Question about Toshiba Satellite P205D-S7802 Notebook
Hi I have a Toshiba Satellite p205-S6277 Laptop. When I turn it on it will not boot. The power lights are on, the fan turns on for a minute and the hard drive light flashes for a second. but nothing happens. I have tested my power supply, and checked the memory. What Can I do to fix this?
  • Toshiba Master
  • 1,606 Answers
That could be a cpu problem or a man board error. You should be seeing some kind of error code either flashing leds or a beep. If it shows no code then if the memory is good, it can be the ram connector or the controller. Basically to generate any code the ram has to be good and the board has to see at least the first 64k of it. It will generate the code even with a bad cpu as long as it can use that first small bit of ram.
Swap the ram locations and you should try just one single module at a time. Sometimes heat cycles or vibrations will work the ram loose. So just taking them out and carefully reseating them can fix this problem.
The two normal causes for this on a laptop are a bad cpu that usually has overheated and the first suspect is always ram.
Either of those can be replaced fairly cheap. Past that you are looking at a main board replacement.
From your description the cpu sounds like the probable cause.
Posted on Sep 06, 2010
Testimonial: "Thanks!"
  • cjparker110 Sep 06, 2010
    Thanks for the the response. I swapped the ram into each slot 1 at a time and nothing changed. So I guess I can suspect the CPU. Thank you for your help!
My toshiba satellite p205-s6277 wont restore or configure also it freezes an error that the registry log has nop room
Click Start/My Computer then Right Click on the C drive and select Properties. If it shows zero bytes or that the drive is full and has no free space then that's why it is freezing and locking up. The system has no room to do anything.
May 23, 2012 | Toshiba Satellite P205-S6277 Notebook
I need sound drive for my toshiba satellite p205-s6277
here are the drivers for your sound card. select the best that suits your operating system
1. Driver Audio Realtek for Win 7
2. Driver Audio Realtek for Vista
3. Driver Audio for Win XP
Select and click download.
I hope you find the right sound drivers for your laptop.
Much appreciated if you rate this help..thanks..
May 25, 2010 | Computers & Internet
Toshiba Satellite P205-S6237 won't Boot up after full shutdown
i think there is some issues with the OS because i noticed you can't shut it down properly so maybe the files needed in order to shut down had been corrupted but one more theory, the bios settings make sure that everythings configured properly there by checking the power options on the bios setup(the blue screen)so try setting it to default and change the boot priority to HDD,CDROM,FLOPPY.
Jul 14, 2009 | Toshiba Satellite P205-S6237 Notebook
Toshiba satellite x205-s9800 - Frozen boot screen
hi,
try this one
take out the battery and take out the Ac adapter now press and hold the power button for 15 sec this will release any static charge residing in your laptop.
now try start your laptop with battery in.
Further Queries are welcome
Jan 21, 2009 | Toshiba Satellite P205-S6287 Notebook PC
Need to unlock phoenix bios password for toshiba satellite a135-s4527
remove the keyboard the mobo battery is there you need to unsolder one end of it, lift the leg, and turn it on that way for it to clear.. you will have to resolder once done.. have the skills or find someone that does... and you're set..
Jan 16, 2009 | Computers & Internet
Toshiba saltellite with internal harman kardon speakers, no sound
To solve your problem, please download and install this free software: driverupdate us. It wont take more than 5 min from you to update all needed drivers.
Wish you best of luck
Nov 30, 2008 | Audio Players & Recorders
Toshiba Satellite P205-S6287 woun't start up
Hi
Try connecting external monitor inform me what is happening....
Jul 19, 2008 | Toshiba Satellite P205-S6287 Notebook PC
Toshiba Satellite P205D-S7802 Notebook Logo
449 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
