Question about Lands Phones
How do I change the time on the NEC Electra Elite IPK
  • Anonymous Mar 21, 2014
    former employee left and we cannot access VM bcz don't know what her code was. I need to access VM on that particular phone to reset for new employee
  • 84 Answers
  • From the programming extension (usually 100), with the phone idle and handset in the cradle, press the FEATURE button
  • Press 9 #
  • Enter the hour (01-12) and minute (00-59)
  • Press the Recall Key to change the AM/PM Setting
  • Press the Hold Key and continue if you want to change the calendar setting.
  • Press SPKR or hang up. The correct time should display
  • You must change the time from a phone with administration priveleges. This is usually going to be the main phone, extension 100 or 101. That phone must have an LCD display to make these changes.
    Posted on May 13, 2008
    Dtu 16d ringer is off at other stations. I need to get the phone to ring on the other stations.
    Hello, That would be a system ring group programming feature. It would depend on the type of phone system you have. NEC Elite 192, Elite IPK, Elite IPK 2. There are different platforms and this would determine how to program it.
    Mar 04, 2015 | NEC Electra Elite DTU 16D-2 Corded Phone
    How do i make the nec electra professional phone not ring
    I think you have change its internal setting so reset your phone again so its again setup your phone and your problem has been removed like phone ring.
    Nec sv8100 IPK DTerm phones Inlinecom
    Aug 11, 2014 | NEC Electra Elite DTU 16D-2 Corded Phone
    How to change from lunch to day mode
    These phones work on about 8 NEC systems, but for a PRO II, an Elite, and an IPK, the standard code is Feature,80, Feature from one of the two main reception extensions. Don't know the code for a 2000, 8100, or IPK II.
    Jul 11, 2014 | NEC Electra Elite DTU 16D-2 Corded Phone
    What steps do I take to change the time on my NEC DTERM 80 phone system? I have already tried the Feature+9+# as well as the Recall+728 but those do not work. The first gives me an error message.
    • 1 Press the "Feature" key on the phone system's main terminal. This is one of the Dedicated Feature keys and is located at the bottom left hand corner of the keypad.
    • 2 Dial 9# to enter the clock setting menu.
    • 3 Enter the hours and minutes using the key pad. For example, if it is 12:15, you would press "1," "2," "1," and "5."
    • 4 Press the "Recall" key on the bottom left hand side of the phone key pad to toggle between AM and PM.
    • 5 Press the "Feature" key to exit the system.
    NEC Electra Elite IPK II
    • 1 Press the "Speaker" key located at the bottom left of the phone key pad.
    • 2 Dial "728" to enter the phone's clock menu.
    • 3 Dial the hour using two digits. Use military time for any time in the afternoon. For example, 1:00 AM would be "01," but 1:00 PM would be "13."
    • 4 Type the minutes using two digits ranging from "00" to "59."
    • 5 Press the "Speaker" button to set the time
    Read more: How to Change the Time on an NEC Phone ' eHow.com http://www.ehow.com/how_7338757_change-time-nec-phone.html#ixzz1XUGjOOet
    Sep 09, 2011 | NEC Dterm DTP 16D-1 Corded Phone
    How to change time on NEC Electra Elite IPK? I
    You have to be on the root phone or "first phone".
    To check various phones -Hit {feature} 4.
    Should display 100= TEL 01. Once on the first phone then use {feature} 9 #.
    Time will flash at top of display and can be adjusted.
    If you are not on the first phone you will get error at the top of the display. Leave the hand set on the hook.
    Mar 11, 2009 | NEC Electra Elite DTU 16D-2 Corded Phone
    Changing amount of rings when going to voicemail
    The call forwarding was turned off. To turn on, press speaker, enter 793, press 1(for set), press extention number, and enter 300. If you have call forwarding on and are looking for more rings, do the above steps except press 2 (for clear).
    Nov 19, 2008 | NEC Electra Elite DTU 16D-2 Corded Phone
    Have NEC D term 80 phone without manual
    The manual is here.
    NEC doesn't call it the "Dterm 80 manual," but that's it. It's titled "Electra Elite IPK II Multiline Telephone User Guide."
    May 02, 2008 | NEC Dterm DTP 16D-1 Corded Phone
    Lands Phones Logo
    486 people viewed this question
    Top Lands Phones Experts
    Are you a Lands Phone Expert? Answer questions, earn points and help others
