Question about Mitsubishi WS-55411 55" Rear Projection Television
I CAN GET PROPER COLOR ON MY WS-55411 MODEL - Mitsubishi WS-55411 55" Rear Projection Television
    Top Expert:
  • Mitsubishi Master
  • 14,553 Answers
Try to describe better, is picture 3d looking or what is your problem?
Make a comment here OR IF YOU RE-POST THE QUESTION MARK IT "attention SD TECH" AND I will assist you.
I know the model indicated very well.
SD TECH
Posted on Sep 06, 2010
How do you adjust color
NORMAL adjustments are made with the remote in the menu--if color looks skewed or even 3d go into menu and select convergence--with remote see if will adjust.
A better explanation of what the issue is might help and confirm model number if possible
Apr 15, 2012 | Mitsubishi WS-55411 55" Rear Projection...
Ws-55411 getting a code 22 short circuit were do i need to look for with this problem do you have idea ?
Check the pico fuses on the board. If one or more tests open, then likely the STK chips need to be replaced. This would mean a convergence failure.
Feb 19, 2011 | Mitsubishi WS-55411 55" Rear Projection...
Hi I need a replacement bulb for my WS-55411 Mitsubishi. Can you help me find the right bulb and it's part number? The screen blacked out and sound still works so I assume I need a new bulb. When I shop...
Your model doesnt have a bulb since its a rear projection TV . It has three picture tubes, However loss of video with audio still working is usually caused by a vertical output failure.
Jul 28, 2010 | Mitsubishi WS-55411 55" Rear Projection...
WS-55411 What seven capacitors need replacing? 2-3 code Problem
U check the power supply board,check all cap,and replaced it?Ur tv make buzzing noise when u turn on power?Ur flyback is dead.
Mar 17, 2010 | Mitsubishi WS-55411 55" Rear Projection...
Red and green colors seperating screen is like a double picture
Replace Both of your convergence ICs STK392-570 Call Mats 1-800-628-1118 $10.95 each
Dec 31, 2009 | Mitsubishi WS-55411 55" Rear Projection...
Mitsubishi WS-55411 55 in. Rear Projection Television
2 possibilities. Either your convergence IC's are going bad, or you need to remove the front panel of TV where the speaker grill is and you will find a small box with 6 control knobs on it. Mark each knob so you can set it back to its original position if you forget, the set might turn off if you adjust too high on either color, if so, set knob back in original position and turn tv back on and try again.The if it works reallign your convergence and that should do it.
Jan 28, 2009 | Mitsubishi WS-55411 55" Rear Projection...
Do have power and sound, do not have picture
this unit has a self test check you can do
when the set shuts down or when the set is turend off.
press and hold , onthe front of the set the input or device button, and hold the menue button for bbout 5 seconds.
the set will flash a 2 digit blink code at you.
12 blik = no problem
21 blink = xray protect
22 blink = short protect
23 blink = loss of deflection.
regards,
daniel.
Jan 15, 2009 | Mitsubishi WS-55411 55" Rear Projection...
TV not turning on after left on
ok 6 hours is not long but i would deffintly say u have a power issue now with the box inside over heated and burnt out will have to be prfessionaly replaced
Jul 18, 2008 | Mitsubishi WS-55411 55" Rear Projection...
4 pin or 6 pin
It has neither. It is not firewire capable.
Jul 17, 2008 | Mitsubishi WS-55411 55" Rear Projection...
Mitsubishi WS-55411 55 in. No Power up
Error code 12 means normal operation. On these models we have found that a switch is bad on the control panel not allowing the set to turn on. Disconnect the control panel. You will be able to use the remote on set. To find the plugs for the control panel: Remove the speaker grill and front panel, then follow the wire to the connection. You can use an ohm meter to find the bad switch.
Jul 04, 2007 | Mitsubishi WS-55411 55" Rear Projection...
Mitsubishi WS-55411 55" Rear Projection Television Logo
29 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
