Question about Nikon Coolpix 4500 Digital Camera
Memory card write protected - Nikon Coolpix 4500 Digital Camera
  • 6,831 Answers
Hello
OK, if the memory card itself is locked, you might sometimes get this error code. All you need to do is to take out the memory card and switch the lever on the left side to the unlock.
If the error is still displayed after you did the above, you might want to try the card in another camera.
If the card works in another camera . the problem is with your card reader in your camera.
If you open you sd slot and look inside with a sharp light , you should be able to see on the left side of the slot there is a little copper or spring steel lever switch. This switch work as follows:
1. When no card is inserted / no write protection , the switch is open and thus the protection is off.
2. When locked card is inserted , the tab is depressed and tells the camera that the card is lock.
Contrary to popular belief ,the little tab on the sd card is not an electronic switch and does not physically influence the card operation itself. If you put a locked card into a camera without a sd lock switch , you would still be able to use the card normally.
It is incredible difficult to fix this switch because of space limitations in the sd card. Look into the sd slot and if you can see the switch , use a needle to pull the little tab down toward the base of the camera by about 2mm or until it works being careful not to bend it.
If this does not resolve your problem , there might be a short in the switch circuit and the camera will need to be disassembled to resolve this error. This should cost no more than $50.
Please feel free to contact me if you need further information
Kind regards
Andrea
Posted on Sep 06, 2010
Kodak easy share c183 memory card protected how to reset
Camera LCD: "Memory card is protected (Reset ... - Kodak
support.en.kodak.com/.../camera-lcd%3A-memory-card-is-protect...
KodakAug 25, 2010 - The camera screen displays "Memory card is protected (Reset switch on card). ... The memory card is locked so that data (pictures, videos, or files) ... The disk is write protected." when writing to or formatting an SD card. Share.
[PDF]KODAK EASYSHARE C183 Digital Camera
resources.kodak.com/support/pdf/en/manuals/.../C183_xUG_GLB_en.pd...
Kodak, EasyShare, Max, Perfect Touch, and Pulse are trademarks of Eastman Kodak. Company. ..... Access to more manual settings than Smart Capture mode. ..... NOTE: To delete protected pictures/videos, remove protection before deleting.
Jan 26, 2016 | Kodak Easyshare C183
Plz help me to remove write protection from my micro sd card.
Hi, slide up the Write protection switch which is white in color for the Memory Card Adapter to remove Write protection and Slide down to enable write protection of the Memory Card.
Please click on the link below to view the Write protection switch:
http://kb.sandisk.com/euf/assets/images/faqs/id1102_e3sdhc.gif
If you are using a microSD/microSDHC card or a miniSD/miniSDHC card, insert the card into the standard SD adapter.
Apr 16, 2011 | SanDisk 2GB microSD Memory Card
When i try to add music in to my card adapter pny SD 2 gb it says it has write protection and to take it off what do i do?..
To remove write protection
In your memory card adapter have a switch to on/off write protection.
pull this switch to down ,you can remove write protection of your memory card
thank you
Dec 23, 2010 | PNY 2GB microSD Memory Card
Want to copy some files to a memory card from a laptop but it says that the memory card is write-protected. how do i remove the write-protection to copy the files.
Some memory cards are having a write protection switch integrated on the side or on the back of the memory card for preventing the content from being erased or overwritten by accident, just like floppy disks. Both SD Memory Card and xD-Picture Card have their write protection switch on the side of the memory card in contrast to the Memory Stick PRO and some Memory Stick Duo that have their switch on the back of the card.
The SmartMedia Card is also supporting write protection but not with a switch. For protecting the SmartMedia Card's content you need to put a sticker on the card's write protection pad. It is the circle that can be found in the middle of the card, when facing the front of the card.
Oct 24, 2010 | Computers & Internet
How do i remove the protected card from my camera
When this problem occur you need to set the memory card unlock or not protected. Remove the memory card from camera and you can see a small button in the memory card, so you need to slide that to set the memory card unlock or not protected.
Jul 27, 2010 | Fuji FinePix A201 Digital Camera
PROTECTED CARD
Most SD memory cards have a small slide switch on the edge off the card. This switch is used to write ptotect the data on the SD card - you can lock or unlock the SD card be sliding this switch.
Jun 18, 2010 | SanDisk 2GB microSD Memory Card
It says my memory card is protected
On the side of the memory card, there is a small slider that locks and protects the memory card from being overwritten. Yours may be in the locked position. Simply pull out your memory card form your camera and unlock your memory card by sliding the tab.
Hope this helps,
Andrew
Do not forget to vote.
Apr 09, 2010 | Kodak EasyShare One Digital Camera
Shows the error memory card is protected
When this problem occur you need to set the memory card not protected. Remove the memory card from camera and you can see a small button in the memory card, so you need to slide that to set the memory card not protected.
Feb 05, 2010 | Panasonic Lumix DMC-FS7 Digital Camera
Memory card protected
If your memory card is protected, remove the memory card. Look at your memory card you can see there a small push button push it so that the card will not protected. Reinsert your memory card to your camera.
Regards
PCmania
Sep 28, 2009 | Kodak EasyShare C653 Digital Camera
I cant copy song in memory card its shows card is write protected
What sort of memory card is it?  can you remove it and install it in a card reader directly on your pc?  What is trhe phone?
Jan 14, 2009 | Motorola Mobility ROKR E6 Smartphone
Nikon Coolpix 4500 Digital Camera Logo
807 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
