Question about GE Energy Star SDL20KCSBS Bottom Freezer Refrigerator
Refrigerator won't stop clicking - GE Energy Star SDL20KCSBS Bottom Freezer Refrigerator
  • GE Master
  • 43,501 Answers
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Posted on Sep 06, 2010
2012 open range refrigerator is closed but won’t stop beeping. It is acting like it’s open. Please help. Thanks.
I would look for some sort of door switch that is not engaging. There has to be something that tells the unit if the door is open or closed. This is the simplest and cheapest place to start.
Apr 28, 2018 | Refrigerators
Water stopped coming out of door dispenser
A few videos about refrigerator water dispensers.
Might not be exactly the same as yours.
Samsung won dispense water YouTube
Oct 05, 2014 | Samsung RF4287HA
Fridge freezer door won'tstay closed
Faulty door seal.The seal that holds the door has a grip and a magnet on other side.May be that needs to be replaced.Or any fringe section tray is not completely fitted,to its end causing these.
Replacement parts can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
partsselect.com
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 24, 2012 | Frigidaire Refrigerators
Water won't stop coming out from the cold water dispenser
The cold water dispensing valve can be stuck or defective. Sometimes jiggling the valve can make it stop running
Sep 30, 2012 | Whirlpool 25.3 Cu. Ft. Side-by-Side...
Danby DPR2262W propane refrigerator stopped cooling
OK-to make this short-you either have a boiler tube blockage or Hydrogen diffusion.If your cooling unit quit suddenly,you more than likely have a boiler tube blockage due to precipitation of Sodium Chromate.If your cooling unit gradually quit working it's Hydrogen diffusion.This process is not easy to understand,and I won't bother you with the details as to why.By the way,burping is a myth,it dosen't work.If there is a blockage in your cooling unit turning your refrigerator upside down won't dislodge it.Danby dosen't make stand alone Propane refrigerators anymore,and since the cooling unit is foamed into the box,it's a throw away refrigerator.You will have to get a Servel RGE 400 made by Dometic.It's the same size as the Danby and I have those for a very good price.Go to: www.marvinspropanerefrigerators.com
Aug 20, 2012 | Danby DPR2262 Top Freezer Refrigerator
Won,t freeze frig won,t get cold
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Sep 18, 2011 | Roper RT21AKXKQ Top Freezer Refrigerator
Fridge makes a clicking noise everything in freezer melted and fridge won't cool. Model number ED5VHEXVQ03. I replaced the starting relay but not the resistor. Problem is the same still clicks...
heatman101
Aug 31, 2011 | Refrigerators
I have a HYUNDAI TUSCON 2006, My compressor is working for 3-5 seconds only then it stops for 45 seconds again it works for short and stops again, morever air flow is weak and not cold.
Constant clicking of the compressor is an indication the system is low on refrigerant. Most vehicles require a minimum of 2lbs of refrigerant to power the compressor. The constant shutting off is a safety measure to protect the compressor from burning out. Most service stations do AC service now. They will typically run a leak detection test to find where the refrigerant is escaping. They won't usually "top off" refrigerant due to legal restrictions. If you're somewhat handy, most auto parts stores will sell you a refill kit that includes refrigerant, oil, and a hose.
May 14, 2011 | 2006 Hyundai Tucson
My minifridge won´t start. It just stopped, just like that, it´s fairly new, not much use, what could it be?
Check the main power, check if power comes to the main relay , does the relay click, doe the volatge flow to the motor, if motor is humming and hot , then the main capacitor is faulty.
Take this check in a sequence, the relay is normally mounted on the compressor assembly, can be pulled out and checked. take care of live power. Set thermostat to high settings to switch on.
Sep 18, 2010 | ThermoKool MR-128 Compact Refrigerator
GE Energy Star SDL20KCSBS Bottom Freezer Refrigerator Logo
100 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
