Question about Gaggia Syncrony Compact Coffee Maker/Espresso Machine
Doesn't power up
My Synchrony mysteriously stopped powering up. I have ensured that the plug is in correctly and tight and I have confirmed that the outlet is good. There has been no power surge as all the other appliances and computer ate all ok. Is there are a reset button or reset sequence?
  • oyray Apr 20, 2009
    it was working fine and then just stoped and now will not even power up
Same problem here, working one minute, lights out the next. No signs of life. Hoping there is a fuse or breaker somewhere.
Posted on Jan 08, 2010
RCA M50wh72s lamp keep blowing bulb
There are a few things that can cause this. First, ensure that the bulb you are installing is the correct one for the unit. Many are similar and the wrong one can cause problems. Second, ensure that you do not touch the bulb\'s glass surfaces with your fingers when handing the bulb for installation. The oils on your fingers will get onto the bulb, causing hot spots and premature failure. Next, ensure that the cooling fan for the unit is working. The bulb generates high heat when operating and the fan provides cooling to ensure the bulb\'s long life. A defective fan will cause bulb failure. Lastly, ensure that when you power the set off you do so with the power switch. This allows the cooling fan to continue to operate for a while to ensure the bulb cools properly. If you remove power at a power strip or pull the plug, the fan stops immediately and the bulb will not cool down evenly.
Sep 07, 2014 | Televison & Video
No power to the stepmill
Start by confirming power at the wall outlet. There should be at least 110v AC at the wall. Also confirm 12v DC output from the power supply where it plugs into the bottom of the machine. If you have power there, I would suggest pulling the side panel and checking the wires just behind the plastic panel, where the power supply plugs into the bottom of the machine. A very common issue with these machines is a simple loose ground wire on the grounding plate. If all of the previous checks provide the correct voltage, continue following power to the relay board and from there to the console. Your problem lies where the power stops. Video about Multimeter Testing
Oct 28, 2013 | Stairmaster Stepmill 7000 Pt
My mr2 86 doesn't crank
Make sure you have a good battery/connections. Make sure you have power down to the starter on the B+ terminal if not replace faulty wire or clean/dirty connectionson ensure connections are tight. While someone turns the key make sure you have power in the S terminal. If power make sure the engine isn't locked up and replace the starter. If no power you may have an issue with the ignition switch circuit (stitch, wiring, fuses....)
Mar 09, 2012 | 1986 Toyota MR2
Errer code 5
1/ Turn off the canon printer
2/ Hold down the Stop/Reset button
3/ Not releasing the Stop/Reset button, hold down the Power button, now release the Stop/Reset button
4/ Not releasing the Power button, double click Stop/Reset button and release both the Power & Stop/Reset button - doesn't matter in which order
5/ Click Stop/Reset button four times
6/ Click the Power button to confirm the selected action (reset counter absorber)
Aug 02, 2011 | Canon PIXMA MP160 All-In-One InkJet...
My speakers are plugged into the computer they're power is on and they are'nt working
You must confirm that they are plugged into the correct output and also into a power source. If they are powered speakers it can either be the audio out or the headphone jack, if they are not powered then they have to be plugged into the headphone jack. Next confirm the audio driver is correctly installed. Finally confirm that the system sound and the sound for whichever program you are using is not muted.
Jul 14, 2011 | Cyber Acoustics CA-2014 Computer Speakers
Just got mobo and set, fan doesn't start, mobo doesn't give any sound nothing moves....did basic removal of mem and unneccesry one by one and still nothing...
Power. Start with power.
1) Make sure the 24-pin ATX main power cable is plugged in tightly to the mobo.
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain24
Ensure that the lock on the male connector (Power cable) is snapped over the tab on the female connector. (Mobo)
Push down on each wire to ensure it's metal terminal connector, is plugged on tightly to each pin.
Looking at the middle photo you are looking at the Front of the connector.
Looking at the photo to the far right, you are looking at a side shot, and the back of the connector. The back is where the wires go in.
Each wire ends in a metal terminal connector.
The metal terminal connector is shaped like a tube, so that it will slide on the pins in the mobo's ATX main power connector.
The metal terminal connector also has two locking tabs. One on each side.
http://www.alibaba.com/product-gs/292070393/male_and_female_crimp_terminal_connectors.html
Sometimes there may be a problem with the locking tabs. The metal terminal connector is not tightly on the pin. May not even touch the pin. Check each wire in the 24-pin ATX main power cable's connector. Push in on each one.
Everything is fine so far?
Perform the diagnostic test to see if the problem is the Power On switch, or the Power Supply.
Use a jumper wire on the back of the 24-pin ATX main power cable's connector.
Touch the jumper wire from the Soft Power On wire to ANY Ground wire.
The Soft Power On wire is the Green wire.
ANY Black wire you see is a Ground wire.
(Soft Power On is also abbreviated as PS_ON)
The general type of jumper wire used is a paper clip.
Thin, and stiff, plus a conductor of electricity.
The paper clip is straightened out, then bent into a U-shape.
Black plastic electrical tape is wrapped around the middle of the U.
This area is for you to hold onto the jumper wire.
The 'legs' of the jumper wire, go down into the appropriate socket holes, in the BACK of the 24-pin ATX main power cable's connector.
One leg goes down into the socket hole with the Green wire (PS_ON), and the other leg goes down into a socket hole with ANY Black wire.
The paper clip goes down into the socket hole RIGHT NEXT TO THE EXISTING WIRE that is already present.
Slides down right next to the wire, and touches the metal terminal.
The metal terminal is pretty far down in there.
Ensure that the paper clip is touching both metal terminals on the Green wire, and any Black wire.
Power supply comes on? You have a bad Power On switch,
http://www.directron.com/atxswitch.html
Power supply does Not come on? You have a bad Power Supply.
For additional questions please post in a Comment.
Regards,
joecoolvette
Jun 12, 2011 | Foxconn M61PMV Motherboard
Sony Vaio PCG-K33 will not power up
Hi
Ensure battery is secure, If so try removing it and plugging power supply in.ensure all power supply plugs are very tight and fitted, unplug each one and re-plug in to be sure. Sometimes the power supply lamp can be on but not actually supplying power out the other end.
Aug 17, 2009 | Sony VAIO PCG-K33 Notebook
Microphone isn't working with the computer.
1-select start2-select contrrol panel3-select sound speech and audio devices4-select sound and audio devices.5-confirm that mute box not signed.6-pres advanced in mic volume confirm mute box not signed7-select audio you will see capture screen in mic volume sign select.8-in default device press volume you will see volume control screen in mic volume confirm that mute box not signed
Mar 02, 2008 | Philips PH62080 Uni-Directional Microphone...
Hpdeskjet 940c printer
If the Power light is not illuminated, first check the power cable to ensure all connections are correct. Next, turn off the printer, then turn it on again. If the Power light does not become illuminated, the printer needs to be serviced. I believe if this doesn't work you have a bad power supply.
Jan 08, 2008 | HP DeskJet 940c InkJet Printer
Gaggia Syncrony Compact Coffee Maker/Espresso Machine Logo
290 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
