Whirlpool Heavy Duty XL Capacity Plus LXR9245E01 washer. It got off balance I opened lid and rearranged the towels. It then rinsed on the final spin cycle it quit working and made a horrible screeching sound.
catriver
  • 878 Answers
SOURCE: Kenmore washing machine
Sounds to me like you have a worn drive block and possibly a bad spin tube. The drive block can be accessed by removing the agitator first. Next you will need to remove the spanner nut. Now you can remove the basket. Attached you will see the picture of the drive block, I hope if it downloads. The spin tube locks into this drive block with two tabs that fit in respective grooves in the block. If the tabs are worn off the spin tube, that will have to be replaced as well. Good luck,
Posted on May 21, 2006
  • 1073 Answers
SOURCE: FRIGIDAIRE GALLERY 12 CYCLES COMMERCIAL HEAVY DUTY SUPER CAPACITY 2 SPEED MOTOR
see if you have a pump issue, pump not working something in the pump
Posted on Apr 12, 2008
jumptrout51
  • 3361 Answers
SOURCE: kenmore 82372110 70 series heavy duty plus won't spin
If it drains and won't spin you have to replace the direct drive coupling.
Posted on Feb 26, 2009
jsrock516
  • 5911 Answers
SOURCE: Whirlpool Ultimate Care Heavy Duty Washer will not spin
It sounds like you have a broken motor coupling. This is a very inexpensive and simple repair.
If the washer will fill and drain, but won't agitate or spin, you may have a broken motor coupling. The noise of the motor engaging, lack of agitation and ability to still drain are the usual symptoms. This is a common fail item with this model washer through normal wear and tear. Newer versions of the coupler are more resilient and resist breaking. The following link explains how to replace one:
http://www.fixya.com/support/r385252-replacing_motor_coupling_whirlpool_top
The motor coupling is located between the drive motor and the transmission and takes the place of a drive belt. They do wear out and can break. The replacement part number is included in the link I provided and is an improved upgraded coupling that is more resilient. It should last longer. If you have questions, or require additional assistance, please let me know. I hope this helps you.
A replacement coupler can be purchased on line at appliancepartspros.com for about $11. Just use the part number in the link and "Search by Part Number" for your search criteria.
Posted on Jul 23, 2009
SOURCE: what is the capacity of kenmore washer 70 series
hey ****, just give an answer. keep your lectures to yourself
Posted on Jan 21, 2010
What is the capacity of a front loading whirlpool washer MO#GHW9150PWO
Whirlpool GHW9150PW 27 Inch Duet Front-Load Washer with 3.8 Cu. Ft. Capacity, 8 Wash Cycles & Triple Dispenser.
whirlpool ghw9150pw0 capacity Google Search
Nov 25, 2017 | Whirlpool Washing Machines
I have a Whirlpool Heavy Duty-Super Capacity Plus, 7cycle/2 speed. Model LSR7200EQO , the agitator stopped working
My whirlpool heavy duty 2 speed 7 cycle washer machine stopped working, It fills up and aggitates for the first cycle then when it should drain and spin it doesnt drain nor spin
Jun 05, 2010 | Whirlpool LSB6200KQ Top Load Washer
Washer stopped washing at rinse
Could it be ul? Sounds like it got out of balance. Try opening the lid and rearranging the contents. If you are washing heavy items like coats or big blankets or comforters, be sure to chose BULKY setting and low or no spin. Hope this helps!
Apr 13, 2010 | Maytag Bravos MTW6600T Top Load Washer
Kenmore 82372110 70 series heavy duty plus won't spin
Feb 25, 2009 | Kenmore Washing Machines
Agitator
if its a 2 piece agitator.. the gears in top of agitator is stripped out.. change gears be like new....spin top countor clockwise if it dont grap.. gears bad
Sep 28, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing Machines Logo
145 people viewed this question
Top Washing Machines Experts
