Question about GE Profile Spectra JGBP90 Gas Kitchen Range
My oven turns on, however, it takes a long time for it to bake anything. It does not seem to be getting hot enough. I have noticed that it makes a humming noise when I turn it on. Help please!!
  • GE Master
  • 43,501 Answers
Just because it glows that does not mean it is not bad...
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Posted on Sep 07, 2010
My kenmore slide in oven gets warm but doesnt get hot enough to bake anything
If your electric oven is taking too long to heat or just not heating up right,then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Aug 25, 2011 | Kenmore Ovens
Pilot light stays lit but oven will not stay lit
I would be interested to know just how long it is that the oven does stay lit. All ovens, gas and electric, cycle off and on throughout a baking cycle, to maintain the proper temp. If the flames or the power to the element were to stay on at full power for the life of the food's required time in the oven it would most likely wind up charred. The temp would simply continue to rise, up and up and up. If that's what it appears to be doing, then it's just working normally. If it goes out completely and stays off, doesn't come back on in a few minutes, then it may be in a keep warm mode. Many ranges have a TIMED BAKE cycle available, so you can set the clock to start the oven at such and such a time, cook the food and then shut off. Once it's finished with the cooking cycle, it goes into a keep warm mode, where it will come on for a short time and then go off, to maintain about 180 degrees. Not hot enough to really cook anything anymore, but hot enough to keep it warm for you when you get ready to eat.
If this seems to be the way it's acting, then look for the timed bake function on the console and set things back to a manual mode.
Apr 22, 2011 | Kitchen Ranges
I turn the oven to 350 degrees and it never gets hot.
First, I guess we need to define hot. If you mean hot enough to bake whatever it is you wanted to bake, then it's possible, if this is a unit that has a "timed bake" feature, that someone neglected to put the control back in manual mode, after having used the "timed bake". If this happened, then the oven will only heat to 160 - 180 degrees, and will maintain that temp. It's called a keep warm setting, which is designed to keep the food that was recently baked, warm, until someone can come get it out and served. Check this feature if you have it and see if it's in manual mode, if not change it and the oven should heat up to 350 and beyond.
If there is NO "timed bake" feature, and there's some heat, just not enough to get to a bake mode, then it's possible that the oven's ceramic glo igniter is cracked and not heating to the point that it allows the oven's safety gas valve to open for gas flow to the burner. If there's no heat at all, the problem could still be the igniter, but it could also be electronic control box feeding the igniter. These things must be checked by a tech with an ohmmeter, and possibly replaced.
Mar 24, 2011 | Ovens
Oven not heating
Your ignitor is weak. Change it.It should be very bright ,if it is dim it is weak.
Jan 19, 2009 | GE JBP24 QuickClean Electric Kitchen Range
Oven Makes large bang sound when on
Hello it is time to have a tech out to change the glow bar for bake. When these parts start to fail they dont get hot enough quick enough.
Dec 23, 2008 | Kenmore 33169 Gas Single Oven
Nu-Vu oven will not reach bakeing tempature?
HELLO IM A OVEN TECH AND SEEMS THAT YOU MAY HAVE A FAULTY ELEMENT DEPENDING ON THE MODEL YOU MAY HAVE TWOO ELEMENTS ,ONE IS GONE ,
Jul 10, 2008 | Nu-Vu NUV-MDO11 Stackable Deck Oven 1...
Electric Oven not getting hot enough
Sir, I think the top oelement is for broiling ONLY. It should not turn on when baking. The clicking may be the oven heating up.
How far apart were the oven temp instrument and the digital?
Don't expect them to match...they are inaccurate.
1. Heat water until it boils. Place digital therm in boiling water until it comes up to 212deg. If it is not at 212 in boiling water, record the error.(this gives a rough calibration to the digital)
2 Turn on oven, set to 350 deg, place digital therm on rack. Wait until oven reaches 350 (on stove) and read the digital. Note the difference between the two
Mar 30, 2008 | GE Profile Spectra JBP95 Electric Kitchen...
there are relays on the oven control that turn the elements on and off, sounds like you need a new control
Feb 05, 2008 | GE Spectra JBP78 Electric Kitchen Range
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
179 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
