Question about Whirlpool Washing Machines
My whirlpool front load is making error of F35 and sometimes would say SUDs. I don't understand why it saying that. It won't do any washing at all.
    President:
  • 1,932 Answers
The F35 error meams there is a problem with the Analog Pressure Sensor. This sensor is near the back right of the machine (viewed from the front) when the top is removed. It has a hose going to it and an electrical connection.
Replace the sensor
Thank You
Posted on Sep 06, 2010
Whirlpool duet f35 error-suds error
Maybe this will help, but I'm not sure
Condition:
SUDS LOCK (Overdose of Detergent detected during the Wash Cycle)
The motor control unit senses a suds lock condition by analyzing the current draw on the drive motor. If "Sud" is displayed a potential suds lock is detected. This may signify a bad pump, an extra heavy load, excessive detergent, or excessive suds.
Check:
If too much detergent was used, run the unit through a Rinse/Spin cycle, then a Normal cycle, without adding any detergent. This should clear the unit of the excess detergent.
Check the drain hose and make sure it is not plugged or kinked.
Check Wire Harness connectors to the Drain Pump, Pressure Switch, and Central Control Unit (CCU)
Check/Clean Drain Pump Filter of foreign objects
Check Drain Pump
Check Pressure Switch
Check CCU
Dado
Sep 13, 2015 | Whirlpool Washing Machines
Suds and then f35 error code shortly afterbstarting any wash cycle.
SUDS error = SUDS LOCK (OVERDOSE OF DETERGENT
DETECTED DURING THE WASH CYCLE)
If suds are detected continuously by the pressure switch during the drain or spin phases, the washer will fill 4 liters of water and during 5 minutes the unit will rest without tumbling, the water will be drained
and it will try to spin or drain again.
If too much detergent was used:
- Run the unit through a RINSE/SPIN cycle.
- Run a NORMAL cycle without adding any detergent.
1. Check the drain hose and make sure it is not plugged or kinked.
2. Unplug washer or disconnect power.
3. Check wire harness connections to the drain pump, pressure switch, and Central Control Unit (CCU).
4. Check/clean drain pump filter of foreign objects.
5. Plug in washer or reconnect power.
6. Check drain pump.
7. Check the pressure switch.
8. Verify CCU operation by running a Diagnostic Test or any cycle.
F35 error = ANALOG PRESSURE SENSOR FAILURE
If this failure is displayed, there is any malfunction of the steamer component detected by the Steamer Electronic Board.
1. Check if pressure hose is fi xed correctly.
2. Check if the airtrap is not blocked.
3. Check if the hose is not blocked.
Dec 28, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I have a whirlpool WFW9600TW01 front load washer. It is giving F35 and SUD error codes. I have cleaned the drain pump and lines, cleaned the dispenser, flow regulator and hoses, took out and cleaned the...
Hi dear.I may have solution for the SUD error.You can give it a go.But I do not know any thing about F35 one
The motor control unit senses a suds lock condition by analyzing the current draw on the drive motor. If “Sud” is displayed a potential suds lock is detected. This may signify a bad pump, an extra heavy load, excessive detergent, or excessive suds.
Potential Causes
• If too much detergent was used, run the unit through a Rinse/ Spin cycle then a
Normal cycle without adding any detergent. This should clear the unit of the excess detergent.
• Check the drain hose and make sure it is not plugged or kinked
• Check Wire Harness connections to the Drain Pump, Pressure Switch, and Central Control Unit (CCU)
• Check / Clean Drain Pump Filter of foreign objects
• Check Drain Pump
• Check the Pressure Switch
• Check CCU
Replace failed component.
As it says run couple of rine cycles it should get back to normal.I hope that helps you.Thanks.
Aug 29, 2010 | Whirlpool Duet 4.0 Cu. Ft. Steam Washer
Suds and F35 keep shuting down my laundry day:(
Remove the service panel and see if the filter has something in it77cb04b.jpg2402fad.jpgf032166.jpg
May 02, 2010 | Whirlpool Duet GHW9150P Front Load Washer
F35 and Suds error on Kenmore Elite HE5t
I also got the SUDS error followed by F35 many times. I replaced the analog water level switch, Wirlpool part number W10156252, and the problem went away. The part is located against the back right corner of the top of the washer after removing the top cover. The part cost $62.99 + $12.95 express shipping from ApplianceZone.net. I have the Kenmore HE3t Steam Washer, model number 110.46752 700 front loader. I was able to run about 6 loads of laundry by unplugging the washer, waiting about 5 minutes, the re-plugging and re-starting the washer. Thereafter, the problem became permanent. I always used HE detergent. The washer was purchased new in December 2007, and the I made the repair in September 2009. I spent about $1300 for the Kenmore H3t Steam Washer, and I am disappointed that it required repair after less than 2 years. My mothers old Maytag washer lasted more than 15 years, and was not susceptible to soap SUDS.
Jul 20, 2009 | Kenmore Elite 45986 Front Load Washer
F35 Sud errors
OK, you can't use regular Gain detergent in this washer. you will need to use the recommended (HE-High Efficiency) brand. its the only way to avoid the SUDS.
Jun 10, 2009 | Whirlpool Duet GHW9150P Front Load Washer
F35 and suds it turns off after 5 mins and whenever I put it on rince only it still cuts off.
F35 is a water level error.
The water level switch (pressure switch) has malfunctioned.
If you remove the top panel, three screws in the back, you will have access to the pressure switch.
With the tub empty, remove the vinyl hose from the switch and blow backwards through the hose to clear any restrictions.
If the fault codes return after doing this, you will likely need to replace the pressure switch.
Also - please be sure to use He soap.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.####
May 25, 2009 | Whirlpool Duet GHW9150P Front Load Washer
F35 code
Dec 26, 2008 | Whirlpool Duet GHW9150P Front Load Washer
F35 Message on Brand New Washer
suds is determined using the level sw located on top right rear side. remove top cover to see. most letter codes do convert to a f code. most common reason for suds error is use of standard detergent or too much detergent. running a empty load of fabric softener can clean the system. or rinse/spin with nothing. other common problem is this is a whirlpool product.
Dec 01, 2008 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
113 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
