Question about Maytag 24 in. PDC3600A Built-in Dishwasher
Dishwasher is leaking water from the bottom of the front door
  • 15,935 Answers
Check the seal - hen check the door is properly adjusted.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 06, 2010
Leaking at the bottom in the middle of the door
you need to determine if it's coming from inside the door or under the front of the dishwasher, if the door latch needs adjusting it can get water through the latch slot, the dispenser can work it's way loose and water can leak through it, or the seal on the bottom of the door can get dirt stuck on it which can cause water to leak out.
Otherwise it could be in the bottom of the dishwasher, it is a matter of closer investigation.
Mar 10, 2012 | GE 24 in. Profile PDW7800 Built-in...
Water leaking at the bottom of the door
Tightening the fittings
1 Remove the service panel that runs along the front of the dishwasher just below the door. If it is screwed in place, remove the screws with a screwdriver. If the panel hangs on hooks, pull the panel out and swing it up to remove it from the hooks.
2 Check the end of the drain hose that connects to the dishwasher. If it's leaking, tighten the clamp with a screwdriver.
3 Check the drain hose connection to the kitchen sink drain. Again, if it's leaking, tighten the clamp with a screwdriver.
4 Check for leaks around the water-inlet valve. If necessary, use an adjustable wrench to tighten the compression fitting that connects the water-supply line to the valve. If the fill hose is leaking, replace the spring clamp that is on the hose with a worm-drive hose clamp. It produces more clamping pressure. Use adjustable pliers to compress the spring clamp so you can pull the clamp and hose off the valve. Remove the spring clamp from the hose. Buy a worm-drive clamp at your hardware store, then install it and tighten it with a screwdriver.
Leveling the machine
1 Remove the front access panel (see step 1, "Tightening the fittings"). This will give you access to the dishwasher's adjustable feet.
2 Open the door completely and remove the bottom dish rack.
3 Unscrew the dishwasher from the kitchen countertop so the dishwasher can move freely as you adjust the feet.
4 Check to see if the dishwasher is level side to side. Place a small level inside the dishwasher so it's sitting on the bottom pan and facing parallel to the front lip of the dishwasher. If the dishwasher is not level, use adjustable pliers to turn one of the dishwasher's front feet up or down until you hit level.
5 Check to see if the dishwasher is level front to back. Turn the level perpendicular to the door, and place it on one of the bottom ledges that run along the side of the cabinet. Check the level again. If the dishwasher isn't level, use your adjustable pliers to turn the back feet up or down until you hit level.
6 Reattach the dishwasher to the countertop and reinstall the front access panel.
Fixing a leaking door
1 Inspect the door gasket. As it ages, the gasket can crack or become hard, preventing it from sealing completely.
2 If the gasket appears solid, adjust the door latch so the door seals tightly. Loosen the screw that holds the door latch to the cabinet. Push the latch in slightly and retighten the screw. Test the door and readjust the latch if necessary.
3 Replace the gasket if water continues to leak after you've tightened the latch. Most gaskets are held by compression in a groove on the door or on the dishwasher cabinet.
4 Pull the old gasket out of its groove, using adjustable pliers (see illustration). Take the gasket to an appliance store to get a replacement.
5 Soak the new gasket in warm water to soften it, then press it into the groove. Start at the top, then work your way down the sides and across the bottom.
Nov 24, 2010 | Hotpoint 23 in. BFI62 Built-in Dishwasher
Just installed the dishwasher and it is leaking from the the two front corners of the door
I dont know what brand your dishwasher is, but if it is leaking from the two bottom corners it is not level. If the back is higher than the front, the water will drip out of the bottom corners of the door. Raise the front feet up so that the edge of the door is flush with the cabinet doors from the top to the bottom.
Nov 20, 2010 | Dishwashers
Brand new kenmore dishwasher leaking out the front
Check the door gasket for uniform seating. Align it. If this does not solve the problem, contact the service provider. He may change the gasket or do the corrective action.
May 25, 2010 | Kenmore 13743 Staimless Steel Built-in...
My GE dishwasher is leaking water from the bottom of the machine
first check to make sure door gasket is ok, if bad, replace and test. Make sure to remove bottom front panel during a test and inspect the motor and motor gaskets. It may be leaking here, replace leaking components as needed.
Jul 01, 2009 | GE 24 in. GLD6200L Built-in Dishwasher
Dishwasher leaks water as it fills
  • Step 1 Remove the front access panel (see step 1, "Tightening the fittings"). This will give you access to the dishwasher's adjustable feet.
  • Step 2 Open the door completely and remove the bottom dish rack.
  • Step 3 Unscrew the dishwasher from the kitchen countertop so the dishwasher can move freely as you adjust the feet.
  • Step 4 Check to see if the dishwasher is level side to side. Place a small level inside the dishwasher so it's sitting on the bottom pan and facing parallel to the front lip of the dishwasher. If the dishwasher is not level, use adjustable pliers to turn one of the dishwasher's front feet up or down until you hit level.
  • Step 5 Check to see if the dishwasher is level front to back. Turn the level perpendicular to the door, and place it on one of the bottom ledges that run along the side of the cabinet. Check the level again. If the dishwasher isn't level, use your adjustable pliers to turn the back feet up or down until you hit level.
  • Step 6 Reattach the dishwasher to the countertop and reinstall the front access panel.
  • Step 1 Inspect the door gasket. As it ages, the gasket can crack or become hard, preventing it from sealing completely.
  • Step 2 If the gasket appears solid, adjust the door latch so the door seals tightly. Loosen the screw that holds the door latch to the cabinet. Push the latch in slightly and retighten the screw. Test the door and readjust the latch if necessary.
  • Step 3 Replace the gasket if water continues to leak after you've tightened the latch. Most gaskets are held by compression in a groove on the door or on the dishwasher cabinet.
  • Step 4 Pull the old gasket out of its groove, using adjustable pliers (see illustration). Take the gasket to an appliance store to get a replacement.
  • Step 5 Soak the new gasket in warm water to soften it, then press it into the groove. Start at the top, then work your way down the sides and across the bottom.
  • May 14, 2009 | Whirlpool 24 in. DU1100XTP Built-in...
    Door leaks on the floor in front of my dishwasher
    1. make sure dishwasher is level front to back and side to side.
    2. check the main washer arm (WD22X154) on the bottom side for leaks. If you use heated dry, the heating elements can cause the part of the spray arm directly over it to soften and eventually leak. When water comes out that leak it can spray at the bottom of the door, splashing water inside it and resulting in your leak.
    3. if 1 and 2 OK, watch how you load the lower rack. If dishes or a bowl direct water from the lower wash arm to spray against the bottom of the door, especially at the center of the door bottom, the resulting splash inside the door allows water to hit the outer door panel and drip out a one or both corners of the door.
    Dec 07, 2008 | GE 24 in. GSD2220Z Built-in Dishwasher
    Leaking water from front of door
    I replaced the seal part # 154576501. The notch is on the right facing the dishwasher. Just pull it out and insert the new one.
    I've fought this problem for over a year, thinking it was an adjustment. I am now running it through the third cycle and I am positive it fixed my leak. Also, while you have the cover off, check and trim the tie-wrap around the wire loom. Mine was interfereing with the seal, but the seal was also slightly distorted allowing the splash to come underneath.
    BnoGno
    Nov 16, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
    Vulcan dishlex mark 8 leaking water from bottom front door in wash cycle.
    try adjusting the feet at the front of your dishwasher so it leans back slightly to keep the water towards the back of the washer
    Dec 07, 2007 | Dishwashers
    Dishwasher leaks
    If you have nuisance water leaks around the base of your dishwasher, you may be using a detergent that is sudsing too much. Cut back on the amount of detergent you use and see if that makes a difference. Water that spills through the door vent is usually caused by improperly loading dishes. Leaks from the door itself may be caused by a faulty door gasket or door tightness adjustment. Also make sure the dishwasher is sitting level (you can adjust the front feet up or down and many units have some type of levelers at the rear). Water under the dishwasher may be originating from a leaky hose or loose hose connection. Remove the lower front panel and check the hoses. The pump seal may be defective, too; replacing this is a job for an appliance repairperson. An older dishwasher may corrode at the bottom, but this is fairly uncommon. If this is the case with your dishwasher, it's time for a new one.
    Jan 18, 2006 | Hoover 24 in. DT999 Free-Standing...
    Maytag 24 in. PDC3600A Built-in Dishwasher Logo
    103 people viewed this question
    Top Maytag Dishwashers Experts
    Mike
    Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
