bought a troybuilt pressure washer used and i changed the motor oil and ran it maybe 5 minutes. later i checked the oil level again and it shot out the cap and i noticed the pump oil level is also almost to the top of sight glass. Does anyone know whats wrong?
  • 57 Answers
If you left it sit for a while & did not turn the fuel tap off,it may have flooded and therefore the oil level would have risen causing the oil to over flow.
always turn the fuel tap off when not using your pressure wahser.
Posted on Dec 20, 2010
Low Oil Pressure warning on 2007 Chevrolet Equinox after a car wash. 127000 miles. Oil full and clean. Could the car wash have shorted out the sending unit?
THE OIL SENDING UNIT GOT WET,WHAT EVER YOU DO,NEVER HOSE DOWN THE MOTOR,ALWAYS GET A DAMP RAG AND WIPE,THE OIL SENDING UNIT IS BY THE OIL FILTER.
Aug 16, 2015 | Chevrolet Cars & Trucks
Motor fires up fine runs slightly rough for about 10 seconds then smooths out for about 5 seconds and cuts off. Will start right back up after about 5 seconds and does the same thing. I have drained the...
Previous owner had way overfilled crankcase oil. Oil had gotten into carb and clogged air filter. Drained oil to correct level. Ran engine but kept cutting off-see above. Took off carb cover cleaned housing and ran without air filter-ran fine. Unsuccessfully tried to clean air filter with gas-did not work. Apparently, the engine could run just long enough to exhaust the air in the old filter and cut off which is why it would start back up after a few seconds. Bought new air filter-whole thing-about $15 at Carquest. Put in some carb cleaner and installed the new filter and it runs perfectly.
Jun 10, 2014 | Homelite Pressure Washer. 2700 psi 2.3 GPM...
My 1999 toyota tacoma prerunner ran fin oil light came on aqnd it just shut off
Maybe you are low on oil and some cars are made like that to shut off when they run out of oil. So check the oil level and add as needed. if there is oil then maybe the oil pressure is low
Dec 08, 2010 | 1999 Toyota Tacoma PreRunner
Engine will not run but a few minutes at a time
Check your spark plugs, see if they are failing, if they are then your motor is getting to hot. meaning that you either have the fuel mixture set to high or the setting on the spark plugs are not correct causing you to burn hot.
Please rate
Jun 01, 2010 | Honda Pressure Washer PSI 3000
Hello, I have a couple year old brigs and strattion upright pressure washer. It has always ran great untill recently. It will run for a acouple minutes before dying, like it is starving for fuel. i give it...
Check the oil level in the engine itself. Verify that your oil reservoir is full, then try again.
You may also want to refer to the owners manual for other trouble shooting tips. Click this link to go to your manual.
http://www.pressurewashersdirect.com/manuals/020244%20manual_2.pdf
And remember
Automatic Cool Down System
(Thermal Relief)
If you run the engine on your pressure washer for
3-5 minutes without pressing the trigger on the spray gun,
circulating water in the pump can reach temperatures
above 125°F.The system engages to cool the pump by
discharging the warm water onto the ground
Mar 24, 2010 | Briggs & Stratton Gas Pressure Washer...
My Simpson Water Shotgun shuts down about a minute into the wash
Have you checked the oil level? Some engines have a sensor that shuts it down if the oil is too low
Jul 16, 2009 | Simpson PS2600 PowerShot Commercial-Duty...
Losing pressure more and more often, especially
not quite sure where to get the parts, but if the pressure starts out ok and decreases as it runs, it is generally that the piston rings/seals are worn out, this can happen just from sitting up over the winter.
You can google Honda Pressure Washer Parts to find a supplier for the seals/rings
Jul 05, 2009 | Honda Garden
How to change oil in a pressure washer
From the manual CleanShot 2050 Briggs and Stratton
Change Pump Oil
1. Drain engine oil and fuel from pressure washer
2. Use an 8 mm allen wrench to remove black pump oil cap between high pressure outlet and garden hose inlet.
3. Tiltl pressure washer to drain oil into an approved container until it drips slowly from pump.
4.Tilt pressure washer in opposite direction and empty premeasured pump oil bottle into same opening (a small funnel may be helpful) [THIS IS WHAT THE MANUAL SAYS-NOT CLEARLY WRITTEN IN MY OPINION OR WRITTEN BY SOMEONE FOR WHOM ENGLISH IS A SECOND LANGUAGE]
5. Install black pump oil cap and tighten firmly.
6. Set pressure washer in upright position. Add fuel and engine oil.
From the engine manual use synthetic 5w-30, 10w-30 from -20 degrees F to temperature of 100 degrees F.
Change oil after 5 hours of operation initially. Before tipping to drain oil, remove fuel from fuel tank by running until tank is empty. Remove oil cap and dipstick and tip engine. Keep spark plug side up. Or remove drain plug from the bottom of pressure washer with a ratchet and square extension and drain oil from bottom. (fuel does not have to be removed)
May 21, 2009 | Briggs & Stratton Pressure Washer...
Honda Pressure Washer PSI 3000 Logo
116 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
