Question about Husqvarna Chain Saw 20" Bar
Start up good and run good , or later on it start stumble and die out
    Problem Solver:
  • 11 Answers
1. your vent for the fuel tank may be clogged
2. your ignition coil, when the saw warms up, the blades inside the coil heat up and separate causing loss of ignition
3. fuel delivery may be an issue, your fuel filter or carburetor need to be cleaned
4. possible air leak
5. your saw could have possible slight scoring and when the saw heats up and the jug/cylander swells you could lose compression
There are many other possibilities, depending on where you are located, we would be more than happy to take a look at your saw to diagnose the problem. if you are outside of CT we can have it shipped. Please call 860.233.5439 x222 Butler Power Equipment.
Thank you!
Posted on Sep 06, 2010
My vehicles shuts off after 3 three minutes of use or when its idling after first initial start but starts perfect when the engine is heated up. Can you help me with this problem?
Car starts then dies in a few seconds - CarGurus
www.cargurus.com > Questions > Ford > Crown Victoria
CarGurusFeb 3, 2014 - Engine turns over fine and starts, but stops in a second or 2. ... Good fuel pressure, starts, runs for about 7 seconds, dies after a sudden drop in fuel pressure. ...starts 15 minutes later, runs fine then stumbles and dies again 3 answers ... I drove carhome shut off and next morning would not start, but will turn ...
94 camry le 4cylinder starts when cold, shuts off .
Nov 23, 2015 | Cars & Trucks
1989 lesabre stumbles and dies
I agree it sounds like the magnet for the cam sensor, or a problem in the wiring harness.
I don't think the engine will run with the cam sensor disconnected since it needs that signal to set base timing. It can run without the crank sensor once the engine starts.
There is a slight chance the timing chain is getting loose and affecting cam timing too. You may be loosing plastic teeth on the cam gear.
Apr 08, 2013 | Buick LeSabre Cars & Trucks
1990 Grand Prix starts but doesnt run no power stumbles dies
Could be clog catalytic converter.Tune up fuel filter,coils,air filter.
Apr 02, 2013 | 1990 Pontiac Grand Prix
1985 toyota 4runner running too lean
Maybe it's not running lean. Maybe it's misfiring. Since you put in new fuel parts and that didn't help, maybe there is an ignition component that fails when it gets hot. A bad coil can do this, also the igniter-rarely, admittedly, but you could have it tested. When it stalls and won't start, if you check for spark and find none, it would confirm an ignition problem.
I hope you find it. Post back and let us know.
Jul 29, 2012 | Toyota Cars & Trucks
1996 c1500 starts and runs then dies
sounds like a faulty pressure regulator be sure to test it before changing it
Mar 15, 2012 | Chevrolet 1500 Cars & Trucks
I have a 2000 Nissan xterra 4x4 v6 and it recently started stumbling on acceleration. I changed the plugs an wires to see I that helped and it drove fine after that then started stumbling on Acceleration...
Sounds like it might be fuel related,,, get some GOOD injector cleaner,, mix generously..run it through two tanks worth.. then change the spark plugs...(the crude it removes gathers on the plugs sometimes!)
Jun 06, 2017 | 2000 Nissan Xterra
No codes but engine stumbles and dies
either its vapor locking or its the fuel pressure regulator
Sep 01, 2009 | 1999 Chevrolet Silverado 1500
The car when hot or cold may stumble and/or die at a stop sign and it may also do it going 70 mph down the road. It will catch itself and start running.
This may be the early sign of a blown head or gasket. Check your coolant to make sure it doesn't have oil in it or appear to be oily. This is the first thing that I would check.
May 16, 2009 | 1996 Ford Thunderbird LX
Propane-converted generator sometimes sputters out and dies
I believe the problem may be with the propane. Have him call his propane provider and get them involved. good luck
Dec 26, 2008 | Coleman Powermate Premium Plus 6250W...
Husqvarna Chain Saw 20" Bar Logo
47 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
