Question about Whirlpool LTE5243D Top Load Stacked Washer/Dryer
Whirlpool thin twin
The washer basin seems to have fallen off of the track, how can you get it back on
  • lancerlots Nov 10, 2008
    Can anyone give me step by step instructions? I am a student and am pretty bright so I think I should be able to do it myself, but I do not know the first thing about repairing washers.
  • 1,122 Answers
Posted on May 29, 2008
LG HE Washer model WM2010c, the unit was in spin cycle and bounced accross the room! Now the washer works but the basin is on a slant with the back end lower than the front!
Go to and enter WM2010c. You will be presented with a list of common replacement parts and may be able to view a generic LG video showing disassembly.
Feb 02, 2017 | LG Washing Machines
We used it then turned it off and went to turn it back on but wouldnt do anything.latches are locked and has water in it. im getting power to the switch
E series vacuums have a safety switch underneath the motor unit to insure the water basin is on. You can see the part here and where it is located (left of the separator)
Rainbow interlock plunger
Sometimes this part may have fallen out and gotten lost when you were putting your vacuum away, or your water basin where it would depress this switch broke of.
If your motor is good and power nozzle is good, it may be this.
Mar 24, 2014 | Rainbow E series Canister Wet/Dry Vacuum
Overflowing Washing Machine, water does not stop filling, overflows to floor. This is a Whirlpool Thin Twin Stackable
sounds like you have a bad water level pressure switch part 3362987
go her part number 10 in diagram or there could be something in the hose,the hose could have fallen off or could have a hole in it,i can't find a video with a stack machine but this explains your problem
Mar 30, 2013 | Whirlpool LTE5243DQ Combination...
My whirlpool duet washer front loader wont wring out the clothese properly. We have replace the drain pump and cleared all the hoses and filters. It also doesn't seem to go in to real fast spin.
First, make sure your machine is not overloaded. Overloading will not allow the machine to spin out properly. Also, make sure its fairly level. Next, make sure that all the shocks on the drum are properly attached and in working order (after you pull off the access panel, the shocks are readily visible -- there are typically 4 of them, 2 in front, 2 in back). Their heads slip into a slot and then twisting them locks them in. Finally, I would pull of the drain line leading from the drain filter to the tub basin. Once its off, stick your hand up into the basin. All kinds of yuck tends to collect there, semi-obstructing the drain line, which permits more water to remain in the basin, which doesn't allow your machine to spin as quickly as it otherwise would.
Feb 24, 2013 | Whirlpool GHW9100L Front Load Washer
Drum inside washing machine seems to come loose..making a really loud banging noise. Whats the best way to fix this.. Whirlpool Thin Twin
Might be a spring or the skate plate out of alignment.
Thin twin service manual is in this apartment series service manual:
Sep 18, 2011 | Whirlpool LTE5243D Top Load Stacked...
Dryer has stopped producing heat
I have a Thin Twin manual that will give you an idea of where to start:
Jul 12, 2010 | Whirlpool WHP1500S Electric Dryer
Rear power window has fallen off track on 2004 jeepcan the door panel be removed and replaced without special tools
Yes. But it is not as simple as putting the window back on track. Most new vehicles use a different type of regulator (not the old pinion and rack type gear. Most use a small motor that is attached to cables that raise and lower the window. Most often these cables break and the window falls. Pull the inner door panel off and you can verify. If it is the regulator, check out Amazon. Seem to have the best prices and warrantees. Good luck!
May 20, 2010 | Cars & Trucks
Whirlpool LTE5243D Top Load Stacked Washer/Dryer Logo
357 people viewed this question
Dan Webster
Dan Webster
Sal De
