Question about Frigidaire FRS3R5EMB Side by Side Refrigerator
WARM REFRIGERATOR TEH FOOD SIDE OF THE REFRIGERATOR STAYS WARM,NO MATTER HOT HIGH YOU TURN IT UP fan running,cleaned the bottom area. now refrig. will not get cold no matter how cold you change the setting. I put two thermometers- one in the refrig, and one in the freezer. freezer one reads10 degrees and the one in the refrig.part reads 60 degrees. thanks in advance for any help.
    Guru:
  • 93 Answers
Sounds like the damper isn't opening. Put you hand on the Left wall of the fridge side, at the top. If you feel No Air. Then there is your issue. Bad Damper Motor. Also check the back wall of the freezer, there sould be No Frost. If there is then you have a defrost issue. Not a damper problem. One more thing. Make sure when you shut the fridge door, the light goes out. About a half inch or so before the door is completly shut, the light will go out, if not then thats your issue. Let me know how you make out.
Bill
Posted on May 15, 2008
The strip between freezer and refrig become hot then cools off. It's like it is going thru a cycle. We cleaned the coils underneath, but it is still getting hot and then in about 15 minutes, it's...
When you cleaned the coil underneath did ya notice that their was air being blown out their by a fan,having clened the coil was a good start but if the fan by the compressor isn't running that divider between the ref/freezer will be hotter than normal( its normally warm and thats ok),so check that the condenser fan is running and that it seems to running at a good speed.
GENE
Sep 23, 2011 | Whirlpool GC5SHEXNS Side by Side...
On our side by side, the partition between the sections get really hot. Why?
Refrigerators used to use a low wattage electric heater to warm this area in order to prevent condensation from forming there. Now, in an energy concious world, they use a loop from the condensor so "waste" heat can be used for this purpose. If the refrig has been running a long time, this area can become rather hot.
Aug 01, 2010 | GE Refrigerators
My refrigerator and freezer working fine,but the door jam between freezer and frig gets very hot can anyone tell me why ?
Either the fan which cools the coils and compressor , behind the rear panel behind the refrig , is not working ( or something is caught in the fan blade ) , or , the coils under the refrig need cleaning badly .
Jun 19, 2010 | Whirlpool ED2FHGX Side by Side...
The front of our refrigerator where the doors rest when closed is hot to the touch. Also, it seems to run more frequently. What could this mean?
the area the door rests on is normal to feel warm. it has a heater to keep it from getting condensation around the doors. Some models have a switch on the inside to turn this off. It usually says something like energy saver. As far as it running more frequently, Could be several things that would be hard to diagnose without seeing it.
Jun 18, 2010 | Whirlpool 25.3 Cu. Ft. Side-by-Side...
Ice melts, then refreezes. Rubber Is HOT
Pull the refrig out , and remove the back panel . Is the fan that cools the compressor working ? Is the coil roll clean ? If the fan is not working , then the problem is probably the main control board . Behind the 8"X10" panel , above the compressor area . Remove the cover , and look for a burnt resistor , just to be safe . If this fan does not work , then the coils and the refrigerant line running between the doors , will get very hot .
Sep 26, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer cold /refrigator warm . we have a side by side unit a couple of years old the freezer seems to work fine but the refrigator is warm .It don,t seem to make any funny noises and the back is clean
When the compressor is running, if the fan by the compressor and the fan inside the freezer are both running, and there is no frost on the back wall of the freezer (if there was frost would indicate a defrost issue) then check the air dampener. It is located at the very top left back side of the fresh food section. If it is not opening up, no air will flow from the freezer compartment (where all the cooling takes place) into the refrigerator section.
Jul 04, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
The 2" panel between the doors on my whirlpool refrig are extremely hot...Help
it is suppose to be warm but you want to check you condensor fan in the back on bottom if it is running then clean your coils underneath with a brush or maybe air
Dec 28, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
WARM REFRIGERATOR
Check the freezer side back wall, do you see Ice forming on that wall?
If so you have a defrost issue. Also check to make sure you fan in the freezer side is running. If not, than cold air from the freezer cannot make it to the fresh food side.
I am factory authorized for Frigidaire Appliances and am confident I can assist you in this repair.
Bill
May 12, 2008 | Frigidaire FRS3R5EMB Side by Side...
Refrigerator/Freezer not cooling
check freezer for frost build up and if fan blowing, check condenser make sure clean, and fan blowing, by compressor Make sure compressor is running and not shutting off on overload.. u said comp. hot.. should be warm... Not hot check vents in refrig. make sure no blockage, freezer control should be in the middle setting, you can try turning that to Warmer freezer allowing MORE air to refrigertor side.
Sep 04, 2007 | Kenmore 50522 / 50524 Side by Side...
Frigidaire FRS3R5EMB Side by Side Refrigerator Logo
219 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
