Question about Kenmore Dryers
My Kenmore Elite Dryer will not turn on. Checked fuse box. its ok. unplugged and replugged. Still no power to the control panel. Is there a fuse behind the control panel?
  • Kenmore Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Sep 12, 2010
Kenmore Elite Electric Dryer -- Diagnostic for electronic control "Start" touchpad is 09. What does it mean?
i donot know what 9is but i think its the moter switch or moter try switch first
Jul 19, 2013 | Kenmore Dryers
My dryer drum won't turn but the electrical panel is lighting up
it is most likely that the belt inside the back of the dryer is broken or loose.
unplug the dryer and remove the back cover of the dryer. it should look something like this:
although the is for a different make of dryer, it should be similar.
Mar 08, 2012 | Kenmore Elite HE3 Steam 8676 Dryer
My kenmore elite dryer model # 110.63032101 will not turn on. When you push the button in nothing happens. i've already checked the breaker box
Hi
I believe that everything else is fine rather it is the thermal fuse that is located inside the rear panel to the exhaust duct that is bad and should be replaced. If you want you can test this fuse for continuity and if it is bad then it should be replaced, as it cannot be reset. If the fuse is fine then it can be due to the control board that is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Sep 08, 2011 | Kenmore Elite Oasis ST 6806 Electric Dryer
My sears kenmore elite he3 electric dryer wont heat up. I have checked the household fuse, exhaust, and cleaned out the cabinet-all seems ok.
The most likely cause of this is the thermal fuse. It is mounted on the element housing, is inexpensive and easily replaced. It is available HERE for $20.75. It is accessed by removing the lower panel. Be sure to unplug the dryer before removing any panels.
Kelly
Mar 21, 2011 | Dryers
I've got a Kenmore Elite Oasis gas dryer, model #110.77082600 with an F40 code. Followed troubleshooting instructions on the tech sheet: Snugged connectors on wiring harness Measured resistance on the MC2...
Common to find loose connection on control panel. Unplug machine access control panel area and squeeze the connectors slightly to inside good contact. If not then c. Panel is shot.
Mar 02, 2017 | Kenmore Elite Oasis 7808 Gas Dryer
Kenmore elite dryer no pwer
If the dryer does nothing at all, it's probably the door switch. Give it a good look over.You Does the light com on inside when you open the door? Does it appear to have power but just won't start?
Jul 24, 2009 | Dryers
Kenmore Elite Gas Dryer - No power
is the door switch ok? i would check the thermal fuse behind the back panel as well, also check for continuity on the start switch
Jun 26, 2009 | Kenmore 73952 Gas Dryer
Control panel dead
1. Unplug dryer.
2. Remove 2 screws from rear top of dryer.
3. Lift panel assembly up, taking care to not pull wires.
4. Check plugs on circuit board for panel display. Press each one firmly, but carefully.
5. Put back together, plug in, turn on.
Jun 14, 2009 | GE Profile Harmony DPGT750EC Electric...
My kenmore elite he3 electric dryer control panel is not working. When the door is open the light inside is on, but with the door open or closed the control panel above does not turn on or light in any...
The control board is bad. You will have to replace it. You might aslo theck the fuse, sometimes they look a little different than you are used to. Refer to your owners manual and wiring diagram to find it. You can also find more info on the Whirlpool website. Whirlpool makes Kenmore.
Apr 10, 2009 | Kenmore Elite HE3 Steam 8674 Dryer
Kenmore HE2 Dryer makes three beeps but wont start
Check your door closer switch. Mine was doing the same and it turned out to be as easy as changing the switch.
Mar 23, 2008 | Kenmore 62602 Electric Dryer
Dryers Logo
56 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
