Question about Brother HL-2040 Laser Printer
Suddenly won't print
Was printing fine, then red blinking light ("paper") started, won't respond to further command to print or to pushing the "go" button. Have removed tray and replaced several times. Have turned off and back on. Nothing working.
  • Anonymous May 20, 2008
    Printer Brother HL-2070N worked fine on Friday, when tried to print after long weekend, paper light keep flashing. Have filled the paper tray, taken out paper tray to check for paper jams - are none. Taken out print cartiage and put back in, turned printer on and off quite a few time. PRINTER LIGHT STILL FLASHING.
  • asharose May 20, 2008
    Printer was printing. Now it only flashes two red lights and will not print. Tried to replace the paper and tried to shut down the printer and computer and turn everything on again and the printer still only blinks red lights. There is no paper stuck anywhere. Tried to press the go button but that does not work. Tried to shut off the "off" button on the side of the printer and when on again only blinking red lights. When th printer first starts up the green "go" button first lights but then stops and red lights blink. Thanks
Found paper fanfolded in back, over the drum. Removed paper, still not consistently feeding through but at least I know where the hang up is.
Posted on May 13, 2008
Epson R260. Brand new. Green light blinks, red stays on.
https://www.manualslib.com/manual/357821/Epson-Stylus-Photo-R260.html?page=55#manual says Epson's manual thinks Red
paper out light ) is on and green P power light flashes means
If you're printing on paper, your paper ran out or multiple
pages have fed at once. Make sure you push the tray lever
up to set the front tray to the paper (lower) position. Then,
load more paper and press the ) paper button to resume printing.
If you're printing on a CD or DVD, the CD/DVD tray is not
inserted. Follow the instructions beginning on page 27 to
insert the tray, then press the ) paper button.
Nov 06, 2017 | Epson Stylus Photo R260 InkJet Printer
Paper stops half way
Please check for torn piece in the carriage which is causing the error
Jul 06, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
Brother HL 5150D not printing unless I keep pressing Go
its not the problem of toner cartridge.its the problem of gears which pulls the paper they r worn out or may be cracked internally.exactly what happens when you u give the print for the first time the printer gets command and the gears starts spinning and the paper gets pulled because it gets a pressure internally and after 2 pages that pressure gets low and it stops pulling the paper.some times changing the paper thickness solves the problem temporvarily .i mean use the thick quality paper instead of thin.
Jan 08, 2009 | Brother HL 5150D Laser Printer
Paper feeding halfway through then stops
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 03, 2009 | Samsung CLP 300 Laser Printer
EPSON R230 PRINTER
ONCE PRINTE COMMAND IS GIVEN PAPER IS ROLLED IN AND THEN PAPER JAM RED LIGHT BLINKS. CAN NOT PRINT ANYTHING.BUT NOZZLE CHECK PRINT CAN BE PRINTED.
Jul 23, 2008 | Epson Stylus Photo R200 InkJet Printer
Not printing, making me crazy
A paper jam has occurred. To solve the
problem, see “Clearing Paper Jams” on
page 6.3.
• The front or top cover is opened. Close the
front or top cover.
• There is no paper in the tray. Load paper
in the tray.
• The waste toner container is not
installed or full. Check the container.
• Your system has some problems. If this
problem occurs, contact your service
representative.
  • Also i can indicate that the Toner Cartridges are empty and need replaced with Genuine Samsung Cartridges
Jun 17, 2008 | Samsung CLP 300 Laser Printer
Problem Printing with Alps MD-1000
Have you ininstall the device and reinstall it? Do you have any pending print job?
Apr 22, 2008 | Alps MD 1000 Thermal Printer
HP 952c
hi!
Try to cancel your document in the printers menu even if you restart the pc or the printers memory stores the previous command.
1.The idea is that printers has its own memory unless you cancel the document that you print.
e-mail me at wendel_tenebroso@yahoo.com if the problem persist
Apr 08, 2008 | HP DeskJet 952c InkJet Printer
Paper jammed
I had exactly the same problem, printer virtually new, printed great for a couple of weeks, then today refused to take paper with E3 flashing. No apparent blockage - all looked clean, tried all the utilities, roller cleaning and plate cleaning, but wouldn't take paper!
Solved it by moving the paper size guide all the way to the left, then folding the top 20mm of a sheet of A4 over and loading it so fold is at the top facing you. This acts as a catcher for anything stuck in the printer. Hold the paper slightly crooked with the left side slightly further into the printer and press the copy button (with nothing in the scanner!). It should draw the paper in now (with some persuasion) and think it is printing (it's blank,of course). Check as the top of the sheet goes in that the fold is still tight and doesn't open up as it feeds in. Lo and behold, mine brought out a 5p piece - printer now prints perfectly!
Mar 20, 2008 | HP LaserJet 2100 Printer
Brother HL-2040 Laser Printer Logo
69 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
