Question about Drills
I have a Mastercraft drill press model 55-5917-0 and ahve two problems; 1 - the chuck all of a sudden fell wile operating the drill. I tried to tap it back in place but it keeps falling off as soon as some pressure is applied... how do I fix this? 2 - the return spring for the handle on this drill press is broken ...where can i get a new spring??
  • 10,865 Answers
Hello Jo Ray. The chuck is friction fit. To reinstall it you may need an assistant. Put the chuck on the spindle, have your assistant hold it while you hit it using a block of wood against the chuck and a hammer. A couple of good blows and the chuck will be installed. Regarding the spring, go to this link and select the canadian tire store closest to you to get the part. http://www.canadiantire.ca/AST/NavigationAssortments/WebStore/Navigation/FooterNavigation/BusinessLinks/Section1/CustomerService.jsp
Posted on Sep 06, 2010
Tooth fell out of chuck
I believe you are in line for a different chuck.
I had this happen, and began a 3 year quest for a chuck.
Know that most chucks simply screw on the the shaft that sticks out of the drill.
They are tightly screwed on, but are removable, usually.
I recommend you try tool sales & repair places, and sooner or later, you should find a different chuck.
I does not need to be off a machine like yours, as they are sort of universal.
God bless your efforts.
Oct 08, 2015 | Genesis GDP500 8-Inch 5-Speed Drill Press
MasterCraft 8 inch drill press (Model 55-5915-4). Problem: the whole chuck unit is attached to a post that spins and in turn spins the chuck. While trying to drill into a piece of stone the whole chuck...
Most drill press chucks are attached via a tapered post on the back end of the chuck. This is a short post about 3/4 inch in diameter and 3/4 inch tall. This short tapered post (the taper is very slight) fits into a tapered hole. That hole is often in the end of a second a tapered shaft (usually call a taper, R8 is a common designation). That shaft is about 6 or 8 inches long and fits into another hole, much deeper of course. It is this longer taper that is meant to be disassembled routinely for inserting different tools. The short one is not meant to be routinely separated. I'm not sure which of these is giving you trouble, but in either case the key thing is that the mating surfaces be clean. The means of attachment is simply by pressing them together. If it is the short post that has come apart, clean both surfaces carefully with a clean rag - you don't want any dust or dirt at all. Open the jaws of the drill chuck all of the way so that the three jaws are retracted inside the chuck. Place the chuck on the table with table raised up enough that you can pull the drill press handle down slowly but forcefully to fully seat this taper. On the other hand, if it is the long taper that has come apart, this taper is not so slight and it meant to be jammed together by hand. Make sure the mating surfaces are clean, align the tang (that's the top end of the taper that looks like a giant screwdriver blade) is aligned with where it will fit all of the way in, then just give it a quick jam into place by lifting it into place quite briskly. By the way, while clean these tapered surfaces look carefully for any nicks or bumps- you will have to remove these with a small file. It's ok to have a small flat spot on the tapered post or shaft, just keep it very small. Good luck, I hope you found this helpful. Al K
Aug 04, 2011 | Garden
I have a 9 in drill press and the chuck fell off while doing some hard drilling . it looks like a press fit and i wanted to be sure before i tried anything
Some drill-to-chuck fittings are known as morris tapers, and are incredibly strong. Look in the end of your motor shaft for a screw hole. The chuck probably has a screw or bolt holding it in place once the tapers align.
Best regards, --W/D--
Jan 21, 2011 | Drills
My 18v ryobi cordless drill does not hold a drill bit even tho i hold and tighten the chuck with my hand. It will hold for a wile but will eventually fall out. Thanks
Abrupt stops can loosen the ratcheting chucks. Before the invention of those chucks we had the ones that required a key. The proper way to tighten them is to alternate between all three position in order to "seat" the jaws on the bit evenly.That all but guaranteed it would not come loose I assume you have a ratcheting "one handed chuck". ther's only one way to tighten them and you don't get the same grabbing force. The only thing I can suggest is to try to eliminate abrupt stops or try cranking it tighter.
Jun 14, 2010 | Ryobi 18v Variable Speed Right Angle Drill...
Can't remove the chuck on my mastercraft drill press.
generally they are a taper fit, is there a slot cut into the spindle?? If so you should have a wedge when you bought it to slide into the slot and tap with a hammer to release the taper shank. Let me know if it is something other than that. on some of the Jacobs chucks they also made special wedges that you put in from either side to remove it again tapping one wedge at a time to put equal pressure on them.
Jan 03, 2010 | Drills
Need to replace chuck on 1/2'' mastercraft hammer drill. Which chuck do I need??? model 54-2986
took off the old chuck , measured, and took it with me to purchase a new one.
Dec 09, 2009 | Drills
Mastercraft seized up chuck
being that new, it should not have seized up, all you can do is try spraying wd40 into the chuck between the teeth and mandrill. if it doesnt work, replace the chuck, it is fairly inexpensive
Sep 02, 2009 | Drills
CaN'T REMOVE A 1/2'' CHUCK FROM A 13'' FLOOR MODEL CRAFTSMAN DRILL
Try heating it up with a torch and tapping it off with a punch
Jul 24, 2009 | Craftsman Drills
Drills Logo
670 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
