Question about IBM 4610 TG4 Thermal Label Printer
Both lights are green but flashing??? - IBM 4610 TG4 Thermal Label Printer
Sx30is flash off position. I would like to take a picture in low light without a flash. The camera emits a green light as a warning that the flash is off. I would like to not have either the flash or...
The reason the camera has the green light is not to warn that the flash is off. The green light is used to help the camera auto-focus in low light situations. If you disable auto-focus and use manual focus the green light should not flash when taking the picture. Let me know if that helps!
Jul 10, 2011 | Canon PowerShot SX30 IS Digital Camera
Zanussi zwf 1430s,power going to machine but when button pressed green light does not come on just a red light nothing on display panel
Count how many times the red light flashes and how many the green light flashes.If its 1 green and 1 red thats water problems.If 2 flashes of red light check filter is clear and pump is free to turn.
Hope this helped.
May 18, 2010 | Washing Machines
The red light is blinking and it doesn't print.
There are actually some certain meaning on the red light and green light showing different information to user. The summaries are:
1) Green On, Red Off = Printer Ready.
2) Green Fast-Flashing, Red Fast-Flashing = Printer warm up.
3) Green Fast-Flashing, Red Off = Printer off-line.
4) Green Slow-Flashing, Red Off = Processing Data.
5) Green Off, Red On = Cover Opened, Toner Empty or Developer Unit / Drum unit missing.
6) Green Off, Red Fast-Flashing = Paper Jam or waiting for jam reset.
7) Green Off, Red Slow-Flashing = Paper Empty or Paper tray is not inserted.
8) Green Off, Red Off = Printer power is off.
9) Green Very-Slow-Flashing, Red Off = Printer in sleep mode.
10) Green (any condition above), Red Slow-Flashing = Toner low or paper empty.
So what is your printer condition? Better know what is going on your printer so can solve the problem.
Oct 02, 2009 | Kyocera FS-920 Laser Printer
CANON I350 DOES NOT PRINT
Green and yellow is a service error, but it flashes a longer green, and then the green yellow flashes, and a longer green again. You need to count the number of yellow-greens in between the longer green flashes, to know the error code.
Sep 17, 2009 | Canon i350 InkJet Printer
Kyocera fS-920KX. Not printing
YBC (/\)
Jun 01, 2009 | Kyocera FS-920 Laser Printer
Kyocera Ecosys FS 920
YBC (/\)
Mar 24, 2009 | Kyocera FS-920 Laser Printer
Panasonic PT-LB10SVU green light flashing,then orange,lamp light
i just replace the lamp, and don't have any light coming from lens,starting green (after a few seconds,green become to flash2_bing.gif), then turning on orange and lamp light flashing...please i need help, fan working perfect...i don't have a remote,is a problem, or not
Feb 25, 2009 | Panasonic PT-LB10SVU Multimedia Projector
Flashing device status light
Ok the lightning bolt is your power indicator: solid green-charging, Flashing green-fully charged, flashing red-low battery, flashing red three times the once green-bad battery. the "trash can" looking one is your hard drive activity indicator it will flash while your hard drive is reading and writing.
Nov 20, 2008 | Dell Latitude D600 Notebook
No 'green' light on bacl of my 'old' Vivitar 285
Then I'd say it's a reasonably sure thing that the green light is just burned out, The lights are supposed to be off at first, then red when there's a partial charge, then green when there's a full charge, then flashing between red and green when the "battery saver" kicks in. If you're seeing off, then red, then off, then flashing red, then that means everything in the charging circuit is working perfectly, there's just no green light.
Nov 30, 2007 | Vivitar 285HV Flash
IBM 4610 TG4 Thermal Label Printer Logo
123 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
CheckitRight
CheckitRight
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
