Question about Whirlpool Dishwashers
My dishes are not coming clean and when the dishwasher is finished there is still soap in the dispenser.
  • Whirlpool Master
  • 43,501 Answers
There are three common problems that cause the Soap Dispenser or Cup not to open. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
Posted on Sep 07, 2010
The dishwasher is not cleaning my dishes very well and the soap dispenser doesnot open t let the soap out to wash the dishes
heatman101
Feb 09, 2011 | Estate 24 in. TUD5700KQ / TUD5700KB...
Dishes not getting clean! and the soap dispenser rarely opens as it should
make sure filter at the bottom of the unit is sparkling clean. dishwashers do not make miracles...clean excess food remains before putting your dishes in the unit. Use good soap. The 5 in 1 finish are usually very good
Mar 07, 2010 | Ariston Technologies LL64WNA Built-in...
Dishwasher is running but dishes aren't clean
sounds like the top or middle spray arm isn't rotating, most likely a clogged spray arm, try and remove sprayer arm and clean it
Aug 22, 2009 | Kenmore 24 in. 17032 Built-in Dishwasher
Soap
1. You have poor pressure coming from the pump. fix this by removing the racks from dishwasher and removing/cleaning the intake filter to the pump. It is located on the floor of the dishwasher. Use a wet vac if you have it to clean the entire area and anything that might be stuck down in the pump. you would be suprised what you find doen there. Don't be afraid to remove a few phillips screws to remove a cover to the impeller. After this all should work better/cleaner AND soap dish will be washed out too.
2. make sure dishes are not stacked to block the soap dish from water spray arms.
3. remove spray arms and clean them out, especially the spray tips. Hard objects will stick in their spray tips.
Good Luck
Jul 29, 2009 | Maytag DWU9962 Dishwasher
Dishwasher does not rinse clean
run the dishwasher empty: use 1/2 the amount of soap you usually use in the soap dispenser close it then put white vinegar in the open dispenser and, run the dishwasher
Apr 22, 2009 | Dishwashers
Soap hardens in the dispenser and dishes don't come clean
Either your dishwasher is not getting the water hot enough to dissolve the powder, or you need to switch brands. Try a liquid/gel type of dishwasher detergent.
Try stopping the washer a few minutes after you start a wash cycle. Open the door -- if there is a lot of steam coming out at you, it's not the water temperature. If there is no steam, your dishwasher is not getting hot water and/or the heating coil is not working.
Dec 09, 2008 | GE 24 in. Profile PDW7800 Built-in...
Dishwasher Issues
I would try using a different soap or less of your current soap.
Jun 21, 2008 | Maytag 24 in. MDB4100 Built-in Dishwasher
Dishes not thourghly cleaned on top sheelve
generally dishwashers rely on the pressure supplied by the water supply line. check to see if it is enough or if inlet pipe is of sufficient diameter for needed flow.in some instances i know of seperate lines needing to be run directly instead of coming off of supply to sink area.
Apr 07, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Dishes not clean
water valve under dishwasher that let the water come in is not opening all the way causing either low water level or no water to come into the dishwasher. with out the proper amout of water the soap cant be disolved. replace water val to solve problem
Nov 20, 2007 | Maytag 24 in. MDB6100A Built-in Dishwasher
Dishwashers Logo
60 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
