Question about Xerox CopyCentre C20 Black and White Copier
The screen reads scanner locked, what do I need to do?
  • 33 Answers
There is a light green colored tab or lever under side of the scanner. Look carefully. Slide it to another position. I remember there is "locked" text or a symbol of a padlock.
Switch power off then back on after you've done the unlock task.
Posted on Sep 07, 2010
How to add fingerprint scanner to screen lock
Hi, here is the way to set a lock screen password or fingerprint scan on the Samsung Galaxy S5 :
  • Swipe down from the top of the screen and tap the settings gear icon in the top-right.
  • Tap the Lock Screen icon that should be near the top, in the Quick Settings section.
  • Tap the Screen Lock item at the top of the following screen.
  • Tap the unlock mechanism you would like to use: swipe (a quick left-to-right gesture), pattern (where you draw a pattern on a 9-point grid which must be recreated to unlock), fingerprint (which uses the fingerprint-scanning home button at the bottom of the device), PIN number, or a regular text password.
  • Each one of these methods have their own set-up process, which is presented in the following pop-up windows. Most methods will require you to enter the code twice, and sometimes you'll need to include an alternative password for when the primary method doesn't work.
  • After setting up your unlock type, scroll to the bottom of the Lock screen section, and tap Lock automatically in order to set how long the Samsung Galaxy S5 waits after a screen has shut off to require an unlock password.
If you need to update your fingerprint scan or authorize additional users, find the Finger Scanner section within settings. From there, you can also set an alternative password.
Be sure to check our tips on keeping the screen active too, as well as our other Galaxy S5 help guides. There's also the Galaxy S5 forums if your particular issue isn't solved there. And be sure to read our complete Galaxy S5 review!
Personally, I'm a big fan of the fingerprint sensor, though the ergonomics don't always work out for everyone, and sometimes it takes multiple swipes to work. What's your favorite way of unlocking your device? How long do you set your lock timeout for?
RFID Solutions RFID Software Solutions JakinID
Nov 01, 2014 | Office Equipment & Supplies
Getting original display back
Hi Steve,
read the user manual very carefully, it will show you step by step instructions on how to use your scanner.
Before you do anything else, turn off the scanner and remove the batteries, leave it off for at least 1 hour, to allow the scanner to reset to factory default status, yes it means you will lose any frequencies you may have programmed in, but if you're a radio buff like me, you would have a hard copy of your favourite frequencies somewhere safe.
Once you have read the instructions, get your scanner up and running again, you should fin the default screen is back again, and you can use the manual to get you up and scanning the right way without locking up the screen.
I hope this has been helpful.
Cheers,
Peter
Jun 27, 2012 | Uniden Bc95xlt 200 Channel Scanner
Hello, I have a Canon MP810 printer and the screen shows there is an error with that number: 5020. It says that I have to unlock the locker of the scanner and then restart. I have done it many times...
I have just read it on the other forum..try this one
Error Code 5020:
Scanner lock switch locked. [5020] Release the scanner lock switch and turn the power
off and back on.
Turn the machine off, unlock the scanner lock
switch, then turn the machine on again.
Hope it helps.
Sep 09, 2011 | Canon PIXMA MP810 All-In-One InkJet...
My pro-95 scanner screen reads all channels locked out! How do I get it back to working mode.
hello firstly select the mode and bank number ,press and hold L/o button this will unlock all channels and ready for programming you will notice that the L/O button is now removed from the screen
goodluck
Apr 19, 2011 | Radio Shack Pro-95 Handheld Scanner
How to unlock my M20i scanner
Release the lock, down the scanner is a tiny plastic piece between the oupt tray (the place where the paper goes out) and the top of the scanner
Fosg2000, Rate me please
Mar 16, 2010 | Xerox WorkCentre M20i All-In-One Laser...
Samsung SCX-4720F reads "SCANNER LOCKED" and won't copy or scan.
the lock is underneath the scanner where the printed paper gets delivered. when you reach in to get a printout you more than likley have pushed it into the lock position. Once you unlock that blue button by pulling towards you, switch off the printer and again switch on the printer.
Jan 06, 2009 | Samsung SCX-4720FN All-In-One Laser...
At the lcd screen you can read this message: "ESCANNER DESABILITADO"what should I do?
The scanner probably got accidently locked. Turn the machine off, unlock the scanner, then turn back on.
Instructions on how to unlock the scanner are found here:
http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE/,/?St=143,E=0000000001181477675,K=8219,Sxi=11,Case=obj(349)
Dec 02, 2008 | Xerox WorkCentre M20i All-In-One Laser...
Problem with lock error
Scanner Locked error shown on screen?2 possible reason, either the scanner unit is faulty or the main board is faulty.
Mar 05, 2008 | Samsung SCX 4521F All-In-One Laser Printer
Xerox CopyCentre C20 Black and White Copier Logo
213 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
