Question about Peg Perego John Deere Gator HPX Ride on Toy
How to move seats. also how to get manual - Peg Perego John Deere Gator HPX Ride on Toy
    Genius:
  • Peg Perego Master
  • 1,508 Answers
You have to flip the gator on its side then you will see four red knobs underneath loosen those and then move the seat to the desired position then tighten the knobs, and here is the manual http://us.pegperego.com/admin/archive/manuals/JD_Gator_HPX_ENGLISH.pdf
Posted on Jun 13, 2012
Seat won't move forward, cant get to the rear bolts to remove seat because seat is back as far as it can go is there any way to move the seat manually
You must remove the seat from the power seat transmission then remove the drive motor from the seat transmission, move the seat to the desired position and reinstall the motor to lock it in place. The seat transmission is bolted to the seat mounting bracket/rails.
Feb 01, 2017 | Seat Cars & Trucks
How do I manually move my driver seat in Lincoln mark 8
if it is an electrical operated seat you don't manually move it . check fuse relay and for a wire unplugged under the seat.if manual seat it has a rod or lever under the front edge to move forward /back
Aug 12, 2015 | Lincoln Cars & Trucks
How to move power seat forword manually
Remove seat from slide assemb ly 4-6 bolts
May 11, 2015 | Seat Cars & Trucks
Manually move power seats
Not really a cheap way to fix it. You have a motor and cables that turn to move the seat. The motor and cables would need to be removed to allow the seat to move, then there would be nothing to keep the seat in place unless you put the motor back.
A manual seat uses a latch and slotted track to move the seat and lock in place.
Apr 24, 2013 | Buick Regal Cars & Trucks
Powerseat switch does not work on 1993 bonnivillehow to manually move seat or jump switch out
Get another switch from a junk yard. the seat will not move manually. If you're going to try to jump the switch it's easier to just replace it.
Dec 23, 2012 | 1993 Pontiac Bonneville
Passenger seat jammed won't move backward
Should be a coat-hanger type hard steel wire running from lever to move seat to move 2 levers, one on each side of seat and this allows it to travel on a toothed track.  Could just be dirt and stuff lodged in this track.  Move these levers out and seat will move but both levers have to be moved to move seat - if spring is off on one side will only move on one side.  Just reach under with light and manually move these levers and push on seat.
Jun 09, 2010 | 1998 Chevrolet Cavalier
Can u move a power seat in a Lexus is300 manually
Ther is no way you can roll it back manually , but you can try to check fuses .
If they Ok , it might be the seat switch itself.
Jun 02, 2010 | 2003 Lexus IS 300
How to manually move power seat in 1997 villeger
They do not move manually unless you remove the cables under the seat and have something to turn the cables to adjust the screw nut jacks that moves the seat
May 26, 2010 | 1993 Mercury Villager
Peg Perego John Deere Gator HPX Ride on Toy Logo
42 people viewed this question
Top Peg Perego Toys Experts
romney2012
Adam Fjeld
Adam Fjeld
Lawrence Oravetz
Are you a Peg Perego Toy Expert? Answer questions, earn points and help others
