Question about Horizon T92 - Treadmill
My horizon we had a power surge An now the motor doesn't work But the display works an the Elevation part works , try the Reset by the switch but it feels like there's Nothing but air behind the switch.
  • 79 Answers
Check the brushes on the motor or may be the controller motor board some one Diode or Mosfet it´s damage
Posted on Sep 07, 2010
What is error 7 message pop up on treadmill screen
plelase see this 2 alternatives error and proceed see the diagram attached. God bless you
E7- 1) Alternative Elevation Motor
1)Cause: Elevation Motor not moving Solution:Check Elevation Motor connection
2)Cause: Elevation Elevation Motor screw binding Solution: Clean screw and lubricate
3)Cause: Elevation Motor Motor out of Range Solution: Check motor out of elevation
4)Cause: E-Motor Potentiometer: Solution: Replace Elevation Motor
2)Alternative:
Display Doesn't Light Up: a)Cause: On/Off switch Solution: Test unit is turned on b)Cause: Insufficient Power Source Solution: Plug dedicated120V, 20Amp Outlet
c) Cause: Line Cord Damaged Solution: Replace Line Cord
d)Cause: Fuse Solution: Check Fuse on MCB
Jan 21, 2013 | Horizon Exercise & Fitness
Error code e7 on trojen staminia 310 - already tried switching off and on again. I washed machine and mistakenly got the motor wet.
see the next steps. God bless you
ERROR CODE # 7
2)Alternative:
Nov 16, 2012 | Exercise & Fitness
I have a Horizon QuantumCS 11 HRC Pacer Treadmill and I am getting E7 flashing when turned on,belt moves for seconds and then stops
please follow the steps and fix it. God bless you
2)Alternative:
Nov 15, 2012 | Exercise & Fitness
I HAVE POWERTREK STRIDER IS NOT WORKING WHAT WILL I DO
see the next causes and remedy and fix it. God bless you
ERROR CODE # 7
2)Alternative:
Nov 13, 2012 | Treadmill Doctor Nordictrack Powertread...
E 7 error
1) this means 2 alternatives.
2)Alternative:
God bless you
Nov 07, 2012 | Exercise & Fitness
What means error 07 by HAMMER walkrunner? how can i resolve that?
means 2 options:God bless you
ERROR CODE # 7
2)Alternative:
Oct 08, 2012 | Hammer Walkrunner Rpe Treadmill
What does E7 mean on Lifespan TR4000i?
see the 2 alternatives that the error code 7 means:
2)Alternative:
However RUN the software calibration for diagnostic, troubleshooting and Fix it.
God bless you
Sep 29, 2012 | LifeSpan Fitness TR4000i Folding Treadmill
Incline raises full and wont go down,t84
1)signal false coming console or display board
2) main motor controller is faulty.
3)Pot attached of the elevation motor ,need adjustment
4) geared slip from elevation motor , carring false signal to console.
Proceed to Test it.
Dec 11, 2011 | Horizon T84 - Treadmill
Hi I own the Horizon T605 Treadmill - The treadmill was working fine until we had a power surge and the treadmill stopped working after. My husband believes that it is a fuse. Do you think it could be...
The unit has a circuit breaker near the on/off switch on the front of the machine. The power surge may have tripped this circuit breaker and it needs to be reset.
If this doesn't solve the problem, Horizon's customer service number is 1.888.993.3199.
Hope this helps.
Apr 27, 2011 | Sport & Outdoor - Others
How do I calibrate my horizon t102. I turn it on and the level motor continues to run, the treadmill motor wont come on. I think it is a level sensor that is bad. Where is that located
The "level sensor" is built into the elevation motor assembly, which is a 10kohm potentiometer. What year treadmill? If the elevation motor assy has a small connector with an orange, blue and brown wire set, you can use an ohm meter to read this pot on these leads. It sounds like a loose cable upper to lower, or possibly a faulty motor control bd which controls the elevation. Unplug tread before looking around..
Oct 20, 2010 | Horizon Fitness Horizon T102 Treadmill ...
Horizon T92 - Treadmill Logo
270 people viewed this question
Top Horizon Exercise & Fitness Experts
Electro Med Services...
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Are you a Horizon Exercise and Fitnes Expert? Answer questions, earn points and help others
