Question about GE Profile Spectra JGBP79 Gas Kitchen Range
GE Profile Gas Range oven turns off
The problem is with the oven. When it is hot for any extended amount of time (1 hour plus in most cases), the oven turns itself off and the panel shows F7 & E6. When we press the off button, the panel clears, then the broiler prompts come on and off continuously beeping each time, F7 occasionally appears during this time. The panel eventually stops flashing when the oven is cool. Then we can use the oven again until an hour later, the same thing happens again. The oven is about 5 years old and we've never had a problem until now. Anyone have an inexpensive and surefire fix?
I just read that the electronic panel malfunctions due to rear burner use. Now, I know that mine gets REALLY HOT in between the back burners (where the heat exhaust for the oven is) whenever I bake/broil. I am guessing that it can cause the same malfunction fromt he oven, as with the backburners. Whenever I use both back burners, mine shows F7 E6, too. Unplugging it for the night or just waiting til the beeping stops and then clearing it works... until I cook again. I read that the replacement part for the control panel is about $300 and another $200, more or less, to install it! I think this is more like a recall or manufacturer's problem. I have read plenty of complaints and I think GE needs to make a call to fix them!!
Posted on Jul 21, 2008
Ve a GE Xl44 Model JGBP26967P gas stove emitting carbon monoxide gas. To use the oven the house has to be open plus the vent has to turned on high.This is a big safety hazard. What can be done?
Check that there is a regulator .... and the gas pressure coming from the regulator to the manifold...if there is a regulator the gas pressure may be too high.....
the other problem would be dirty burners, but that would not be causing all of them to emit CO...
Most people do not realize it, but many gas ranges emit harmful amounts of CO....if they were furnaces they would be banned...
heatman101
Feb 06, 2011 | GE Profile Spectra JGBP90 Gas Kitchen...
Oven taking very long time to hit temperature. set at 400 it takes forever (1/2 hour) then gets stuck at 398
Replace the oven ignitor. (they get weak after a period of time, and will give those results, or stop heating altogether)
Nov 09, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
I lost my owner's manual for Spectra gas stove. How long to leave self cleaning on?
That will depend on how dirty the oven is. Times can vary from 2 to 4 hours, with an average of 3 hours. (plus cool down time)
Oct 02, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
Describe your GE Profile Spectra XL44 Oven
My GE Profile Convection Microwave Oven will beep and display a F2 for no apparent reason. What is this?
Mar 09, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Profile Gas Range Model:JGBP79AEV4AA When i turn on the oven the flow of gas is interupted and continues (sort of like stops and starts) oven does warm up to temp however takes a long time. Any ideas?
Possibly an ignitor or valve problem. We also see this sort of thing due to a control board failure. If this turns out to be your case we can help. We repair oven controllers at www.fixyourboard.com
Oct 13, 2009 | GE Profile Spectra JGBP79 Gas Kitchen...
GE Profile gas range
hello dreeden5
Ngafm at your service,
You have a GE Profile oven range. I and you just cleaned it and the pilot light on all four burners continues to click on and off.
It sounds like the gas line or the gas valve, have some debris in them!
They need to be evacuated by an experienced tech.
This time you need service.
Bless You ngafm
Please give me a good rating at this sight before you leave!
Thank You
Sep 10, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Ge spectra gas stove top not lighting
no gas flow sounds like a bad gas regulato on the stove. as for the 5 year old ge profile with ignitors not working, you need a part called a spark modual
Nov 16, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Profile Spectra JGBP79 Gas Kitchen Range Logo
590 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
