Question about Bose LifeStyle 5 Series-III CD Shelf System
No sound Lifestyle 5
Hi David
I have a Lifestyle 5 which suddenly stopped producing sound from the speakers. The headphone jack still works OK. I saw on another post that you might have a fix for this. Something to do with the system not switching the sub on!
Any assistance would be appreciated
Regards
Bruce
My ose lifestlye 5 has just stopped working were can i take it to get fixesd
Posted on Nov 18, 2008
  • 12 Answers
Hi the problem could be a burnt out R428 resistor replace with a 330 ohm
Dave
Posted on Oct 14, 2008
The speakers no long produce sound after using the headphone jack,,disconnected jack , still no sound
When you plug in the headphones, the jack itself routes the signal away from the speakers. When you unplug the headphones, the jack has contacts that close again, routing signal to the speakers. If the jack contacts are dirty, they won't close correctly. I suspect were you to clean the contacts, you'd solve the problem.
Feb 25, 2015 | RCA Rt2760 Home Theater Receiver
Suddenly there is no sound in the speaker but headphone works fine..laptop is Lenovo B575
If the head phone jack works its more likely to be the problem, if you use the headphone jack a lot the connections inside it can get worn or bent out of shape--engaging the headphone jack should shut the speakers in the unit off.
Other possible reason is a bad speaker or connections.
Dec 14, 2012 | Lenovo B575-1450A5U - IdeaPad Laptop / AMD...
Audio from laptop speakers is fine, headphones are not.
Do these headphones work OK in another machine??
If not they are faulty / If so then sound port may be faulty.
'Ensure it is enabled in BIOS. press DEL key when booting and look for similar.
Mar 23, 2010 | Dell Vostro 1510 Laptop
My laptops speakers stopped working
Have you tried a pair of headphones to see if they work?
Is the sound ouput muted? (a lot of laptops have a physical button to
do this...
check to see if the laptop is muted. Also, check the
volume control to see if everything is up where it should be, including
Speaker Out.
If I've got this all straight, the only thing that it can be is an
issue with the plug on the speakers and the jack on the laptop.
Obviously the computer is putting out sound to the headphone jack as
evidenced by your ability to listen through headphones. The speakers
work on another computer. So, it has to be something specific about
the Speakers on this laptop. Plug/Jack problem is the only thing that
comes to mind.
Jun 24, 2009 | HP Compaq Presario 2500LA Notebook
Left speaker gives no sound
There could already be a problem with the speaker jack, if only one channel is consistently giving no sound on your system.
Try turning the male (connected to speaker wire) jack and you might hear a static crackle while doing this. If you get both channels to produce sound this way, you already have a failing audio jack, and may need replacement later on.
Hope this helps.
Jun 07, 2009 | MSI PM8M2-V Motherboard
Fix to issue where no output from fixed outputs but headphone output works
07e570b.jpgI took a picture of the board on my Lifestyle 5. Could someone point out which is R428? Thanks.
Nov 18, 2008 | Bose LifeStyle 5 Series-III CD Shelf...
No sound from X-530 speakers
unless you are capable of replacing the jak on the speaker u need a new pair. the wiring functions the the jack which is now broken
Sep 30, 2008 | Logitech X-530 Computer Speakers
Trouble with Speaker 5.1 +Vista + Asus P5k Motherboard. No Rear Speaker sound
Hi Perseo,
If you run through a speaker test in windows, and hear playback from all 5 speakers and the subwoofer, then your system is correctly connected, and working properly.
Vista uses a layered sound system that renders sound a bit differently than what you're used to on your previous system. As a result, it will most often refuse to project stereo sources in 5-channel surround, on it's own. it will just play them as stereo, and the bass will fill in whenever it can.
One possible way you could use to get around this, is to force the system to use all 5 speakers, through the driver. If you're using a realtek onboard card anything like mine (I have a p5k-VM board myself), this can be done by opening up the HD Audio Manager, and selecting the "Speaker Fill" option, under the Speaker Configuration" tab.
another option would be to load your media player you use to play music or movies, and see if there's an option to change speaker settings within the programs.
hope this helps!
Dec 30, 2007 | Logitech X-530 Computer Speakers
Stopped consistently producing sound
Try plugging and unplugging a pair of headphones. The headphone jack in these receivers are flaky and sometimes think there are headphones hooked up even when there isn't. Full repair would require the headphone jack to be replaced. If you don't use headphones at all, you can take the top cover off and unplug the cable going to the headphone jack board and eliminate the problem that was as well.
Mar 01, 2017 | Denon AVR-1603 Receiver
Bose LifeStyle 5 Series-III CD Shelf System Logo
330 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
