Machine won't wash or spin and won't complete the cycle.
Initailly it was an intermittent problem where the washer wouldn't spin at the end of the load, but not every load. It would make the sound to start spinning but the bowl would only move a few centimetres and then stop.
Now the machine won't wash either. It will fill with water, then send the signal to the bowl to spin (to start washing) but nothing happens, only a humming sound.
  • 975 Answers
SOUNDS like the motor turning bad , if you hear humming and a strange smell ? yes, you might be needing a new main motor, if you can take a look inside while the machine is ON , check the belt to see if not broken , hope this helpful AJ
Posted on May 13, 2008
GE washer won't spin
Sounds like it needs a new motor. Electric motors can develop bad spots on their coils. What happens is they begin to work intermittently or only when hit. This is the same problem with a cars starter motor. Probably a pretty easy fix, just unplug the power to the washer for safety and pull it out and get a part number off the motor assembly then order up a new motor. If you have a multimeter and are comfortable working around live AC voltage to can see if power is being sent to the motor at the power connector.
Jan 07, 2014 | GE Profile WPRE6100G Top Load Washer
The washer will drain but not completely ..leaves a litlle bit of water in machine
Make sure the spin is working. If its not working you wouldn't know it since it spins during the middle and end of cycle.
If not check lid switch
Thank you for using fixya
Leo Ponder
Please rate me if this helped.
Jul 17, 2011 | Frigidaire FEX831CS Top Load Stacked...
Kenmore model # 110.23832100 Washer would drain but wouldn't spin or aggitate. Replaced coupler. Now will spin and agitate, but will not drain.
sounds like it's in the re-assembly since the water pump is directly connected to what you just did. take it apart once again and make sure all is put back right and water pump is properly seated on motor shaft.
Jul 15, 2011 | Kenmore 23822 Top Load Washer
Maytag washer (model PAVT244AWW). Won't spin. Don't know how old it is or its history, as it came with a home we purchased in October. Several times it's "walked" during the spin cycle. About 6 weeks...
Its the clutch ,And it sounds like it time for a new washer,the clutch is expensive and washer are cheap try a second hand store that sale scratched or almost new machines
Jul 05, 2010 | Maytag PAV2300 Top Load Washer
Our older top loading Whirlpool washer skips FILL
It sounds like you have a timer going bad.
Mar 06, 2010 | Washing Machines
I have a Whirlpool Ultimate Care II, top loading washer. Upon intial start up the machine agitates. During the spin cycle, the cold water remains ON, throughout the cycle. This is leaving the clothes wet...
The timer is at fault.
During the spin cycle the timer should send intermittent power to the water valve. This activates cold to help rinse soap residue from the laundry.
If cold is continuous it means the timer is not breaking correctly.
Feb 14, 2010 | Whirlpool Washing Machines
I have a whirlpool ultimate care 2 top load washer no spin
Sounds as if the drive hub which the tub is attached to maybe free spinning. Not an expensive part but does require a special tool called a spanner wrench to remove and replace.
Jan 31, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Spin cycle starts, speeds up, then stops spinning
This fault often occurs when something (like a small coin or a paper tissue) has blocked the drain pump!
The only way to fix this would be to get a service engineer to remove the pump and check for a blockage, unless of course you are an experienced electrician or technician and don't mind doing it yourself.
Nov 18, 2009 | GE WBSR3140DW Top Load Washer
Washer motor spins but the TUB does not (intermittent)
If the motor is running and the tub is not spinning you must remove the motor and inspect the drive coupling.
One of the 2 plastic pieces could be stripped or cracked.
If the drive coupling is intact, proceed to the clutch on top of the transmission.
Replace the clutch linings.
Mar 08, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing Machines Logo
151 people viewed this question
Top Washing Machines Experts
