Question about Dryers
My crosley dryer won't dry my clothes - Dryers
    Problem Solver:
  • 14 Answers
I would say the heating element has gone bad replace it
Posted on Sep 06, 2010
Why would my crosley dryer get really hot but the clothes don't get dry
If the dryer is getting hot (the heater element is working) but the clothes aren't drying, it suggests that there is insufficient air flow through the dryer. Remove the exhaust tube from the back of the dryer. With the tube removed and the dryer running, check for hot air (lots of it) flowing out the exhaust vent of the dryer. If there is good air flow, check the exhaust tube for lint build-up or a clog that is blocking the air from flowing through the tube. If there is no air coming out of the exhaust vent with the exhaust tube removed and the dryer running, it suggests that the problem is with the exhaust fan inside the dryer.
Jul 08, 2014 | Crosley CDE6000 Electric Dryer
Our Crosley CDE6000 electric dryer would shut off midway through a timed cycle w/ clothes not dried. I removed the door and front , then cleaned out a fairly good amount of lint from trap in door. Rep
sounds like your stat (Tod) for short has gone a Tod is what tell the dryer to heat and when to turn off you will have to replace them OK they are right on top of the heater OK hope this have helped
Oct 22, 2012 | Crosley CDE6000 Electric Dryer
I have a model # CDE20P8A crosley clothes dryer that will not start. It has power to the dryer, but the interior light or motor will not work. Is there an internal fuse that I should check or replace?
Yes. It takes an LA-1053 fuse kit. Most of these dryers take way too long to dry the clothes, then the fuse blows because it over heats. The problem being the blower wheel. The fuse itself is attached to the side of the heater and is held there by a clip that is held in place by the long screw that hold the element. Unplug it and take it outside so you can sit it on a table to work on it.
To get inside release the clips
It won't do any good to replace the fuse if ya don't check the blower wheel.
They strip out and get loose on the motor shaft.
Aug 01, 2011 | Crosley Dryers
Crosley cde22bgv, gets warm but won't blow right. Takes about 4 hours to dry a load of clothes.
check make sure the vent is not stopped up and that the blower wheel is not lose
Oct 03, 2010 | Crosley CDE6000 Electric Dryer
Dryer does not dry clothes but seems to be hot inside when i open the door
Most of these guys get a bad blower wheel. The heat melts the hub causing it to spin free and airflow is reduced. This makes it take fifty forevers to dry a load of clothes. More Here
Aug 18, 2010 | Crosley Dryers
Crosley Model #CDE22B7V. Clothes dryer only gets
I used to work for a Crosley dealership. The number one problem is gonna be the blower wheel.709b43d.jpggo ahead and pop the top(after unplugging the machine) f11ef2b.jpgGet the front off and then get the drum out. Clean out all the lint. 31001043 is the part number
Apr 01, 2010 | Crosley Dryers
MY CROSLEY DRYER DOES NOT GET HOT AND DRY MY CLOTHES.
most likely the element. to lift the top - slide a putty knife between the top and front , push the two clips toward the back and lift the top. the element is at the right rear. check for continuity with an ohm meter
Jan 22, 2010 | Crosley CDE6000 Electric Dryer
Crosley Dryer Model CEDX463RQ1 no heat
take elements to a dealer and have them checked, unless you have a digital multimeter and can DIY.Otherwise get a replacement element
Aug 01, 2009 | Dryers
Clothes take a very long time to dry
You need to remove the front panel and clean out the lint and replace that bad blower wheelaa0396a.jpg
Feb 21, 2009 | Crosley CDE6000 Electric Dryer
Crosley dryer
Let the machine sit for about an hour and try again. Let me know what happens. Would like to know the reason the motor was replaced.
Jan 26, 2008 | Crosley CDE6000 Electric Dryer
Dryers Logo
43 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
